Go Back   RCCrawler Forums > RCCrawler General Tech > General Crawlers
Loading
Thread: New Frame
Old 01-18-2006, 07:46 AM   #1
Default New Frame
building a frame/its kinda overkill but was the smallest square tube i could find for now. not sure about suspension yet.
wanted to run leaf springs but dont think it would look right with the frame & body.
& dont mind the welds, it was late & i was in a hurry.
jeepguy is offline   Reply With Quote
Old 01-18-2006, 12:43 PM   #2
Interesting. Are you running the shocks as links like that, or is that just for mock-up? Seems kinda of like regressing a bit - putting a square tube frame and leaf springs under a vehicle that is all tube and has coil overs "stock" But I like the way the frame tucks up under the body. Is it pretty rigid? The 1:18 rigs are pretty light, but it looks like you could toss another cross-brace in there, just for good measure. Are you mounting all the "guts" up in the cab?
Mad Scientist is offline   Reply With Quote
Old 01-18-2006, 01:34 PM   #3
there will be more bracing. i'm gonna mount my servo on the fram tucked under the hood.
the battery will be in the center.possibly tucked up halfway in between the seats but back a little/ with a skidplate across.
& the electronics are gonna be in the back seat or on back somewhere.
i am not sure about the suspension yet. was gonna do leafs but the nylint axles are kinda big for that(doesnt look right..
might make some different links/ran outa time.
Old 01-18-2006, 08:26 PM   #4
that reminds me of the old tamiya blazing blazer. looks pretty cool.
king_crawler is offline   Reply With Quote
Old 01-21-2006, 07:45 AM   #5
got my servo mounted, & my battery tray made
Old 01-21-2006, 08:58 AM   #6
It looks like you are going to get alot of bump steer on with that servo placement. Looks good otherwise.
RD400 is offline   Reply With Quote
Old 01-21-2006, 09:19 AM   #7
Why not mount the servo on the axle where the original steering assembly goes? Are going for a scale look, or is there another reason? It is up to you, but like RD400 said, you are going to get a lot of bump steer, and your articulation may be affected. And if you put the servo on the axle, you could put a winch up where the steering servo is now
Old 01-21-2006, 12:53 PM   #8
going for a more scale look! as good as i can get with these axles anyway.
wont get much bump steer with the low gear mod, it barely moves.
i want everything tucked up in between the frame rails for a low cog & smooth look.
then i wont need much lift for good ground clearance.
i am not going to go for alot of articulation but a more realistic suspension travel.
with the heavier frame & decreased wheel travel it should pull tires off the ground as it climbs the bigger rocks.
Old 01-21-2006, 06:54 PM   #9
heres some redneck links i made out of some brass roundstock i had.(or copper,whatever it was it was hard to drill through)
the rear is ok, but the front needs to be way different(no flex.
Old 01-24-2006, 08:38 PM   #10
just ordered a tlt kit/the nylints gonna get some new axles.
Old 01-25-2006, 12:51 AM   #11
Quote:
thats a shame! so your going to be left with a nylint bodied TLT....
it was looking sooo good in that last pic!
SlammedMini469 is offline   Reply With Quote
Old 01-25-2006, 08:14 AM   #12
i think i'll finish it the way it is & build a whole new fram for my next truck using my camo scorpian body//i wanna see what this thing will be like on the rocks.
You may not edit your posts
