Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Loading
Thread: Homemade winch how-to
Old 07-29-2007, 08:06 PM   #1
Default Homemade winch how-to
I got a lot of comments on my homemade winch in my K2-K5 build thread, so as promised, here is the how-to:
Start with two of the cantilever parts from the TLT kit, a strip of thin sheet styrene and a papermate pen barrel.
When you look at the cantilever parts you will see a side with no lip on the outside and one with a lip. I cut off the arm on the side with the outside lip. You want to cut it as straight and square with the other arm as you can. These will serve as the feet of the winch.
Now cut off the nub on the back and try to keep it square as well.
Now on the arm that's left cut off the top just at the bottom of the hole. Again you want it to be square, as this will be the top of the winch.
Now take the papermate pen barrel and cut a 3/4" - 7/8" piece out of the middle. Clean up the edges as you will glue this piece in to the cantilever parts.
When you glue the barrel into the cantilever pieces, it is imperative that the arms are straight and square. As long as they lay flat against the table, you should be good. Trace some circles onto the styrene sheet, cut them out and glue them onto the ends.
Now wrap whatever you are using for winch line around the center barrel and secure with a knot on the back side. Put a small drop of CA to insure it doesn't unravel.
Cut 3 strips of the styrene and glue to the front, back and top. Take a small file and smooth out all of the edges.
Now take a few short pieces of wire and drill two holes in the arm and two in the body the same general size. These will be the power cables from the controls to the winch motor.
Now cut an elbow off one of the sprue trees and glue it on to the barrel on the opposite side from the wires.
Add a little paint and a sticker, drill a couple of holes for mounting and ta-da, instawinch!
It will depend on how you set up your winch line, but there should be room under the center barrel for the actual line to run out, like mine above. Good luck!
onespeeder is offline   Reply With Quote
Old 07-29-2007, 09:14 PM   #2
I had the hottest girlfriend at the MSD Nats
INSANE. i never knew. excellent job hombre. that really is awesome! friggin creative, man thats cool!
obijuan is offline   Reply With Quote
Old 07-29-2007, 11:32 PM   #3
octigonwallrus's Avatar
wow some of the most exellent use of stock tlt parts.
octigonwallrus is offline   Reply With Quote
Old 07-29-2007, 11:46 PM   #4
Nice jon of using what you have. Top Notch for sure...
Old 07-30-2007, 02:16 AM   #5
Awesome!! I'm going to build a faux winch like this, and i may just have to use your design! Great job, I'll be sure to give proper credit.
Mlow is offline   Reply With Quote
Old 07-30-2007, 06:19 AM   #6
Kte
Thumbs up
Great tutorial.
Kte is offline   Reply With Quote
Old 07-30-2007, 06:22 AM   #7
Nice job man! Very creative. I'm gonna have to try this. Thanks for the tip!
BGGruff is offline   Reply With Quote
Old 07-30-2007, 06:43 AM   #8
Wow! That came out better than expected. I'm gonna have to try that out. Keep up the good work, it looks great!!
jamesbernatchez is offline   Reply With Quote
Old 07-30-2007, 06:53 PM   #9
WOW, what can I say that hasent been said... oh well, Ill say it anyway...
THATS FRICKEN AWSOME MAN!
You are the man!
Nice job, a sticky for sure
~John
KRAWLR4life is offline   Reply With Quote
Old 07-30-2007, 08:58 PM   #10
I lost my vendor privileges
well im another one that will be copying this one. nice job.
clodstall is offline   Reply With Quote
Old 07-30-2007, 09:36 PM   #11
What type of paint did you use? I can't get any I have to stick to the damn thing.
Old 07-30-2007, 09:50 PM   #12
I just used Testors enamel. It has held up for me so far.
And thanks for all the compliments. It's amazing what a rainy Saturday, some rummaging and a little imagination can do. Hope it helps.
Old 07-30-2007, 10:20 PM   #13
Just found some Testors Steel and used that. Worked great! Ill post up pics tomorrow. Thanks for the great tip
Old 07-30-2007, 11:08 PM   #14
Great idea! I'll have to try it tomorrow.
Norcal crawler is offline   Reply With Quote
Old 08-01-2007, 09:32 PM   #15
Thanks for the tip. I made my own. I did a few things diffrent tho.
west virginia krawler is offline   Reply With Quote
Old 08-01-2007, 09:42 PM   #16
Right on, man. It's all about making it your own.
Old 08-02-2007, 10:44 AM   #17
I really like that man! That really nifty. I wonder if there would be some way to power it......... Maybe something like a steam train, like connecting rods and wheels. Something like this
servo with arm that can continuosly spin and round servo horn on the side of whinch. Put the servo on the chassis and connect a little arm between the servo horn on the servo and the one on the winch. turn on the servo and watch it crank the whick like a steam train! That would be cool, but the winch would have to be alot bigger for it to work right I think. But all the while it would be cool.
Great idea man. Very creative. Looks great. And where are you getting the small warn decals?
Krawlin is offline   Reply With Quote
Old 08-02-2007, 05:26 PM   #18
I will deffinatly do this, just was digging through the parts box and walla I got everything to do it!
Great how to!
scalecrawler is offline   Reply With Quote
Old 08-02-2007, 07:06 PM   #19
im working on one right now for my hummer buildup. Thanks for the tip...
Stallion1967 is offline   Reply With Quote
Old 08-02-2007, 07:56 PM   #20
i dont like to copy things but i am going to do this but a little funcional
thanks
andres-tavares is offline   Reply With Quote
You may not edit your posts
