10-10-2012, 01:12 PM | #1 |
| SCRCC Q & A Thread
I thought this might be fun so I figured we'd give it a shot. This is how it works...and rules are subject to change. A question will be posted below...the person that answers it must provide another question to be answered. This should be kept on topic with RC Crawlers...scale trucks, comp trucks, supers, suspension setup, shock setup, tires, foams, radios, electronics, etc. etc. etc. This can also include judging, rules, course format, etc. etc. etc. The questions don't have to be something that you don't understand...it just needs to be relevant to RCC! If you don't know the correct answer...don't answer. If you don't know the correct answer...look it up...then post the CORRECT answer AND another worthwhile question...got it? Good...let's get started...be sure to make the question you are asking A DIFFERENT COLOR so it stands out!!! With regards to suspension setup and link geometry: What effect does moving the rear upper links UP at the CHASSIS have on traction at the rear axle? |
10-10-2012, 07:46 PM | #2 |
RCC Addict Join Date: Nov 2007 Location: somewhere
| Re: SCRCC Q & A Thread
It gives u less traction in the rear
10-10-2012, 09:17 PM | #3 |
Pebble Pounder Join Date: Jun 2009 Location: gaffney
Link position Where can I get 18 gauge wet noodle? |
10-10-2012, 09:22 PM | #4 |
Quarry Creeper Join Date: Nov 2011 Location: dark corner
It makes the rear push on the front more due to the fact that the link is higher so the axle wrap pushes on the chassis and provides more downfprce on the front end!
10-10-2012, 09:29 PM | #5 | |
| Re: SCRCC Q & A Thread Correct...but where's your question Quote:
Where's your question? Care to state the obvious? Although I've never seen 18 gauge wet noodle, you can buy 18g wire through our site or other sites such as: Robot MarketPlace - 16 Gauge Silicone Wire - Black What are the maximum wheelbase rules for each of these classes: 1.9, Super, 2.2pro, 2.2S? | |
10-10-2012, 11:29 PM | #6 |
| Re: SCRCC Q & A Thread in shafty setup what is the best pinion angle and why? |
10-10-2012, 11:43 PM | #7 | |
| Re: SCRCC Q & A Thread Quote:
2.2 and 2.2s are both legal @ 12.5 inches A PERSON IS RUNNING A COURSE AND MAKES IT UP TO GATE 5 WITH TWO REVERSES AND A BARRIER HIT WHEN HE CLEARS GATE 5 HE TAKES ANOTHER REVERSE TO CLEAR GATE SIX, HE GOES ON TO FINISH THE COURSE (10 GATE COURSE) WITH ONLY A HAND ROLLOVER WHAT WILL THIS PERSONS SCORE BE WHEN HE FINISHES THE COURSE? | |
10-11-2012, 06:12 AM | #8 |
-2 if my brain is working right this morning What is the minimum gate with for 1.9. 2.2pro and supers |
10-11-2012, 07:23 AM | #9 |
| Re: SCRCC Q & A Thread |
10-11-2012, 08:13 AM | #10 |
10-11-2012, 11:16 AM | #11 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
10-11-2012, 11:28 AM | #12 |
Rock Crawler Join Date: Oct 2010 Location: pickens county
| Re: SCRCC Q & A Thread You can get 18g wire from advanced auto, autozone etc........way easier bud Will derrick build a losi sportsman's rig? Last edited by cmyers1; 10-11-2012 at 02:20 PM. |
10-11-2012, 06:03 PM | #13 |
Quarry Creeper Join Date: Mar 2009 Location: Yokota
| Re: SCRCC Q & A Thread A gate is considered straddled if at any time the axle of a vehicle (facing in any direction) passes over any part of a gate marker and both tires of that axle are touching the ground (or any object on the ground) on opposite sides of the gate markers, it is considered a straddle and a Gate Marker penalty is assessed. What does increasing the distance between the upper and lower links at the front axle do to the suspension geo? |
10-11-2012, 06:55 PM | #14 | |
10-11-2012, 07:02 PM | #15 |
Rock Stacker Join Date: Dec 2010 Location: Pickens, SC
10-11-2012, 07:23 PM | #16 |
10-11-2012, 08:12 PM | #17 |
| Re: SCRCC Q & A Thread Did you really forget your question again??? Just FYI...the dark blue text is VERY hard to see... Memory foams get hard when it's COLD, and softer the warmer it gets...never a consistent set up really. TRUE OR FALSE: Hitting or straddling a gate marker for a bonus gate during your run counts against your score while running the course regardless of whether or not you progress the gate. |
10-11-2012, 08:55 PM | #18 | |
Rock Crawler Join Date: Dec 2010 Location: Piedmont, SC
While on course your crawler breaks....you start repairing it. The clock needs to _______running until repair is finished | |
10-11-2012, 08:56 PM | #19 | |
Who's is going to win our next comp | |
10-11-2012, 09:02 PM | #20 |
SCRCC Q & A Thread - Similar Threads | ||||
Dorkstar & Bulu trip thread... | toyofast | RC Rock Crawling Worlds | 17 | 09-07-2011 07:36 PM |
SCRCC Comp #7 Discussion Thread | ittybitty | South Carolina | 67 | 06-28-2011 07:44 PM |
Cheapbatterypacks.com feedback Q&A thread | Chris_The_Battery_Man | Vendors Electronics | 118 | 01-06-2011 11:20 PM |
Tattoo's Q&A thread...... | TattooKenny | Chit Chat | 93 | 04-03-2009 08:24 PM |
