Go Back   RCCrawler Forums > Regional > Southeast > South Carolina
Thread: 4 link or 3 link?
Old 12-18-2013, 07:46 PM   #1
jdgodfrey68's Avatar
Default 4 link or 3 link?
Is the 4 link better than the 3 link on front of SCX10? Why and how has it helped your rig?
Sent from my SCH-I605 using Tapatalk
jdgodfrey68 is offline   Reply With Quote
Old 12-19-2013, 04:11 PM   #2
Default Re: 4 link or 3 link?
3 link is good for a chassis mounted servo so you can run a panhard bar and get more scale points.
4 link is good if you run a axle mounted servo, but if you stay with this route ditch the Y link on the upper and and run your upper links farther apart.
******DO NOT RUN A CHASSIS MOUNTED SERVO WITH 4 LINK .....IT CAN PHYSICALLY BE DONE BUT LITERALLY ITS RETARDED.....YOU WILL LOSE STEERING AND GAIN BUMP STEER************
Performance wise they are pretty much the same. I have ran them both no big difference between the two so just use what you want
M_ENERGY is offline   Reply With Quote
Old 12-19-2013, 04:40 PM   #3
Thanks
Old 12-25-2013, 07:56 PM   #4
I am running 3 link on the front and rear of my 1.9 truck. No real issues to speak of.
2003EDGE is offline   Reply With Quote
4 link or 3 link? - Similar Threads
Steering link and drag link - what's the best bang for the buck? Matthewboerner Axial Wraith 29 10-25-2011 10:25 AM
Link setup on TCS 4 link plates and boulder chassis sdcrawls Axial AX-10 Scorpion 8 11-17-2009 02:37 AM
