04-29-2020, 04:17 PM | #1 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
| SSD TK upper links
First I love my TK and SSD support is second to none. The only issue I have had is with the upper rear links. I eat the rod ends on every crawl. Rips the ball right through the plastic. This is my scaler and literally crawls. Have a Hobbywing 1800kv AXE and it torques through the ends like nothing. Any alternatives made of harder plastic the same size as the short 3mm ends? Sent from my Moto G (5) Plus using Tapatalk |
04-30-2020, 07:53 AM | #2 |
| Re: SSD TK upper links
The rod ends from the old TMaxx are very close to the same size (part # 2742), don't know if they are any stronger though. Any rear upper links that fit the SCXII should work on the rear of the Trail King so you could replace the links with something that uses stronger M4 rod ends. |
04-30-2020, 08:02 AM | #3 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Can you post a pic of your link set up? I haven’t heard of this issue before, certainly not at that frequency so it makes me wonder if something else is going on. I use the ssd links on my 10.2 (same link set as TK) and it’s one of my more high mileage rigs and the links are overall are in great shape without slop at the balls. My TK has seen considerably less trail time but also does it have this issue.
04-30-2020, 08:34 AM | #4 |
Here is my link set-up. Had rod ends on both ends fail on the uppers. That said we have some extreme rocks and link stressing crevaces in UT comps. White Rock tested it for sure. Other rigs have 4mm links all around Sent from my Moto G (5) Plus using Tapatalk |
04-30-2020, 08:44 AM | #5 |
My Trail King. Sent from my Moto G (5) Plus using Tapatalk |
05-01-2020, 11:26 AM | #6 |
Nothing looks off to me with your links, strange that keeps happening and wish I could have been of some help. Good looking truck though |
05-01-2020, 06:15 PM | #7 | |
| Re: SSD TK upper links Quote:
Sent from my Moto G (5) Plus using Tapatalk | |
05-05-2020, 08:31 PM | #8 |
I hammer on my SSD Trail king and only a couple rod ends have some play after 15+hours of hard use, granted I'm running a 35 turn on 3s, which is a far cry from your power level. You might need to upsize to 4mm rod ends with matching links for a long term solution.
SSD TK upper links - Similar Threads | ||||
Bomber upper links vs wraith upper links. | DivineReeper73 | Axial RR10 Bomber | 23 | 04-06-2018 02:29 PM |
Using upper links for bottom links? I've hit a dead end! | TIME MACHINE | Axial AX10 2nd-gen | 2 | 03-04-2015 11:00 PM |
