09-12-2007, 10:06 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: USA
| 2.2 Rebuild Above Comp Worthy...
New axles... My new Smaller Knuckles and Tubes. Perfect for 2.2's. These axle tubes give about 1/4in more Clearance then Standard ones. New shorter CVD's. Don't widen the Track width at all. Went back to plastic gear cases to reduce over all weight. Chassis and axles |
Sponsored Links | |
09-12-2007, 10:21 PM | #2 |
Picky Fab'r/Acetal Junky Join Date: Jul 2006 Location: Arizona Desert/AJ
Your about as bad as I am...can't leave a truck alone. What is the height inside the axle C's? I'd like to know if the knuckles I have would fit. I assume they are the same type of alum knuckles that use the white spacers on the standard C? |
09-13-2007, 02:04 PM | #3 |
RCC Addict Join Date: Mar 2006 Location: Xxx
Shorter cvd's ? |
09-13-2007, 03:51 PM | #4 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
We need more info on the tubes, please. Like where did they come from?
09-13-2007, 04:03 PM | #5 |
Rock Crawler Join Date: Sep 2005 Location: IDK
09-13-2007, 04:51 PM | #6 | |
| Quote:
Interesting, this is the first time I've seen the small C axle tubes. They look very nice JP. | |
09-13-2007, 05:38 PM | #7 |
Ya I thought they would be perfect for this Build.... |
09-13-2007, 06:07 PM | #8 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
verry nice build so far. |
09-14-2007, 08:37 PM | #9 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
09-14-2007, 09:12 PM | #10 |
RCC Addict Join Date: Nov 2006 Location: southaven
my pics are not working to show u but turn the axle tubes upside down from how ur pics are so the flat spot is on top for the axle stays and servo mount. if u still have the pics i emailed u about two weeks ago u can see what i mean and how mutch to cleance the knuckles lookn good
09-14-2007, 09:14 PM | #11 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
how wide are you now with them axle tubes and tires.
09-14-2007, 09:21 PM | #12 |
09-15-2007, 10:23 AM | #13 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
hmmmm, i think i'm gonna have to take another looko at your website!!!
09-17-2007, 10:40 AM | #14 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Well,we need updates
09-17-2007, 11:19 AM | #15 |
09-18-2007, 11:45 AM | #16 |
A little update. Added a 5955TG for the Servo. Figured that should get the job done easy. Added 2 65t CrawlMax's. I'll get more done woith Pic's later.
09-18-2007, 08:32 PM | #17 |
Would consider that a little tease, get on with the good stuff ............ |
09-18-2007, 10:58 PM | #18 |
Pic's... Got some done... Mounted the Electronics. Well most of them. I made a Plate for the Lipo pack, but it's drying at this time. Only have to mount the RX and maybe a Castle BEC. I have a new set of Wheels coming in. That should shallow the Axle C's and cover that area all up. That should also bring my Track width back done about another 1/4in or 1/2in. I'm sitting at 10-7/8in right now. |
09-18-2007, 11:35 PM | #19 |
I wanna be Dave Join Date: Dec 2005 Location: Happiness is a warm AK.
Looing good bud! I like the new tubes and C's. Any word on the CrawlMax motors availability yet? |
09-19-2007, 02:16 AM | #20 | |
| Quote:
I was trying to figure a Way to lock out the Rear steer, Since I didn't have a straight axle in the rear. Washers wouldn't work with Alumn Parts. I didn't want to use Locked out steering links. Then it hit me.... Takes up just about ZERO Space and is super simple...... Here is my battery tray... Not the best, but works and moves the battery lower and more towards the front then my old set up. | |
Thread Tools | |
Display Modes | |
