RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Electronics
Thread Tools Display Modes
Old 05-12-2005, 06:50 PM   #1
FritoBandito
Arrow My Modded TQ3 Update - Added EPA pots
I posted a pic of this when it was still in the works. Now it's done and I'm loving it. It's over the top but works very well. I wouldn't want a steering wheel this big if it had to go fast but for this application it's great. Not bad for a $15 radio. Pretty obvious what I've done to it. Later I'm also going to add a charging jack and eyelet for a lanyard. Feel free to comment.
Close up of the switch. I took my time on the mount.
FritoBandito is offline   Reply With Quote
Old 05-12-2005, 06:56 PM   #2
powertuned
i like it how difficult is it to use?
how bout a break down of how you were able to accomplish it
__________________
Please tell you BOOBS to stop staring at my EYES
[img]http://www.rcefnet.com/albums/userpics/10050/sig4.jpg[/img]
powertuned is offline   Reply With Quote
Old 05-12-2005, 07:00 PM   #3
phantom309
NICE, i like that., Good work.
__________________
I can't forget that i don't remember what.
phantom309 is offline   Reply With Quote
Old 05-12-2005, 07:47 PM   #4
FritoBandito
Quote:
Not at all. The wheel might slow you down a bit but for crawling you'd never know. Ergonomically it's as natural as the stock TQ3 wheel for me. The switch is also easy to use. Since I fly RC planes I have it set to steer the rear wheels the same direction a rudder stick does. Keeps my head straight. Important when I go fly my 3D planes 2 feet off the ground.
The transmitter is painted with American Tradition Plastic Paint and chased with a couple coats of clear lacquer of some brand. The plastic paint works very well but is not very chemical resistant hence the clear coat.
The labels are my own as well. Notice the FritoBandito between the trim pots. I scanned the stock labels into Photoshop and converted their image into a template to make mine. They're printed on color inkjet paper and protected with several coats of fixer spray and affixed to the transmitter with 3M 77 spray adhesive.
Obviously the steering wheel is my stock TLT wheel and tire. I took the stock TQ3 steering wheel and mounted it to a steel shaft which I mounted in my drill. Then I used the drill like a poor man's lathe to turn down the diameter and face of the steering wheel until it fit snugly and deep inside the TLT wheel. Then I ran three screws through the outside of the rim where they'd be covered by the tire and into the TQ3 steering wheel. I also cut down and stuffed the tire with a spare tire foam I had laying around. Without it the tire was a bit on the squishy side for steering.
The switch comes from my local hole-in-the-wall electronics store. It's wired with caps according to the article posted in this forum. The stock switch hole was filled with JB Weld, Dremeled down, then built up using a mix of microballoons and epoxy. Then that was Dremeled, filed, and sanded until I got it where I like it. Other than a few scratches it came out pretty nice.
Detailed enough?
Old 05-12-2005, 07:51 PM   #5
powertuned
plenty
__________________
Old 05-13-2005, 01:21 AM   #6
hcfr34
Very nice. Your steering switch. Is it controlled or far right, far left, and center?
__________________
If it ain't broke your doing it wrong.
hcfr34 is offline   Reply With Quote
Old 05-13-2005, 06:16 AM   #7
FritoBandito
Unfortunately it's not proportional. Just full lock left and right. I guess I could have made it proportional with a pot switch but it didn't seem necessary. Besides, at some point I have to remember it's a cheapo radio and not worth too much of an investment. If I really need that kind of control I have a nice Hitec Eclipse I'm not using. Install a surface module and I'm ready to rock. Now... if I could only replace the sticks on the Eclipse with... BEER TAPS! Yea.. that's the ticket... ;)
Old 05-13-2005, 07:07 AM   #8
Gimbal
Very nice, looks factory What does the receiver look like? ;) (truck)
Gimbal is offline   Reply With Quote
Old 05-13-2005, 07:33 AM   #9
FritoBandito
Well the truck side of things isn't quite done yet as neither the body nor the wider axles have arrived. Outside of that it's assembled. It's a pretty standard TSC-10 with some minor changes to the stock shock mounting location and a custom skid plate.
