Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Loading
Thread: old comp truck turned scale truck
Old 11-09-2010, 08:47 PM   #1
Default old comp truck turned scale truck
A few weeks ago I started to realize i wasn't going to have the Scaler I've been working on done for my local club's next comp plus i was getting burnt out working so hard on it to get it done. When i starting to think of how to cut corners to finish it I realized i needed to take a brake.
Well 2 weeks ago, while i was staring at the scaler, i looked at my old comp truck that i threw together for the last scale comp and thought to myself that the dove nose, dove tail and boat sides Just were not going to cut it for a 1.9 scaler. then it hit me, I'll just cut the front and rear bars holding the fenders on, pull them out, and run the body full width!
For reference here is what it looked like as a 2.2 comp truck
Build thread: Comp tuber
So here it is as it sat for the last scale comp running TLT axles and 1.9 flat irons
First task was to remove all offending body panels
Then i began cutting. Off came the stinger and i pulled the front tubes out
Then i did the same to the back
Here is how it looked at this point
And i did a test fit of the panels
After the test fit i realized the tubes needed to come further apart the fit the hood in so i just cut them off all together and cleaned up the chassis tubes while they were off
And i also decided to move the servo to the chassis
then i re attached the front tubes and added a cross bar
then some supports and test fit the panels again
then onto the back were i reattached the tubing and fitted the panels, bobbed of course
Then added supports, a bumper and welded the down bars to the frame
Then i added a bumper to the front a little different then on the scaler. sort of a mini stinger, and test fit the grill
And a winch of course
Then i added sliders to fit tight under the doors taking place of the rockers
Next i mounted the grill using small tabs
and fitted the rest of the panels
to finish the chassis i added tabs to hold the panels, a spare tire mount, electronics mount and brazed all the joints for a clean finish.
That is how i looked by last weekend and i'm really digging it at this point.
Once the chassis was painted i reassembled it and added the electronics. the box in the back is for the LiPo
Then had to test fit the painted panels
WOW does that look killer!!
Next was the grill. I shaved the back to open up the slots
then made light buckets out of some aluminum using the originals as molds
then i made lenses from the molds i made of the originals
And glued them into the painted grill with lights
I wasn't going to do an interior but i just had to so i whipped out a quick one using some styrene and zip ties
and added a dash using more styrene and some thicker aluminum
i started finishing the panels by gluing the cab sides to the back and mounted the rear fenders with lights as well
and yes the taillights ate the one that will brake. i finally got the plastic figured out. the only down side it they are yellow not clear.
I also added breakable corner lenses up front
and here it is in all it's glory with everything in place.
But you know what, it just doesn't look quite right....
Now this is better!
NOW THAT IS BADAZZZ!!!
Did you ever build a car that surprised you so much that you just can't stop looking at it?
Well here are some more pics including the mandatory flex shot.
I'm in love with this truck all over again!
To top it all off, I ran it this past sunday and WON THE COMP!!
I'll get some carnage pics up soon
Sorry for the long post but i just wanted to get it all on at once since i haven't been on here much lately.
Metal Masher is offline   Reply With Quote
Old 11-09-2010, 09:01 PM   #2
Very nice truck! I love that color and the pro-line tsl's. Very clean looking truck! Is that an all aluminum body? where did you get it?
motostowes is offline   Reply With Quote
Old 11-09-2010, 09:06 PM   #3
Quote:
Yes it's aluminum and i made it. Check out my other thread
Project true scale - Aluminum Toyota body!
Old 11-09-2010, 09:56 PM   #4
It was really cool to see the truck last Sunday, it performed very well. Sorry for breaking the tail light with the Willys..
BigSki is offline   Reply With Quote
Old 11-09-2010, 10:15 PM   #5
Quote:
It was actually my fault! LOL! Hay, how did that turn out on the vid?
Old 11-09-2010, 10:22 PM   #6
Great transformation.
