10-23-2005, 06:12 PM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: crescent city
| Xmod/jeep build
ok, so i bought a xmod f-150. i am a "jeepguy"/so i bought a jeep body(from a model kit) the 4wd kit, the lift/tire kit, the gearing /motor kit, so, the build is on.. stock=not very good wheelin//open diffs/ put the 4wd kit in// these parts are small!! the flat side of the dogbones goes inward toward gears!! pics to come!! |
Sponsored Links | |
10-23-2005, 06:29 PM | #2 |
10-23-2005, 06:43 PM | #3 |
Newbie Join Date: Sep 2004
10-23-2005, 09:23 PM | #4 |
lots of info there//thanx!
10-23-2005, 09:40 PM | #5 |
Quarry Creeper Join Date: Feb 2004
Thats just what I Plained on Doing, Just couldnt find a Jeep body and The Gearing sucked so.. I brought it back. Cant Wait to see Yours .I mite have to Go Get a Nother.
10-24-2005, 08:30 AM | #6 |
jeep body is from a plastic model kit//with the gearing kit it does a little better/& it has proportional throttle & steering. needs diffs locked though. with the lift & bigger tires it can handle more obsticles, but still looses traction from open diffs. |
10-24-2005, 09:17 AM | #7 |
why did my xmod build get moved to general chit chat/non tech?? my cam died so i have not been able to update my build yet. this is going to be tech!! THIS IS GOING TO BE A ROCKCRAWLER!! Last edited by jeepguy; 10-24-2005 at 10:12 AM. |
10-24-2005, 10:11 AM | #8 |
this thing doesnt have alot of flex, but i think if i can get the diffs locked it will be a decent trail rig,should handle some rocks!! got the lift & tires in. i think i did everything about 5 times. put in wrong parts. so it crawls a little better now. i will get pics when i get batteries for my cam later. i am going to figure out how to lock the diffs also. |
10-24-2005, 05:22 PM | #9 |
10-25-2005, 08:22 AM | #10 |
got it locked front & rear, with the notched on middle swivle cut mostly/ good flex. lots of traction. the lowest gear still is too high though. i need to find even lower gears or make another reduction where motor is & move motor up. |
11-06-2005, 03:32 PM | #11 |
some pics of my new body & the cage in progress i used a piece of fence & just bent it into the shape i wanted/no welding or anything needed. but i want to put more bars in it. this pics kinda confusin cause of the fence patrs behind it the fence before cutting & bending Last edited by jeepguy; 11-06-2005 at 03:36 PM. |
11-06-2005, 05:29 PM | #12 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
maybe you could find some larger tires from a different truck kit. i remember mpc and others offering lots of 4x4 kits at one time.
11-06-2005, 06:16 PM | #13 |
| i havent figured out how to get it geared low enough or enough power for bigger tires yet. why are these words so big?? anyway i wanna get it to do some mild crawlin/ |
11-06-2005, 06:23 PM | #14 |
RCC Addict Join Date: Jul 2005 Location: Provo
about how tall are those tires?
11-06-2005, 07:30 PM | #15 |
11-08-2005, 08:08 AM | #16 |
put bearings in it also replaced stage 1 stock motor magnets with bigger mags out of a "crest spinbrush" yes i am juicing it up with toothbrush parts!! |
11-08-2005, 03:00 PM | #17 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
Where do you get xmod?
11-11-2005, 03:04 AM | #18 |
Rock Stacker Join Date: Oct 2005 Location: Newbie general!!!
Probably a stupid idea, and your motor would hate you but if you had a lathe, stupidity and welding magnets you could make some new magnets. 220,000 rpm for about 2 seconds then theyres a lot of smoke. Joke. If i had a motor to spare id try to make it work with welding magnets. imagine the grunt. Crawlerkid |
11-11-2005, 12:40 PM | #19 | |
RCC Addict Join Date: May 2005 Location: Auburn, WA
| Quote:
11-13-2005, 04:52 PM | #20 |
i'll sell you mine for half of what i got into it!
