RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Electronics
Thread Tools Display Modes
Old 04-23-2009, 06:25 AM   #1
PunkRC
PunkRC's Avatar
Default PunkRC Dig Switch
We now have P. Patent Protection....
I thought I'd tell you all first. Here it is, the PunkRC Dig Switch
1.5" x 1.0" in size (thats small)
Handles over Twice the Power of the "Dig-a-ma-jig" with the radio shack switches. Each Dig Switch Relay Rated at 12A at 35VDC.
Here is a video, more details coming. Watch the WATERPROOF test!
I will be taking pre-orders (20% off) and doing a giveaway. I will update you all.
Watch the video:
http://www.youtube.com/watch?v=B7foeSpDaAA
[EDIT] Production Model
[EDIT] Prototype
[EDIT] Wiring Diagram Added
Commence Drooling......
__________________
PunkRC
www.punkrc.com
Last edited by PunkRC; 05-07-2009 at 01:51 PM. Reason: Typo N.P. Patent to P.Patent added (20% off)
PunkRC is offline   Reply With Quote
Old 04-23-2009, 07:19 AM   #2
rockassassin
I am getting one.
rockassassin is offline   Reply With Quote
Old 04-23-2009, 08:38 AM   #3
Offroader5
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Sweeeeeet Nice job.
Get 'em done fast....I have two MOA rigs that need these quick.
How long do ya think? I may have to build my "dig-a-ma-jig" till these are ready if it's going to be too long.
EDIT: Umm...nevermind, just watched the vid and saw the available date of May 15th.
Do we really have to wait that long? :-(
__________________
Quote:
Originally Posted by Duuuuuuuude View Post
Offroader5: you are a kind and gentle soul, a true gentleman of great intelligence and understanding.
Offroader5 is offline   Reply With Quote
Old 04-23-2009, 08:52 AM   #4
PunkRC
PunkRC's Avatar
I will have limited quantities avaliable this weekend. They will be the a proto run of the production setup. The production will have a green circuit board while these will be tan like the one shown. These will be the final check before I place a large order.
If you PM me, we can work something out. I can get you one of those. I will have 4-10 of them.
Also I am always looking for people to make a video or post a review, so those will get also get priority.
EDIT: I will have these things shipping before the 15th, but I just don't want people screaming if the production units are delayed. If I get enough pre-orders, I will have them shipping about May 2nd.
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 09:01 AM   #5
PunkRC
PunkRC's Avatar
Here are some specs I am putting together.
TX Position | LED | Function
Left | Red | Motor #1 Off</STRONG>
Center | Green | Both Motors On</STRONG>
Right | Blue | Motor #2 Off</STRONG>
Technical Specs:
Size: 1.5"W x 1.0"L x ±1.0"H
Power Source: Radio RX
Power Draw: <150mA (similar to standard servo)
RX Voltage: 4.8V - 6.5V Receivers
Motor Capacity: Any
Switch Rating: 12Amps @ 35V (each motor)
Water Resistant Electronics plus Water Proofing Seal
Hookup:
I will have a diagram drawn up soon, but it is REALLY easy.
1 - Plug the Dig Switch Servo Wire into Receiver's Spare Channel (Usually #3)
2 - Wire ESC's Negative Wire to Motors as normal
3 - Solder the Center Dig Switch Contact to the ESC Positive Motor Wire Output
4 - Solder each Outside Contact to the Positive Terminal of each Motor
5 - Trim TX Channel to Center with normal Endpoints
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 09:13 AM   #6
BigB_117
BigB_117's Avatar
So this little sucker will do front and rear dig on a MOA rig? sweet.
I like how small it it.
Any idea's on cost?
BigB_117 is offline   Reply With Quote
Old 04-23-2009, 09:20 AM   #7
PunkRC
PunkRC's Avatar
Quote:
Originally Posted by BigB_117 View Post
Any idea's on cost?
I have them finally listed on www.punkrc.com
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 09:28 AM   #8
BigB_117
BigB_117's Avatar
Quote:
That seems like a good price.
Can this unit be switched in and out of dig while on the throttle? I know that has caused switch's to burn out for some that are running the switch's and servo setup.