Since this is the radio forum I'll just post links to the pics. When I get the body and axles on I'll post it all in the Small Scale Forum.
http://www.datascape.net/crawler/crawler01.jpg
http://www.datascape.net/crawler/crawler02.jpg
http://www.datascape.net/crawler/crawler03.jpg
http://www.datascape.net/crawler/crawler04.jpg
http://www.datascape.net/crawler/crawler05.jpg
http://www.datascape.net/crawler/crawler06.jpg
http://www.datascape.net/crawler/crawler07.jpg
http://www.datascape.net/crawler/crawler08.jpg
http://www.datascape.net/crawler/crawler09.jpg
http://www.datascape.net/crawler/crawler10.jpg
http://www.datascape.net/crawler/crawler11.jpg
http://www.datascape.net/crawler/crawler12.jpg
http://www.datascape.net/crawler/crawler13.jpg
Old 05-13-2005, 05:15 PM   #10
powertuned
any idea if you can add a trim knob to the third channel? i think it would make driving easier in the long run.
__________________
Old 05-13-2005, 05:31 PM   #11
FritoBandito
Believe it or not there is one from the factory. It's inside what looks like a screw hole on the back side if the transmitter. A complete surpise to me.
What I am thinking about adding is a couple micro pots to adjust the end points of the rear steering.
Old 05-13-2005, 05:35 PM   #12
powertuned
i dont have my tq3 yet any way you can take a pic and post it so i know what to look for when i get mine
__________________
Old 05-13-2005, 06:59 PM   #13
Tuffguy
hey I would like a detailed write up of the micro pots to control endpoints
don't like replacing 645's cuz of overstraining them!!!!!
Kevin
Tuffguy is offline   Reply With Quote
Old 05-16-2005, 08:08 AM   #14
FritoBandito
I'm in the process of adding the EPA pots now. As soon as I have it figured out I'll post the details.
Old 05-16-2005, 08:33 AM   #15
JasonInAugusta
06 Super National Champ
JasonInAugusta's Avatar
Excellent!
Good bit of work, looks great!
Also looks like you've spent some time with static models or owned several "hard" bodied vehicles.
__________________
A good paragraph should be like a skirt. Long enough to cover the subject but short enough to keep your attention.
JasonInAugusta is online now   Reply With Quote
Old 05-16-2005, 09:27 AM   #16
FritoBandito
Thanks Jason,
Most of the techniques/tools/materials I used come from RC plane building which is my primary hobby (well flying em anyway). I haven't built a static model in 20 years. I hate to show ignorance but what is a "hard" bodied vehicle?
Old 05-16-2005, 09:52 AM   #17
JasonInAugusta
Clod, Jugg, Blackfoot, Bruiser...etc
__________________
Old 05-16-2005, 10:33 AM   #18
syco133
I guess Ill show my stupidity here but I found the 3rd channel trim by accident I put the 3 way toggle in my tq3 and every thing was fine before I took it apart when I put it backtogather the trim was way the heck off.I started to look to see what could have changed and ta da there it was a little hole in the bottom left corner of the remote I adjusted it and that was all it took I couldnt belive it I was so pissed and to think how many times I adjusted the linkage on my maxx .
__________________
[COLOR=Lime][SIZE=5][FONT=Impact][URL=http://www.sercrc.com]www.sercrc.com[/URL] [/FONT][/SIZE][/COLOR]
[COLOR=Lime][SIZE=7][FONT=Impact][/FONT][/SIZE][/COLOR]
Leading the shockless revolution.Not copying it.
Brushless since 10/05/2006
syco133 is offline   Reply With Quote
Old 05-18-2005, 10:16 PM   #19
FritoBandito
Lightbulb My Modded TQ3 Update - Added EPA pots
In my previous thread I had simply added a switch like most folks have. At the time I was considering adding a couple pots to control end point adjustment for my rear steering. Well now it's done. A brief rehash of the radio.
Front of the radio. You can see the neck strap ring I've added.
Now back of radio. Notice the additional holes in the base.
Close up. From left to right.
Existing screw hole, existing rear steering trim, new right and left EPA trim pots, new charging jack.
It works PERFECTLY. I'm able to smoothly adjust end points from just a little movement to full travel individually for either direction. At the request of a couple folks, here's a simple image describing the wiring.
There's nothing to it. The only hard part was stuffing the extra wire and connectors into the radio. Notice the wires from the switch go to the same pair on the pots. That way they both do the same thing when turned in the same direction. Other than that this is a stupid simple mod.
Hope you guys find this useful!
Old 05-18-2005, 10:29 PM   #20
Vitamin_J
ur nuts
__________________
grrr
Vitamin_J is offline   Reply With Quote
You may not edit your posts
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
