05-31-2009, 01:25 AM | #1 |
Newbie Join Date: May 2009 Location: Australia, Townsville
| New 3racing High Clearance Knuckle.
Anyone running these yet? I was looking at them here: http://www.rcmart.com/catalog/rc-axi...cPath=595_1160 I thought they might be a good investment. Any ideas or input with them please? |
Sponsored Links | |
05-31-2009, 01:40 AM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Actually a portal axle setup, wish they had a high steer arm though. I would like to try em, when I can get them.
05-31-2009, 02:13 AM | #3 |
Well I dont have the problems of steering rods at the front, mine has a plate running across on the inside. Gives me bettera approach angles. Bugger it, im ordering a set now....lol |
05-31-2009, 07:49 AM | #4 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Those are pretty sick. I agree with gunnar tho. I would get some if they had a high steer arm. Looks like your gunna gain about a 1/4 in GC.
05-31-2009, 08:06 AM | #5 |
I wanna be Dave Join Date: Sep 2005 Location: Houston, TX
05-31-2009, 08:08 AM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Jakes Performance Hobbies has them in stock.... |
05-31-2009, 08:19 AM | #7 |
| Yes, I don't think there is reduction either. I just said portal because that's what they remind me of, and if there is no idler gear, motor rotation would have to be reversed. Looking at the cover, it looks like a two gear setup.
05-31-2009, 10:04 AM | #8 |
20K Club Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| Probably why they only sell them in sets of 4. Interesting to see them doing a part like that. If they are strong enough I would even consider running them on just the rear of my berg.
05-31-2009, 10:13 AM | #9 |
In certain bind situations, could also put additional stress on the end of the axle housing too. More distance between center of axle and stub centerline=more rotational leverage=twist off the end of the housing.
05-31-2009, 10:43 AM | #10 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I saw a picture of the inside of them somewhere. The top gear was smaller than the bottom gear. There looks like there is some reduction though not much.
05-31-2009, 02:21 PM | #11 |
Rock Crawler Join Date: Sep 2004 Location: eureka
I wonder how much you actually gain in gc. it looks like they will make you wider as well . seems kinda cool , makes you wider while keeping the width/gc of axle in somewhat the same ratio as before. but like gunnar said , they will probably twist off the axles c's unless maybe they had enough reduction to help with that. |
05-31-2009, 02:37 PM | #12 |
Hateraide Join Date: Dec 2008 Location: Mission BC
this should help answer all your guessing Heres some better pics for you guys to really show the internals and stuff |
05-31-2009, 02:57 PM | #13 |
thanks for the pics. how many teeth are on those gears? |
05-31-2009, 02:58 PM | #14 |
im not positive there pics off of another site
05-31-2009, 03:00 PM | #15 |
Shelf queen Join Date: Aug 2008 Location: Internet
Last months issue of RC Car Action had these in there. According to them, these portal setups provide a 1.6:1 gear reduction
05-31-2009, 03:00 PM | #16 |
they also have them im blue for the Cr01
05-31-2009, 03:56 PM | #17 |
| Yea, looks like 10 and 16 on the tooth count. Reverse motor rotation. Yes they would raise COG, but lowering belly height some would help. Hard tell if the shafts are fully bearing-supported, the top shaft might be a bushing, but could be a tiny bearing too.
05-31-2009, 04:42 PM | #18 |
Pebble Pounder Join Date: Dec 2008 Location: SE Oklahoma
Umm, since the arm is centered vertically couldn't you flip them and lower the CG?
05-31-2009, 04:49 PM | #19 |
Custom Carbon Fiber Join Date: Oct 2007 Location: Connecticut :(
05-31-2009, 04:50 PM | #20 |
Yeah, a little bit of reduction. Might not be a bad idea for the rear...
Thread Tools | |
Display Modes | |
