07-16-2009, 08:29 PM | #1 |
Quarry Creeper Join Date: Jun 2008 Location: Hell
| Pro mod Bronco buggy chassis
I just started a new tube chassis to replace the one from my previous build (which is in the 2.2 forum if you've seen it) This one is alot smaller so it's using shortened door, fender panels. More just a buggy with a Bronco grill. I'm just gonna be brief for right now.
Sponsored Links | |
07-16-2009, 08:45 PM | #2 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
I got a summit trans in my Bronco What dims do you need? |
07-16-2009, 09:04 PM | #3 |
I need to see how tall it is if you laid it on it's side (the width) And how do you like the gear change? Does it allow you to change from a medium high speed to a average crawl ratio or better? |
07-16-2009, 09:10 PM | #4 | |
| Quote:
FRom outside of the spur gear to the outside the motor its 3.5 in widelike in this picture the gear box itself is about 2.25 in. wide | |
07-16-2009, 09:14 PM | #5 |
Tits...... I only got about an inch to spare. Idk maybe I could just mount it up front where the engine would be but then I still need a T case and it's gonna be heavy.
07-16-2009, 09:15 PM | #6 |
ahhh spur is not installed in that pic sorry but you get what i mean right? the trans is quite big my frame rails are 2.875 wide and it hangs out over them a bit but its worth it if you can squeeze it in there. |
07-16-2009, 09:21 PM | #7 |
Ok, well thanks alot. I'm even thinking about trying to take the gears and make a custom gearbox but I don't have the machine to do it with....yet. lol. I'm gonna probobly buy a tranny anyway cause they go for cheap on ebay, I just missed one for $20 shipped the other day, I was pissed
07-17-2009, 08:44 AM | #8 |
I rolled some ax10 axles under with 1.9 flatirons which look huge! mock up panels Full droop Pretty skinny chassis at 5.25in, wheels at 9in |
07-17-2009, 08:57 AM | #9 |
Rock Stacker Join Date: Sep 2006 Location: vancouver
i like it i think those tires are perfect for a buggy that size keep up the good work |
07-19-2009, 04:06 PM | #10 |
Got a little more done but I haven't been workin on it 10 hours a day since Thurs. lol. But I started cuttin up the body panels and I've been making panels out of this .030 aluminium from homedepot which I've been cutting on a wood cutting band saw with a metal cutting blade lol, sucks but works ok for this light stuff. I made the seats, roof and 2 floor panels out of it and the firewall out k&s sheet stainless. I'm gonna wrap the seats in something but i dont know what yet.
This stuff is gonna bolt down, eventually Heres compared to the old chassis Seeing what I'm gonna do with suspension travel I'v got no idea right now Cross eyed Willy Last edited by super mud; 07-19-2009 at 04:11 PM. |
07-29-2009, 07:54 PM | #11 |
Didn't get much tube work done but I've been messing with someother stuff lately. tight space. Esc will probobly go up on the firewall though. 3/4in to the table messing with some styrene, I need to get some green putty from the local hobby store. And other stuff, can't remeber wat micro t batteries (1/3A) (6v) brass tube for the space filler. Not finished, need to find the volt meter to check it. (My father always takes my tools) Looks nasty with all the shoo goo and bad solders, Could not get the factory spot solders hot enough to detach so I ripped them off and grinded the poles with the dremel. Probobly a little bit bigger than scale. If it holds a charge I'd like to use it as a receiver battery. For the big batteries, I'm gonna use 2/3a (6) in the nunchuck style which will hide under the rock sliders/side skids. Last edited by super mud; 07-29-2009 at 08:06 PM. |
07-29-2009, 08:12 PM | #12 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Looks good. Love me some Fords. |
07-29-2009, 08:37 PM | #13 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
Touche on the batteray |
07-29-2009, 09:28 PM | #14 |
Found the volt meter. (I had it, not my dad lol) And I was getting 4.5v which I wasn't expecting for overcharged batteries which had been sitting for like a year+. So I popped it in the chrager on 1amp then remembered it's not regular 2/3a receiver batteries. It got super hot (smell of burnt shoo goo was in the air) and now I was getting 2.7v, great . Forgot I had a micro t wall charger so I converted that to tamiya plugs and now I can use the adptors for this and my dx6 and not charge on 1amp I'm pretty sure my dx6 battery was screwed along time ago though. Right now I'm letting it cool and I'm gonna try the microt charger.
07-29-2009, 11:01 PM | #15 |
RCC Addict Join Date: Sep 2005 Location: Lehi
MMMMMM, Waffles and cereal! Shes not looking bad! |
07-29-2009, 11:58 PM | #16 |
Rock Stacker Join Date: Mar 2009 Location: Albuquerque
Very nice tube work. Cool rig. Waffles need some peanut butter and then a bigger glass of milk. |
07-30-2009, 01:23 PM | #17 |
Lol, penut butter. Brazed some nuts on. Very very hard with 2mm size nuts (2-56) But what I do is have a surface to lay the nut on which is the only thing that seems like would work. Motor mount: just like full size custom mounts. Dirty but strong. I'll do the other side once I figure out how low it can drop/angle. I'm running out of Silv and my 15' of brakeline "magicaly dissapeared", so I got to get a little more for the sub frame. Then off to the sand blaster so it dosn't look like ass. |
08-04-2009, 02:02 PM | #18 |
Little more done. |
08-15-2009, 04:59 PM | #19 |
Got a little more done. I also got more brazing silv in the the mail so I can finish up the chassis. I did some stuff with my electronics LED light bar Pico switch made from a servo board (if u didnt see my thread for it) ESC mounts My antenna on my dx6 was broken so I shortened it re sufacing the screen which had eaten spots from CA activator (previous owner lol) I was swaping lockers from a used axle I got and found this which was cool Some mock up pics. It looks cooler in person which is weird, no joke. |
08-15-2009, 06:59 PM | #20 |
Quarry Creeper Join Date: Apr 2008 Location: santa rosa
if i were you i would get a different esc i had to go throught 3 to get one that worked descently im not sure if you have had probs with yours but i hate mine but your bronco is freekin awsome man |
