Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > SSD Trail King - Pro Scale Chassis Builder Kit
Thread: Largest set of Overdrive gears?
Old 07-30-2020, 12:16 AM   #1
Default Largest set of Overdrive gears?
Is the SSD Overdrive set of ring/pinion gears in the diff the largest available? or is there another set of gears that will fit the Pro44 case that offers a larger overdrive option?
Timmahh is offline   Reply With Quote
Old 07-30-2020, 07:00 PM   #2
Default Re: Largest set of Overdrive gears?
Beuller?
Beuller?
Old 07-30-2020, 07:22 PM   #3
There has only been 1 overdrive ratio for the AR44s. There are a few different brands offering these but always with the same gearing. I would highly recommend the Enduro gearbox combined with a set of overdrive gears if this were just an SCX10.2 but the Trail King tranny is kind of its party piece.
HumboldtEF is online now   Reply With Quote
Old 07-30-2020, 09:44 PM   #4
Thats what I had thought, though I did seem to think I heard of a taller set that would go into the axles.
Going for a different build with an axle, and was hoping to find a taller ratio for the pumpkin.
But I gotz Iders so the SSD OD set it is.
Thank Hum. Appreciate the info.
Largest set of Overdrive gears? - Similar Threads
Overdrive gears for the 10 II skybolt Maine 0 07-05-2017 05:27 PM
Overdrive gears! Alexander_0_1 General Crawlers 4 03-03-2016 09:40 AM
overdrive gears crawler pilot Losi Mini-Rock Crawler 13 11-29-2009 04:23 PM
