Go Back   RCCrawler Forums > RCCrawler General Tech > General Crawlers
Loading
Thread: Members' Rides - No talking
Old 02-09-2005, 10:12 PM   #1
Colt Python/SR9c
TwistedCreations's Avatar
My Old Crawler
Truck Base :Emaxx
ESC: EVX (mod done)
Motor(s): 1 Lathe motor(Titan pictured )
Servo(s): Airtronics 200oz ( Front) Hobbico CS-70 ( rear)
Trans: Emaxx locked into 1st
Axles: Maxx Hybrid Axles
Tires: BFT's
WB: 15:5"
Overall Width: 16"
Diff clearance: 4"
Center Chassis clearance: 5.25"
Overall height: 12.5"
It's time to post up your rides and keep them all in one spot so others can view them and help give ideas.DO NOT post pictures of projects torn in pieces,they need to be driving and in one piece.Have at least one picture with the body on and not a bunch of chassis shots.Only post up 1-2 pics and answer the following questions( if you guys want to add another question,LMK ) if there is more than the 1-2 pics and the info requested, it will be deleted. Pics that DO NOT work( due to the host), will also be deleted.If you see something in the pics and want more info, please PM that person and ask. This will keep all the BSing to a minimum.
answer the following ( copy and paste if ya want)
Truck Base :
ESC:
Motor(s):
Servo(s):
Trans:
Axles:
Tires:
WB:
Overall Width:
Diff clearance:
Overall height:
Posting for Ryan (Bhamb2)
Base: clod
E.S.C. super rooster
motors: stock
Servos: crap
Trans:n.a.
Axles: clod
Tires:clod
W.B. 13"
Width: 15.5"
Diff clearence:2"
Center chassis clearence:4
Overall hight: 12
Truck Base : Maxx
ESC: Super Rooster
Motor(s): GD600 w/ a Johnson 27t motor
Servo(s): Cs-70's F&R
Trans: Maxx locked into 1st
Axles: Hybrid Maxx axles
Tires: LST's on narrowed stock maxx rims
WB: 17"
Overall Width: 16"
Diff clearance: 4.5"
Center Chassis clearance: 5.5"
Overall height: 12"
Overall weight: 8lbs.
The newest truck from Twisted Creations
Owner: Rufies97XJ
Truck Base : Emaxx
ESC: SR
Motor(s): Reversed MM motor with GD600
Servo(s):CS-70 in the front and Bluebird 630 in the rear
Axles: Custom Maxx axles
Tires: LST's on narrowed Hot Bodies rims
WB: 16 1/2"
Overall Width: 15 1/2"
Diff clearance: 4 1/2"
Center Chassis clearance: 5 3/4"
Overall height: 11"
Overall weight: 8 lbs.
Truck Base : Maxx
ESC: SR
Motor(s): MM w/ a GD600
Servo(s): Airtronics 359's
Axles: Maxx hybrid
Tires: Moabs
WB: 16.5"
Overall Width: 16 3/4"
Center Chassis clearance: 5 1/4"
Overall height: 11"
TwistedCreations is offline   Reply With Quote
Old 02-09-2005, 10:43 PM   #2
Default Rig stats
Here's my fullsize rig/scale rig
Truck Base : TXT / TLT x2
ESC: Rooster/ ditto x2
Servo(s): 645 /S3305 Fut. x2
Trans: TXT with GD600 @ 2.5:1 & 9t / pede, Lathe motor x2
Axles: TXT JB welded / TLT JB welded x2
Tires: Cut BFT's on TXT narrowed wheels / Moabs on Duratrax ST's x2
WB: 15 3/4" / 12" & 12 1/2"
Overall Width: 14 3/4" / 10 1/4"
Diff clearance: 2" / 1 3/8"
Center Chassis clearance: 4" / 3"
Overall height: 10" / 9"
rckjeep is offline   Reply With Quote
Old 02-09-2005, 11:05 PM   #3
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
ROKCLOD 9
Truck Base : Clod, custom aluminum chassis
ESC: Super Rooster
Servo(s): Hitec 5995 front and 5645 rear
Trans: Hey....it's a clod
Axles: Clod, locked, lathe motors
Tires: Giant Trac/Cut Juggs
WB: 16 inches
Center Chassis clearance: ~4.5 to 5 inches
Overall height: ~ 9 inches
roktoy is offline   Reply With Quote
Old 02-10-2005, 02:53 AM   #4
2006 2.2 National Champ
BENDER's Avatar
ROCTAPUS
Truck Base : TXT-1
ESC: Super Rooster
Motor(s): Integy 55t lathe
Servo(s): 2 digital Hitec 945mg's
Trans: TXT w/ GD-600
Axles: TXT w/ JB Welded diffs
Tires: Moabs on narrowed Outbacks
WB: 16 3/4"
Overall Width: 15"
Diff clearance: 2 1/4"
Overall height: 9 5/8"
BENDER is offline   Reply With Quote
Old 02-10-2005, 02:42 PM   #5
Truck Base : Clod/ESP Chassis
ESC: Super Rooster
Motor(s): 2 Integy 55t
Servo(s): 2 JR Z650M
Trans: JB weld Locked gears
Axles: Clod plastic
Tires: Moabs on narrowed 40's
WB: 16 1/4
Overall Width: 15
Center Chassis clearance: 4 1/2
Overall height: 11 1/2 with body
MIDGET
kwj48 is offline   Reply With Quote
Old 02-16-2005, 08:14 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
The SuperDuke
Truck Base : El Diablo Chassis
ESC: Super Roostah'
Servo(s): Hitec HS5645MG front / Hitec HS5945MG rear
Trans: Dont need no stinkin trans 9T/8T front/rear pinions
Axles: Clod with Shoe Goo lockers
Tires: IMEX JumboMaxx Swamp Dawgs or Custom Savage
WB: 16.25"
Overall Width: 13.75"?
