05-24-2007, 07:50 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Alumatruggy
Started a new off-road truggy . the last one turned out pretty good but too heavy so this ones all aluminum welded up. he scale on this one is also much closer than the last. I will be using a tlt rear axle and custom front suspension all hand made in the shop. i am also goingto try a direct drive setup with a brushless outrunner.
Sponsored Links | |
05-24-2007, 08:33 PM | #2 |
Quarry Creeper Join Date: Dec 2006 Location: Bozeman
looks like its going to be a great build |
05-24-2007, 08:48 PM | #3 |
Quarry Creeper Join Date: Jul 2006 Location: Look outside your window 0.0
You've got my attention.......great work so far |
05-24-2007, 09:05 PM | #4 |
~THE SCALE SHOP~ Join Date: Apr 2006 Location: KILLEEN TX
trophy/corr/prerunner truck...ill be watching this one for SURE
05-24-2007, 09:13 PM | #5 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
good start how did you weld it i didnt know it was possable to weld then again i dont know a lot |
05-24-2007, 11:14 PM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
05-25-2007, 09:15 AM | #7 |
Quarry Creeper Join Date: Mar 2007 Location: northern utah
I doubt it was a mig, most migs only do steel and even with the kit to do alum. they suck! I'd say a tig and they're TOUGH! Anyways... sweet build man, that's a pretty clean frame!
05-25-2007, 10:20 AM | #8 |
Got a little more doe all i need is shock mounts and thee rear susp is done
05-25-2007, 10:23 AM | #9 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
what are the lick tyres off? btw nice tuber so far
05-25-2007, 10:26 AM | #10 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
WTF?? man, you ought to work on the shock mounting a little it would look much better moving the shocks back onto to the axle which should lower the upper mount to about the top of the frame. your not mounting the shocks sticking way up like that are you?? its a great looking frame you got, i think the shocks like that would just funk it up. Last edited by Thorsteenster; 05-25-2007 at 10:30 AM. |
05-25-2007, 10:36 AM | #11 |
Adilynsdad too! Join Date: May 2004 Location: G ville
VERY cool looking so far. What's the weight?
05-25-2007, 11:01 AM | #12 |
the top off the shocks will be mounted bleow the top of the frame dont worry..The chassis weighs about a half pound right now but i got to get out my better scake that weighs in grams to get a closer number. The slicks are from a 1/8 scale gas powered go kart that Kyosho made in the early 90's i think.
05-25-2007, 11:11 AM | #13 |
Quarry Creeper Join Date: Dec 2005 Location: los alamitos
lookin' good.. what are the trailing arms made of? kinda looks like aluminum c channel. i was thinking of using that myself, but the teflons haven't broken yet, and if ain't broke.... i would suggest putting the shocks in the trailing arms, in line with the ball ends. if they're gonna stay off to the side like that, they will cause the arms to rotate, and possibly bind...if they are just there for mock ups, ignore that last sentence! |
05-25-2007, 11:40 AM | #14 |
the rear arms are 1/4" in thick solid aluminum milled down the shocks will probably stay there not sure yet but i am concerned with trying to rotate the trailing arm so i milled a pocket were the shocks mount to try to get them on center of the arm... will see how they work.
05-25-2007, 02:43 PM | #15 |
Pebble Pounder Join Date: Aug 2004 Location: Redondo Beach
Very nice! Are you trying to replicate any particular Class 1's?
05-25-2007, 03:09 PM | #16 |
i think your gonna find the savage shocks to be TOO long. ive been down that road before. may try cen shocks i think there around 5 to 5.5" or a set of runnin2jeeps 120mm shocks |
05-26-2007, 03:25 PM | #17 |
The rear is done . I am going to try the Savage shocks but may go with a shorter one later. I also made a nifty little axle mount for the four link . The battery is only there for a little pre load on the suspension . I will get a better place for it before its done. Right now the rear suspension cycles 4.750" but probably put some straps on it to get more like 3 or 3.5" before its done.
05-26-2007, 03:34 PM | #18 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
if the savage shocks are to big, try the WK shocks, same look but a hair shorter |
05-27-2007, 08:02 AM | #19 |
Its almost a roller . I am using some old school RC10 front arms for now but they seem to work well in this setup but i still might make some longer custom arms later. There is no steering setup yet I will be working on that next. The rear shocks are a little long but i have some 5 inchers i'll try out.
05-27-2007, 08:23 AM | #20 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
Looks like its coming around great |
Thread Tools | |
Display Modes | |
