04-30-2017, 08:33 PM | #1 |
Newbie Join Date: Apr 2017 Location: Eagle
| What does it mean to overdrive the front axle?
I read about people overdriving or underdriving one of the axles?
Sponsored Links | |
04-30-2017, 08:34 PM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Re: Hat does it mean to overdrive the front axle?
The front wheels spin faster than the rear. It helps significantly with climbing and in my opinion turning. Sent from my Pixel XL using Tapatalk |
04-30-2017, 09:43 PM | #3 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
| Re: What does it mean to overdrive the front axle?
From what I've read here as far as the SCX10.2 is concerned, it means to drive the front axles faster until the cheapo aftermarket Xtraspeed gears explode.
04-30-2017, 11:09 PM | #4 |
Pebble Pounder Join Date: Jan 2014 Location: Eugene
Here is an example of overdrive underdrive. You see the shaft from the transmission is going into the transfer case and directly into the rear axle keeping that stock axial drive. The transfer case then gears up to 1.47:1 and shoots the driveshaft to the front axle. This means for every 1 rotation of the front tires, the rear goes about 3/4 of a rotation. As stated above, helps with climbs and steering quite a bit. Or as also stated, get the xtraspeed 1 piece spool overdrive gear and watch it strip. Im sure it will work really well once or twice! |
05-01-2017, 09:22 AM | #5 |
I run the Toyzuki V2 setup which I believe is a 31% overdrive? All I know is I love it. No Xtra speed junk gears for me. Sent from my Pixel XL using Tapatalk |
05-01-2017, 10:01 AM | #6 |
I wanna be Dave Join Date: Jun 2016 Location: Deep in the Everglades
Or the rears are slower by underdrive on them.... Reason for either is to let the rear follow rather than pushing Hang up and Drive |
What does it mean to overdrive the front axle? - Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
SCX10 front overdrive | Ssendam | Axial SCX-10 | 19 | 12-16-2014 03:40 PM |
Overdrive Front Poblems | The-Blacksheep | Axial SCX-10 | 10 | 03-15-2012 06:35 PM |
XR10 Overdrive front axle? | spunkysandoval | Axial XR10 | 7 | 10-11-2011 03:16 PM |
