Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Loading
Thread: Tranny Guide
Old 04-05-2007, 09:22 AM   #101
dezfan's Avatar
Quote:
Originally Posted by SnailMail View Post
what about WK tranny? it is small and light... just rotate the motot plate for even lower CG
I didn't include the WK tranny as It was still very new when this was written and I hadn't seen one used.
I may as it as some point as I'm sure new trannys will come out that we can use in our crawlers.
dezfan is offline   Reply With Quote
Old 04-06-2007, 07:16 PM   #102
Quote:
Originally Posted by SMFtwstdHICK View Post
I got a pede tranny as well. I don't think I am going to be able to use it cause of it's size. Too big and may interefere with the seats/interior. May have to check into the Stealth tranny. Great thread , thanks.
Just to let you know bout what I did to my pede........
I chopped it to ****............grinded the heck out of it and after it was a lot smaller than originally.....Hope that helps.....
dremels rule...
5150bronco is offline   Reply With Quote
Old 04-06-2007, 07:21 PM   #103
Yeah, there's a lot you can shave off a pede tranny. 5150bronco, you should post a pic of your tranny for an example.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 04-06-2007, 10:41 PM   #104
Yeah, 5150, do you have a pic of it? No worries if ya don't, that was my next move. Just dremel the hell out of it. I think I can set it up to where my center console covers it.
SMFtwstdHICK is offline   Reply With Quote
Old 04-07-2007, 08:50 AM   #105
Just so the guide is historically correct......the Stealth tranny was nothing but a copy of the MIP 3 gear tranny, that was out a good two years before the Stealth Tranny made its debut at the 1989 Worlds in the original Stealth prototype car.
So the basis of all 3 gear trannys is the MIP.....not the Stealth.
Later EddieO
EddieO is offline   Reply With Quote
Old 04-07-2007, 09:14 AM   #106
for those looking to use a xxxt tranny i found these xx drive cups that you can hook right up to maxx yokes and on the axle side i used the stock tlt drive cup and mounted them to the maxx yoke. here are some pics.
shrek is offline   Reply With Quote
Old 04-12-2007, 09:17 AM   #107
Web Wheeling
Etype R's Avatar
Here is a complete R2 gear ratio list I came up with last night.
8 = 30.38:1
9 = 27:1
10 = 24.3:1
11 = 22.09:1
12 = 20.25:1
13 = 18.69:1
14 = 17.36:1
15 = 16.2:1
16 = 15.19:1
17 = 14.29:1
18 = 13.5:1
19 = 12.79:1
20 = 12.15:1
Etype R is offline   Reply With Quote
Old 04-24-2007, 04:47 PM   #108
Anyone here know if I can replace the stock TLT tranny with the R2 tranny on the stock TLT chassis? If not, what modification I need to make to make the R2 tranny works with the stock TLT chassis? Thanks for any info.
Jeff
jeffho830 is offline   Reply With Quote
Old 04-24-2007, 11:16 PM   #109
You can, but it's not a great idea, if your going that cool with the tranny, pay an extra $50 and get a vertical Smile from Double J or something and make a nice crawler. A chassis makes a world of difference.
Rob92k1500 is offline   Reply With Quote
Old 04-24-2007, 11:17 PM   #110
Quote:
Don't you mean xx drive cups for a xx, and xxx for xxx????
If you go on Losi's site, they list "Molded Outdrives" for a XX, and another set for the XXX....
I have a BK XX CR tranny and have XX outdrives...
Old 04-25-2007, 11:44 AM   #111
Quote:
Hey, I dont have a pic, just trying to figure out how to post a pic since I dont have a star....but what I can say is I shaved and cut everything off that I could...........Everything! Then grind it down so it is smooth and thin.....
It is still a pede, but it is significantly smaller and so it works for me....
Good luck choppin away
Old 04-30-2007, 06:52 PM   #112
Default TowerHobbies
so is it possible to order all the parts for a Stealth tranny from lets say towerhobbies? I found an RC10 t3 tranny, would that be a good one to use?
pc6uru is offline   Reply With Quote
Old 04-30-2007, 06:54 PM   #113
dezfan's Avatar
Quote:
The T3 will work fine, the T4 is better though.
Old 04-30-2007, 10:24 PM   #114
Hell, I have a buddy who just built his first TLT using an old Ultima Tranny, works AWESOME. but it's a little wierd with the 3 outside gears in addition to the internal ones.
Strang setup. But it works.
Old 05-14-2007, 01:15 PM   #115
Anyone Try Using A Evader Tranny. I Dont Know How To Connected My Shaft To The Tranny
KENNYKILLER14 is offline   Reply With Quote
Old 05-14-2007, 09:16 PM   #116
dezfan's Avatar
Yes, they Evader tranny has been used successfully in a crawler.
Mounting a drive shaft to the Evader tranny should be similar to the Stealth and Losi tranny.
Old 05-16-2007, 05:28 AM   #117
on the pede tranny i try too put one of the planetary gears between the other two as noted, be i could not close the diff case. so is there any more info about this
malibu 81 is offline   Reply With Quote
Old 05-16-2007, 05:57 AM   #118
I have been running a evader tranny in my tlt for about 5 months now,using revo shafts and lock the ball diff and lock the slipper down tight,no problem so far. I am running also a 93 tooth 48 pitch spur gear with a 15 tooth pinion its close to rubbing the drive shaft but it will work.
fomoco is offline   Reply With Quote
Old 05-19-2007, 03:20 AM   #119
Quote:
Sure use search button: looking for stampede locking.
ak73 pro a is offline   Reply With Quote
Old 05-20-2007, 08:02 AM   #120
Default stampede\rustler
i have one of the newer rustlers(xl-5) and was planning on using the tranny out of it but i mocked it up and just doesnt fit right i started looking around at the rest of the tlts and noticed that the old tranny from the stampede is a lot smaller will my rustler tranny fit or would it be easier to find a stampede tranny can the insides be swaped out as far as the gears
terrongregg is offline   Reply With Quote
You may not edit your posts
HTML code is Off