Jeff
jeffho830 is offline   Reply With Quote
Old 11-09-2010, 11:00 PM   #7
Suck it up!
Duuuuuuuude's Avatar
Very nice. Be sure and post pics after its been beat on.
Duuuuuuuude is offline   Reply With Quote
Old 11-09-2010, 11:09 PM   #8
so awesome... cant wait for pics and vid.. i hope the vid is as awesome as the willys first comp vid.
ae racer is offline   Reply With Quote
Old 11-09-2010, 11:25 PM   #9
Amazing work as always!
Looking forward to seeing the carnage pictures.
Rogue is offline   Reply With Quote
Old 11-10-2010, 12:10 AM   #10
4RunnerKid's Avatar
that thing is BADASS.
i really need to pick up one of those alum. bodies...
4RunnerKid is offline   Reply With Quote
Old 11-10-2010, 01:08 PM   #11
Wow that is a sweet looking hilux you have their. you do some very nice work on your trucks
crawler-king is offline   Reply With Quote
Old 11-10-2010, 04:09 PM   #12
photos dpnt do this truck justice. you have to see it in person. its sweet.
still love the breaking taillights.
PontiacGT201 is offline   Reply With Quote
Old 11-10-2010, 04:20 PM   #13
Awesome rig!! I love the cage work...as well as being aluminum to see the damge!! I wish I had the skill that of the guys on this site! Great work
Let's see the dents!
blakeski is offline   Reply With Quote
Old 11-10-2010, 05:42 PM   #14
WOW - That rig really turned out AWESOME..!!! Great job..! Can't wait to see some of the pics and video with some "trail damage"..!!
51WillysJeep is offline   Reply With Quote
Old 11-10-2010, 06:34 PM   #15
Wow! you have some serious metal mashing skills!
Old 11-10-2010, 08:57 PM   #16
heres some of the carnage from the scaler meet
he has alot better damage photos then I do.
Old 11-11-2010, 09:18 AM   #17
I thought you saw my post on the shout box- the vid stopped after about 15 minutes, can't figure out why. Then after I reviewed the vid, I forgot to save it in a file, so when I unplugged the GoPro from my lap top, the vid got erased. I had already cleared the SD card in the camera before I realized that I didn't save the vid in a file, so it's all lost. We need to get together and just go for a trail ride one day and shoot video with the GoPro and your camera and piece together a video.
Old 11-11-2010, 10:49 AM   #18
The ultimate ,real metal scale rockrash and panel damage.
I love it.
vipxj is offline   Reply With Quote
Old 11-11-2010, 07:55 PM   #19
I joined the Band!
this is a killer truck I bet you are glad its not a 2.2 comp truck anymore
bayareaaxial is offline   Reply With Quote
Old 11-11-2010, 08:23 PM   #20
Thanks guys for the kind replies!
PM me
I think that's my favorite part as well!
Quote:
The vid isn't as good as the willys but good enough to post up when it's done.
A little anxious are we?!!! LOL!
Aw man that stinks! o well i guess that means we need to do it again!
Ok before i post the carnage pics i want to show some more poser shots.
A close-up of the paint
And my favorate
Now pics from the comp
First course
and the damage from the first course
course 2
damage after the second course
And a clear show of the real broken tail light!
now the hill climb
rolled it over the second time i went up trying to get some good vid
Then went out on a trail run after the comp and carnage ensued!
Now started the process of repairing the damage.
The passenger side came out pretty good
but the drivers door was just too far gone to keep
so i pulled the old one off
And made a trip to the junk yard to get another door
Finally i straightened the rear quarters
and put some new tail lights in that i picked up while in the junk yard.
Now I'm ready for some more wheeling!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/280059-old-comp-truck-turned-scale-truck.html
Posted By For Type Date
Зарубежные проекты 1.9 - Страница 4 This thread Refback 10-05-2011 03:36 AM
You may not edit your posts
