Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Loading
Thread: Pro arena truck
Old 04-08-2010, 07:59 PM   #1
Default Pro arena truck
well after i finished my scale truck i still have the itch to build
so i decided to flex my fab skilz and build something a little different a pro arena truck similar to what you would see racing inbetween rounds at a monster jam or 4 wheel jamboree event
basicaly a poor mans pro 4 race truck
it will be a combination of a mrc and a losi mini lst
and ofcorse toped with another blazer
the tires will tuck nucly inside the body to look as scale as possable
raceace is offline   Reply With Quote
Old 04-08-2010, 08:03 PM   #2
well i had to flip the lst gearbox to get everything to move the right direction
and when i went to install the lst diff into the rear axle i was disapointed the the axles wont fit in the side gears if anyone has tried this let me know how you made it work
Old 04-08-2010, 08:17 PM   #3
Looks like your off to a great start! Subscribed
KRAWLR4life is offline   Reply With Quote
Old 04-08-2010, 10:37 PM   #4
looks cool so far. i wanna do an ifs truck someday.
dieselfuel is offline   Reply With Quote
Old 04-09-2010, 07:28 AM   #5
I was considering doing this to my MLST as well.
Why are you dropping the MLST diff into the MRC case? yes they are the same Ring and Pinion, but the axle output cup on the MLST is a different shape than the MRC axle.
What you will need to do to make this work is buy the metal lockers for the MRC and put them in the back, and either mod the front ones, or glue-lock (jbweld, epoxy, etc) the diff gears for the MLST diff.
Or, just keep the MRC axle complete when you swap it over to the IFS rig.
Also, are you going to be using any wideners for the MRC axle to get it the same width as the MLST? and... The MLST uses an M3 threaded axle stub, but the MRC has the more common M4 stub, are you just putting the other pair of MRC stubs in the MLST Hubs? (They fit, you might as well)
I think the reason I haven't done this yet is the MLST has some pretty weak components, IE dogbones, that couldn't even stand up to stock components. What are your plans to beef that up?
I want to see this work because I want to make a 1.9 IFS Tracker with the same components (I might just lock-out the rear axle for now though) but I don't think it will stand up to much abuse.
monkeyracer is offline   Reply With Quote
Old 04-09-2010, 06:43 PM   #6
well since this will b a race truck and not a crawler i want an open diff in both front and rear so will have a decent turning radius
i am going to be makin new front a arms to narrow it up to the same with as the mrc rear axle and allow the tires to tuck into the body
not sure on the bones yet
i will prob have to build the from scratch because they will b so short
thanks for the info on the axle stubs i will swap them
Old 04-09-2010, 07:02 PM   #7
well i messed up when i layed out the wheelbase so i had to shorten it 1 inch and move the front suspention back and relocate the motor
Old 04-09-2010, 08:05 PM   #8
cool, i'll be watching to see what you end up doing!
Old 04-12-2010, 02:49 PM   #9
made some progress today
Old 04-12-2010, 04:40 PM   #10
Old 04-13-2010, 05:52 AM   #11
Cool idea!
rquarte is offline   Reply With Quote
Old 04-13-2010, 09:41 AM   #12
Wait....Why was this moved???? It's a 1.9 scale rig.The 1.9 scale rigs in the 1.9 section aren't really crawlers either.Their trail trucks that can do "some" light crawling. I feel this is a perfect example of a 1.9 scale build.It's unique, well planned, and will be very 1.9 scale when complete. The only reason I'm saying anything is. I think that this truck will be a big influence on alot of builders. I know I liked the idea of the independent front suspension in the front VS a solid axle.That idea would make for a killer 2wd trail truck to give it that authentic look.Or a 4wd truck that doesn't use a solid axle on the real truck.But it being in the "Miscellaneous Noncrawler RC's" section will hurt peoples chances of seeing it. Plus there are other rigs in the 1.9 section that aren't crawlers either. But anyway that's just my opinion.
T I N Y is offline   Reply With Quote
Old 04-13-2010, 11:11 AM   #13
Quote:
X2... i think this needs to be moved back to the 1.9 section
ae racer is offline   Reply With Quote
Old 04-13-2010, 05:39 PM   #14
yep thanks guys i totaly agree i was shocked it was moved
please can it be moved back
well for those that see this spred the word of this cool build so atleast people will know that i have not given up on it
Old 04-15-2010, 07:41 PM   #15
4 link brackets made
well my delrin came in so ill be able to make my front arms now
they should be done by monday as well as mounting the rear
Old 04-16-2010, 07:06 PM   #16
lower arms
Old 04-17-2010, 10:45 AM   #17
you could have just drawn the arms in silver...would have been quicker
Gen3_Teg_88 is offline   Reply With Quote
Old 04-17-2010, 06:19 PM   #18
i did but didnt like the way they looked so u colored it silver and strated over
i was being lazy and it was late lol
Old 04-17-2010, 07:20 PM   #19
This is a cool build! I was wondering where you got the material you made your frame out of?
jgb7038 is offline   Reply With Quote
Old 04-17-2010, 08:20 PM   #20
1/2 inch square tube from the hardware store ripped in half on a bandsaw
You may not edit your posts
