07-22-2009, 12:53 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: little egg harbor
| The Home Made BMV
Last comp i broke my tuber and always had trouble with it, it also always bottom rubed, so i decided to build a BMV, heres what it looks like so far, bottom of skid plate, those screws sticking out aren't staying like that, instead of buying the collors i used ax10, t-maxx, and fj cco1 drive shaft ends, i cut off the connecter part where the joint connects, |
Sponsored Links | |
07-22-2009, 01:28 PM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: Houston, TX
Looks good! I always like my BMV2, but I would bend the wires too easily...and finally gave up with replacing them.
07-22-2009, 08:32 PM | #3 |
just about done with it, just some little stuff that needs to be done. Clearence |
07-22-2009, 10:45 PM | #4 |
Rock Stacker Join Date: Jul 2008 Location: Spring
looking good but that esc is probably in the worst spot you could find... Maybe a little lower on the rear axle but let see some action shots...
07-22-2009, 10:49 PM | #5 |
Hateraide Join Date: Dec 2008 Location: Mission BC
07-23-2009, 12:24 AM | #6 |
Quarry Creeper Join Date: Mar 2004
Pretty cool. I am on my second homemade BMV chassis as well. I have the ESC on the rear plastic block. One other difference I did was I angled the axles some more. You will have some issues with the HEAVY driveline angle. I will grab some pics of mine when I get it finished (this week) and see what you think (mind you I am running the stock drivelines still) DIma |
07-23-2009, 10:19 AM | #7 |
Is it bad if the holes for the rods are a little big and it flexes with no resistance?:?
07-23-2009, 11:41 AM | #8 |
07-23-2009, 01:01 PM | #9 |
Rock Stacker Join Date: Mar 2009 Location: Abq
nice, i really like that. where did you get that wire? i would like to get some but is it just steel or aluminum wire? 1/8 or so? thanks |
07-23-2009, 01:21 PM | #10 |
did also know you have the two bottom bolts on your diff missing
07-23-2009, 01:34 PM | #11 | ||
| Quote:
Quote:
and yes i kno there not in there , Thanks though | ||
07-23-2009, 03:18 PM | #12 | |
| Quote:
You DO want piano wire because it does not bend like regular wire does. It is a bit stiffer, and it retains its original shape. DIma | |
07-23-2009, 08:02 PM | #13 |
Thanks much for the info. I went to my LHS and got some 1/8in music wire and a bunch of collars with set screws, so I should be set. |