Diff clearance: 2.125" (Shaved axles)
Center Chassis clearance: 4.25"
Overall height: 10"?
Grizzly4x4 is offline   Reply With Quote
Old 02-16-2005, 08:55 PM   #7
Talking my updated TLT-10
Truck Base : Tamiya TLT-1
ESC:Mtroniks RV15
Motor(s): P2K pro
Servo(s): traxxas high torque
Trans: stock tlt-1 ( w/ 4-tec diff )
Axles: TLT-1
Tires: proline masher 2000 stampede front wheels ( narrowed to inside beads )
WB: 11 1/2 in
Overall Width: 9 1/2 in
Diff clearance: 1 1/2 in
Center Chassis clearance: 3 1/4 in
Overall height: 11 1/4 in
Nish is offline   Reply With Quote
Old 02-17-2005, 07:38 AM   #8
Adilynsdad too!
braceysdad's Avatar
Heres mine left to right:
Base: Boyer TXT Boyer Clod Boyer Clod
ESC: Super Rooster on all
Servos: FR 5995/ RR 5645 on all
Motor: 1-55t 2-MM 2-55t
Trans: E-maxx Clod Clod
Axles: TXT w/gd600 Clod w/ ttr Clod
Tires: LST LST Moabs
WB: 15.5 17.5 16
Width: 15.5 16 16
Diff: 2 2.5 2.5
Center: 4 4 5
Height: 10 10 11.5
braceysdad is offline   Reply With Quote
Old 02-22-2005, 10:53 AM   #9
Here's mine:
Truck Base: Clod
Chassis: Gecko
ESC: Super Rooster
Motors: Stock with 9 tooth pinions
Servos: Front, Hobbico cs-71 Rear, Futaba S3003
Axles: Clod
Rims: Stock Clod narrowed with RC Alloys LST Ring adaptors
Tires: LST'S
WB: 14"
Overall Width: 15"
Diff Clearance: 2"
Center Chassis clearance: 3 5/8"
Overall Height: 11"
Motor Mounts: ClodMod Racing
Body: CJ8
Mike
Mikey007 is offline   Reply With Quote
Old 03-12-2005, 08:33 PM   #10
Truck Base : Clodbuster
Chassis: Home built 3/16 square steel, fully welded. Sheet metal skidplate underneath.
ESC: Novak Rooster
Servo(s): Front Bluebird BMS-630MG, rear Associated S2002, both with Kimb. servo savers
Rx pack: 5 AA Nimh 1600mah cells strapped to front upper links
Trans: n/a
Axles: Clodbuster
Shocks: Aluminum Maxx shocks with Trinity HD springs mounted at all 4 corners
Tires: Losi LST on reversed tmaxx wheels
WB: 18"
Overall Width: 24", from servo to servo
Diff clearance: ~2.5"
Center Chassis clearance: ~4.75"
Overall height: 11.25"
AdamF is offline   Reply With Quote
Old 03-13-2005, 05:52 PM   #11
Thumbs up e-maxx
Truck Base : e-maxx :-(
ESC: stock 14.4v novak
Motor(s): twin 550 titans
Servo(s):1 traxxas 2055 and 1 airtronics double ball bearing aliminum 200 oz
Trans:stock
Axles:stock a-amrs with hotbodies steal axels
Tires:hot bodies death grip
WB:16 3/4"
Overall Width:16"
Diff clearance:3.5''
Center Chassis clearance:5''
Overall height:12.5'' with land cruser body
rockspaz is offline   Reply With Quote
Old 03-28-2005, 03:05 PM   #12
My tlt hummer
Truck Base : tlt
ESC: rooster
Motor(s): mag mauhem
Servo(s): hpi 2
Trans: e maxx
Axles: tlt
Tires: Masher 2000's
WB: 13
Overall Width: 10 1/2
Center Chassis clearance: 2 3/4
Overall height: 9 1/2 w/body on
sean_lv_crawler is offline   Reply With Quote
Old 04-07-2005, 03:31 PM   #13
Bergsteiger:
Truck Base : Clod
ESC: Novak Super Rooster
Motor(s): Johnson 550's
Servo(s): Hitec HS645MG's
Trans:
Axles: clod locked with shoe goo
Tires: Proline Moab 40 series
WB: 16"
Overall Width: 16-1/4"
Diff clearance: 3"
Center Chassis clearance: 5"
Overall height: 12"
camel_rc is offline   Reply With Quote
Old 04-09-2005, 01:33 PM   #14
Location: Driving the Troysion Stick up the BIG BOY line!
