02-10-2011, 08:48 AM | #241 |
The wheels are 115mm (~4.5") in OD and I narrowed them to 1.5" in width. The tires measure just over 8" in OD when mounted on the wheels. |
02-13-2011, 04:12 AM | #242 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Thanks alot for your Quick answer. one other question what is your Vehicle track width with the HPI blasts and the Supersedonas? |
02-18-2011, 06:21 PM | #243 | |
I also ordered up some bling parts: (red shock parts to replace the blue) (Ti kingpins) | |
02-20-2011, 11:21 AM | #244 |
I finally got the battery off of the upper links and mounted to the gearcase. I was planning on just drilling the gearboxes like I did on my Berg, but then BigRon came out with a new carbon fiber mount for the bergs, so I figured I'd see if it fit my Super Bully...and it does! I also took first in our local comp yesterday....here is an action shot: |
02-20-2011, 11:36 AM | #245 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I like that battery mount. I think I pick one up for my bully super when she gets her next rebuild. Should be REAL SOON. (key evil laugh while I cough up carbon fiber dust)
02-20-2011, 11:41 AM | #246 |
02-20-2011, 02:49 PM | #247 |
Rock Crawler Join Date: Mar 2009 Location: AZ
Looks great. I've been thinkin bout doin the same.
02-20-2011, 07:45 PM | #248 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
Battery mount looks sweet in there, what battery you running on it? Congrats on the win too! |
02-20-2011, 08:00 PM | #249 |
Thanks guys! The batteries that I run on this truck are Krawler Hobbies (Krawl Off Road) 850mAh 4S packs: http://www.krawloff-road.com/store/i...&product_id=53 |
02-21-2011, 11:21 AM | #250 |
Pebble Pounder Join Date: Jan 2011 Location: Bakersfield,Ca
Jeremy,is that battery mount a bolt-on ? & does BigRon have them for sale ?
02-21-2011, 11:32 AM | #251 |
02-21-2011, 02:29 PM | #252 |
I taket it that a standard 1300 pack will fit ?
02-21-2011, 02:32 PM | #253 |
Hummm...not sure. I can measure the plate this evening for you if that will help.
02-21-2011, 02:41 PM | #254 |
If you could that would be great,right after I hit "submit" I remembered you run 850's,still would like to know since that is a killer location for them.Thanks Jeremy.
02-21-2011, 04:06 PM | #255 |
Scott, the plate is 35x60mm. |
02-21-2011, 05:05 PM | #256 |
Sounds like it will work,I think I'll order one up and see..............Thanks!
02-22-2011, 02:42 PM | #257 |
Jeremy,does the RCC stands keep the tires off the ground with your 8" tires ? btw congrats on the comp this last w/e.
02-22-2011, 04:01 PM | #258 |
Acutally....those stands allow the tires to barely touch the ground. And thanks! |
02-23-2011, 11:06 AM | #259 |
Ok,here we go again,where can I find teflon like what you used to wrap to axles ? I would like to keep the carnage to a minimum as spendy as these axles are !
02-23-2011, 11:35 AM | #260 |
IIRC, I got that stuff from McMaster.com |