Old 04-23-2009, 09:30 AM   #9
Mic
I am here
Mic's Avatar
Looks like a good product the only thing that I maybe missing is that it does not short the motor when the DIG is operated (that causes the breaking effect to lock the motor) I really like your dual steer computer that I have been using for about a year so I wouls like to try th DIG switch out.
__________________
People that can't do it should stop telling the people who are doing it , that it can't be done.
Mic is offline   Reply With Quote
Old 04-23-2009, 09:38 AM   #10
binaryterror
Team Wolf Pack
binaryterror's Avatar
Does this short the motor to causing it to lock stronger, or just turn it off?
Either way...pre-order done through the site!
__________________
BeetleJuice Berg...(Army against the Moonbuggy invasion)
Representing MiRCa @ 2010 Nationals in Disney
binaryterror is online now   Reply With Quote
Old 04-23-2009, 09:45 AM   #11
PunkRC
PunkRC's Avatar
Quote:
It turns it off without shorting. Seems to work nearly as well and doing locking would add too much to price, size. (EDIT: Read Below, the shorting has been added without increasing price, but it is 0.3" longer)
Well those switches were rated at 3A or 5A, this is 12A. Also I am experimenting with adding capacitors (or other) across terminals to help stop the voltage peak. The arcing happens when disconecting a inductive load.
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 10:28 AM   #12
51504rock
Just ordered up one of these sweet little dig switches. I will be doing a review with some videos as soon as it receive it
51504rock is online now   Reply With Quote
Old 04-23-2009, 10:53 AM   #13
Shane_744
You can't pass following.
Shane_744's Avatar
Pretty good little setup. Size is good as well. I like the innovation. It will help more folks have MOA dig that couldn't before.
On the other hand that price is killing me. I can make an electric MOA dig with two manly dig switches (Rated 15 amps @ 250v each) and HS-55 servo for $17 total (plus shipping) and some soldering and glue.
Just my .02
Shane_744 is offline   Reply With Quote
Old 04-23-2009, 11:24 AM   #14
Arct1k
Nice innovation... where was it a week ago when i made my switches!
Arct1k is offline   Reply With Quote
Old 04-23-2009, 11:31 AM   #15
PunkRC
PunkRC's Avatar
Agreed, I don't think that this will KILL those dig switches. Cost is a issue.
The advantages are no moving parts, water resistant, simple to wire, compact, no endpoints to adjust. These relay are each rates at 12A @ 36VDC or 250VAC, so the switches are close. Normal draw does not take much, just guys burn them when disconnecting a powered motor.
About the "burning" the switches. It this will come with some capacitor like components that will absorb the voltage spikes that make the arcing. THey are however, not caps (those can actually add to the problem) They will be included with the item.
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 11:33 AM   #16
JohnRobHolmes
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
have you done any testing on positive side arcing vs negative side arcing in relation to the motor? Very cool product!
__________________
www.HolmesHobbies.com
Your Source for High Power Electronics
Team RCC Sponsor
midwestrcc.com
Team Futaba
JohnRobHolmes is online now   Reply With Quote
Old 04-23-2009, 11:56 AM   #17
PunkRC
PunkRC's Avatar
Quote:
I have not. But I am adding some Cap-Like parts that absorb the spark. If you are not a nerd, skip this: It is essentially like two zener diodes back to back, then when the voltage goes past the reverse breakdown voltage (mine are rated about 30V) it will short it out instead of going across the contacts.
Make sence?
__________________
PunkRC
www.punkrc.com
Old 04-23-2009, 01:02 PM   #18
Rocksolo
holy sheite!
I wish that available 1 month ago.
Thats is definately on the wish....... I have 2 spare 25amp switches so it may be a while, or not.
I am tuned in to see how that thing actually works in the long run.
nice product
__________________
when all else fails, I rock solo!
Rocksolo is offline   Reply With Quote
Old 04-23-2009, 01:33 PM   #19
Shane_744
Shane_744's Avatar
Great points.
Old 04-23-2009, 02:04 PM   #20
Hawk Mortimer
Default Dig witch
PunkRc,
Pre-order placed.
Sure hope my understanding is correct. Using your "Dig Switch" I do not need the two (2) mechanical switches and the servo.
Correct or not so correct?
Thanks,
Hawk
Hawk Mortimer is offline   Reply With Quote
You may not edit your posts
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