Default Here's Cheajeep and Cheapjeep Jr.
Cheapjeep
Truck Base : TXT
ESC: Super Rooster
Motor(s):Integy 55t Lathe
Servo(s): Hi-tec HS-5645MG
Trans: TXT with GD600 and revo shafts. 129:1 approx ration
Axles: Locked TXT
Tires: LSTs on narrowed TXT wheels with RC Alloy bead locks
WB: 15 5/8"
Overall Width: 15.5" lug to lug
Center Chassis clearance: 4 1/4"
Overall height: 10 3/8"
Cheapjeep Jr.
Truck Base : TLT-10
ESC: Super Rooster
Trans: Stampede with Metal Idler gear. Locked with JB Weld
Axles: Locked TLT with INETRC wideners
Tires: Imex 2.2 Swap Dawgs on Stampede wheels with RCKJEEP lock rings.
WB: 12.5"
Overall Width: ?
Diff clearance: ?"
Center Chassis clearance: ?
Overall height: ?
More pics http://www.geocities.com/cheapjeep2/RCCrawler/
cheapjeep2 is offline   Reply With Quote
Old 04-14-2005, 07:59 PM   #15
thefordmccord's Avatar
Truck Base : TLT-1
ESC: LRP Runner
Motor(s): 27T Integy
Servo(s): HS-5645mg Front and Rear
Trans: Stampede
Axles: TLT Locked front and rear with JB Weld
Tires: Proline-Masher 2000
WB: 12.5"
Overall Width: 11.25"
Center Chassis clearance: 3.25"
thefordmccord is offline   Reply With Quote
Old 05-15-2005, 05:38 AM   #16
I`m sure most here have seen my trucks but thought I`d get in on this post anyway.
The Savage
Truck Base : Savage
ESC: Super Rooster
Motor(s):Integy Lathe
Servo(s): HiTec 645MG
Trans: Pede
Axles: Savage (locked and 4 linked )
Tires: Pro-Line Moabs
WB: 16"
Overall Width: 16 3/4 "
Diff clearance: 4"
Center Chassis clearance:4 1/4"
Overall height: 10 3/4 "
________________________________
Overkill 2
Truck Base :RC Rock Gear Chassis
ESC:Super Rooster
Motor(s):MM with MP Jet Reduction
Servo(s): Hobbico 1/4 Scale Frt/Rear
Trans: E-Maxx
Axles: X-Factor
Tires: Narrowed Kongs
WB: 17"
Overall Width:16.5"
Diff clearance: 2.75"
Overall height: 11.5"
And I can`t forget the original Overkill.
4XADICT is offline   Reply With Quote
Old 07-10-2005, 07:21 PM   #17
heres my new one
Truck Base : TXT-1
ESC: Super Chicken
Motor(s): Integy 55T lathe (gd600
Servo(s):JR
Trans:TXT
Axles:TXT
Tires:Imex jumbo swampers maximizer beadlocks
WB: 15 3/4 "
Overall Width: 22"
Diff clearance: 2"
Overall height: 11"
Old 07-26-2005, 10:12 PM   #18
My TXT
Old 08-01-2005, 03:25 AM   #19
*Keeps bs low*
Truck Base : TLT
ESC: IntelliSpeed 12t
Motor(s):Mag Mayhem
Servo(s): Hitec 945.. LOL
Trans: Stampede
Axles:TLT
Tires:Masher 2k's
WB:13 "
Overall Width:
Diff clearance: Half Fist?
Center Chassis clearance: Fist and a bit?
lunardaisy is offline   Reply With Quote
Old 08-04-2005, 01:06 AM   #20
here's mine
Truck Base: utrcrc v-prime clod
Motors: Integry 55t lathes (x2)
Servos: Hi-tec 5645mg (x2)
Axles: clod with r/c guy 4ws kit
Tires: commando bead-locks narrowed 3/4" with moabs and Benders adaptors
WB: 15 7/8"
Overall Width: 14"
Diff. Clearance: 2 1/8"
Center Chassis Clearance: 6"
Overall Height: 12 1/4"
Thanks for all the great parts guys and thanks crawler store for the axles and the tq3
dorji is offline   Reply With Quote
Members' Rides - No talking - Similar Threads
What the #$%#$#@ are ya talking about? Paul58 Newbie General 10 01-13-2013 04:40 PM
Anybody know what im talking about?! shadowrejects Chit Chat 2 05-14-2010 06:26 AM
members 1.1 rides? SaVaGe MaN SS Chit Chat 4 03-28-2008 02:48 PM
You may not edit your posts
