03-18-2014, 03:58 AM | #1 |
Newbie Join Date: Jan 2013 Location: West Columbia, SC
| Traxxas TQ1 Help
I just bought the TQ1 for the 4ch with 5ch receiver. 3 position switch to run my RC4WD winch. I found to need to do this little mod to get the switch to be a 3position switch only. by doing this. Traxxas TQi 4 channel transmitter mod tutorial http://www.rcsparks.com/forum/genera...-tutorial.html now when i hook it up it works you can control id going in and out just fine, but when its in the OFF position it continues to run slightly like having the throttle trim just a little off. dose know how and what to do to get it right. Last edited by thetinman85; 03-19-2014 at 11:25 AM. |
03-18-2014, 05:12 AM | #2 |
Newbie Join Date: Jan 2013 Location: lexington
You need to go into the menu and set channel 3 trim Sent from my C771 using Tapatalk 2 |
03-18-2014, 05:05 PM | #3 |
Can you do that on the traxxas TQ1? Sent from my XT1056 using Tapatalk |
03-18-2014, 05:44 PM | #4 |
Newbie Join Date: Jun 2013 Location: Taylors
| Re: Traxxas TQ1 Help
Yes, if you don't have the manual for the radio, go to Traxxas' website and you can download the manual. I will tell you how to make all your adjustments.
03-19-2014, 06:30 AM | #5 |
Im not able to adjust the trim on the channel, or i just dont know what im going lol. i do have the manual.
03-19-2014, 02:39 PM | #6 |
03-19-2014, 03:21 PM | #7 |
If you cant adjust trim...but i would imagine you can...there are also products sold here that help correct this issue if Im not mistaken.
03-19-2014, 03:51 PM | #8 |
What type of winch controller are you running? Sent from my DROID RAZR HD using Forum Runner |
03-19-2014, 04:33 PM | #9 |
I just looked at the transmitter manual and the radio mod. There isn't a way to adjust the trim on ch 3 because it was initial intended to be a 2 position switch. All you are able to do is reverse the direction. I would try doing the if you haven't already. If that doesn't work the only other thing that I can think that you could do is trace the circuit board for that channel and if there is some sort potentiometer in the circuit, adjusting it very slowly may take care of the problem.
03-19-2014, 04:52 PM | #10 |
another option you can try is this. Go thru the the first 5 steps of the programming to reverse the servo, then instead of pressing set the final time press menu. If the red light blinks twice, use the multi-function knob to see if that takes care of the problem. If that works press the set buttom to save the setting and then press and hold the menu button to get out of programming mode. I would go thru the process of setting the knob back to what ever you had it set for prior to making the adjustments.
03-20-2014, 05:14 AM | #11 |
RC4WD 1/10 Bulldog 9300XT Scale Winch Gunmetal Z-E0021. and all the hardware and plugins. i will try those steps when i get home today.
03-20-2014, 06:08 AM | #12 |
Traxxas TQ1 Help - Similar Threads | ||||
Traxxas TQ1 Help | thetinman85 | Electronics | 0 | 03-17-2014 09:47 PM |
traxxas fm radio and traxxas waterproof esc help | jon1197 | Newbie General | 11 | 12-14-2009 12:34 PM |
