#1 |
![]() Join Date: Aug 2005
I've been wanting to work on this for a long time and reciently got the motovation to start.
The goal is to make an RC car that is as scale as possible, in every aspect, with a super secret body This truck will kind of be a rolling test platform for another 2 trucks i will eventually build so to start I'm going to use a Mountaineer chassis I bought new 10 years ago ![]() For the hard chassis fans out there, i'm not going to cut or weld to the frame in any way To keep the scale appearence i'm sticking with the original axles ![]() One of my pet peeves is the difference in axle width but with the body that's going on it, it won't be that notacible. I was originally going to use 2.2 tires but after Measuring my 1/18 Nylint tires I realised they were exactly 1/10 scale 35's so to bring the whole shabang down to a respectable level I placed the axles above the springs ![]() ![]() Yes the pumkin is on the wrong side but you'll see why later ![]() The tires are just sitting on the bare axles but the proportions are what i was shooting for. More progress to come Last edited by Metal Masher; 08-04-2007 at 08:53 PM. |
| Sponsored Links | |
#2 |
that looks really good. I like the nylint tires on there, real scale looking. I will be watching this one for sure!
#3 |
Axial Team Driver
![]() Join Date: Feb 2005
The tires may be 35's in 1/10th scale, but the bruiser/mountaineer frame and axles are actually larger than 1/10th scale. Not exactly sure how much but I know 1bjb knows. Where is he at?
Good luck with the build! I with I had a set of those axles |
#4 |
Looks good. Stock toy diffs are driver drop aren't they? If you were super anal retentive you could cut the rear axle and shorten it, but different backspacing on the rear rims would probably do the same thing.
__________________
http://www.gotmuddy.com bizatches |
#5 |
Toys are pass-drop, wranglers are driver. Hmm...
#6 |
![]() Join Date: Oct 2006
nice frame can't wait for your neat paint job on the "secret body"
__________________
That's Mr.Lawyer to you. Last edited by ThinkTank; 11-04-2006 at 10:51 PM. |
#7 |
Wrecker Fab
![]() Join Date: Nov 2005
Huh, "Secret body", sounds interesting. It will be nice to see a build that is scale in every aspect, you don't see that much. Should be sweet.
__________________
#8 | |
Quote:
#9 | |
Quote:
I've already thought of that and the housing would not need modifing, just the outer bearing carrier and the axle shaft itself. I've already got something it the works for that. I have a good solution for running 2.2's and using backspacing that i'll explain later. |
#10 | |
#11 |
oops! :?
#12 |
Looks like a great start, gotta love those Bruiser chassis. I just have a question about the nylint tires you have there, are both the outer and inner diameter for the wheel openings the same? I always wondered because of the big dish in the back of the wheel.
#13 | |
Wrecker Fab
Quote:
__________________
#14 |
nice
#15 | |
Quote:
#16 |
Well I took the chassis over to my garage to start on the cage.
Since I didn't want to damage the frame I decided to incorporate the skid plate into a means to support the rest of the cage. I started by plazing some rough pieces. Man I love plasma cutters! ![]() The main plate is pretty heavy at .120 thick and the sides are .060. Once they were cleaned and shaped to fit the chassis... ![]() They were welded... ![]() then the welds were ground smooth and tested once again for fit.
#17 |
You can see how the sides wrap around the frame to give the sliders something to attach to
![]() Seems to work pretty good ![]() Well time to hit the sack. More to come later. |
#18 |
TOKEN BLACK GUY
![]() Join Date: Dec 2005
Must be nice to have all that equipment man,The skid looks awesome.
__________________
CRAWLERS SUCK. |
#19 |
are you in hanover pa???? if you are we need to get together and crawl
#20 |
they way you built that skid plate is a work of beauty! This is going to be an awesome rig. I cant wait to see the final product.
| Thread Tools | |
| Display Modes | |
