12-22-2006, 03:48 PM | #1 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
| Step by Step Servo Reversing
If you are like me and run multiple rigs of of one tx and don't have model memory or you simple need to reverse a servo than here is a step by step servo reversing procedure. I hope this comes in handy.
Sponsored Links | |
12-22-2006, 04:51 PM | #2 |
Pebble Pounder Join Date: Aug 2006 Location: Emporia
Thats a great post. Wish I would have known that at least one fried servo ago |
12-22-2006, 06:04 PM | #3 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
wish i thought of that before i brought the reverse y- harness heck i even cut the servo wires to reverse them only to fry the bec out:-( good tip kamikaze |
06-15-2008, 11:18 PM | #4 |
Newbie Join Date: Jun 2008 Location: California
What about when the motor is solder directly to the circuit board?
06-16-2008, 08:23 PM | #5 |
Sol...........
06-17-2008, 12:23 PM | #6 |
Rock Stacker Join Date: Jun 2008 Location: Eureka
thanks works perfectly
11-08-2008, 03:00 PM | #7 |
Newbie Join Date: Nov 2007 Location: Iceland
11-09-2008, 09:58 AM | #8 |
Pebble Pounder Join Date: Oct 2008 Location: Bartlett/ Memphis
Whats this for? does it let you use a 2 chnl controller and yet still turn front and back wheels? I aint real sure about this. well not your post but im confused. i want to run rear steer as well. and i was thinking i need a 3 chnl controller? and i was also thinking why can't i use a 2chnl controller and just splice into the same cable feeding the front steer? |
11-09-2008, 10:09 AM | #9 | |
TEAM MODERATOR Join Date: May 2004 Location: Tennessee
| Quote:
If all you want to do is run rear steer,this ain't for you. If all you got is a 2 channel radio,your kindly stuck with full time four wheel steering. A simple Y-harness will fix you up. There's a few good options here....Holmes Hobbies. Your pretty limited with a 2 channel radio. Minimum needed for a crawler is a 3 channel. | |
11-09-2008, 11:06 AM | #10 | |
| Quote:
ah ok, cool thanks for the tip. i hadn't bought a crawler yet, but these are the questions i need answered before i jump in and buy the wrong stuff. Thanks for the info. i'll stick with looking for a 3 channel radio setup then. i will also later want to do the "dig" i have read about as well. | |
11-09-2008, 11:39 AM | #11 |
Quarry Creeper Join Date: Jul 2007 Location: 517
Untrue raptorman, you can get by with 2 channels. Dig and/or rear steer is amazing to have though... by amazing I mean almost required |
11-11-2008, 08:57 AM | #12 | ||
Quarry Creeper Join Date: Aug 2008 Location: UK
| Quote:
I have an old Techniplus AM radio with no reversing switches, and I wanted to let my sister use it on a car I've built for her. Currently, the steering goes the wrong way compared to the stick movement on the radio, so i'm going to try this idea on it. Quote:
If you can get your head around controlling the front and rear steering independently, you have the option of crabbing and tight turns. Haha look at me trying to be all knowledgeable. | ||
11-11-2008, 03:04 PM | #13 |
ha ha, I will take all the help i can get. i'm learning, asking and reading at the same time. Thanks, Howard |
08-21-2009, 07:50 PM | #14 |
Newbie Join Date: Jul 2009 Location: plainfield,vt
thats great to know thanx
08-21-2009, 08:29 PM | #15 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Wow There is no way I would be game enough to do that Nice write up though It is sure to help someone. Kieren |
10-30-2009, 02:17 AM | #16 |
Newbie Join Date: Oct 2009 Location: Boise
If anybody else is tired of the flimsy setup for the rear stear on their duratrax cc this little mod would help eliminate that useless spacer and allow them to set up the rear servo exactly like the front one, and greatly improve the angle and effectiveness of the 4 wheel steer! Great post!
10-30-2009, 07:10 AM | #17 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
Nice help....Never needed it because I run digital and can just reverse the servo from the radio, but it will most definetely help those that don't have servo reversing. Love the detailed pics.
02-24-2010, 08:13 PM | #18 |
Newbie Join Date: Oct 2009 Location: Delta B.C.
I have a Hi-Tec645mg and i want to do this. The wires are different on mine than this one can any one tell me which ones on mine to change? |
02-24-2010, 10:58 PM | #19 |
Newbie Join Date: Feb 2010 Location: Prairieville
this is a great tip!!!! im going to use this in planes and all kind of stuff. no more reversing servo y harnesses. sometimes this is your only option to make a clean setup without buying a new radio just cause some dude said you dont have a good enough rig....... if anything its a great chunk of knowledge that every1 should have Last edited by sudden_scaler; 02-24-2010 at 11:00 PM. |
02-24-2010, 11:17 PM | #20 |
the 2 of the 3 wires on the pcb that you swap go to a potentiometer in accordance to the board in the pic you provided. so if you can access the potentiometer swap the 2 outer wires, then swap the motor wires.... right kamikaze??
