Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > SSD Trail King - Pro Scale Chassis Builder Kit
Thread: SSD Trail King K10
Old 10-19-2022, 09:35 PM   #41
Default Re: SSD Trail King K10
Foams trimmed and still wouldnt compress enough for the hardware to start so little vice did the trick for the extra power i didnt have in my hands. No i was not trimming the tires bead.
Schs2013 is offline   Reply With Quote
Old 11-02-2022, 03:37 PM   #42
Curios to know how some of you would recreate a blown out sidewall on super swampers?
Old 11-04-2022, 03:52 PM   #43
Define, "blown out"?
lonleycreeper is offline   Reply With Quote
Old 11-04-2022, 04:00 PM   #44
Damaged from trail environment.
Old 11-13-2022, 09:37 PM   #45
Truck came back from my buds place. He created a second rear cage mount that is more adjustable. Figured i would start by tire swap. (New) super swampers on black gcmracing ranger beadlocks (Old) used Dick Cepek Mud Country on swap meet special beadlocks.
Old 11-13-2022, 10:47 PM   #46
At full compression. Upper link hits oil pan. Ill see what i can do with it.
Like the lifted look so far with stock spring preload. But no damaged rear spare so it has a lot of rear rake in my opinion, but it can be tuned later. Rock rails need alot of help as well but all in due time. Thats all the time i have to thinker on my toys tonight.
Old 11-18-2022, 12:11 AM   #47
Start of the Trail Damaged for the rear spare.
Need a cheap wheel to mount it on.
Tools used
Old 11-18-2022, 12:58 AM   #48
Rear end cosmetic’s being mocked up. Fuel tank sits just ever so slightly over the rear axle but even at full stuff it doesn’t touch. Making some progress.
Frame want to chop it but do not want to much flex from removing the metal bumper mount. Ill just leave it for now.
Old 11-19-2022, 09:35 AM   #49
Default SSD Trail King K10
A buddy of mine gave me a great idea. Leave the frame as it is and fit a winch between the frame and cage. Not sure just how this will work but its worth trying a rear winch setup which i have looked at doing on other rigs in the past but never did.
SSD Trail King K10 - Similar Threads
SSD Trail King - Trail Run - 06-13-2021 soze Scale Videos! 0 11-02-2021 06:34 PM
SSD Trail King - Trail Run - 1/10/2021 soze Scale Videos! 1 09-20-2021 07:43 PM
My Take on the SSD Trail King neilus SSD Trail King - Pro Scale Chassis Builder Kit 48 03-24-2020 04:09 PM
SSD Trail King is now $369.99! SSD New Products and Great Deals 0 10-04-2019 04:13 PM
SSD Trail King Toothless9 General Crawlers 2 09-03-2019 06:57 PM
