09-11-2013, 06:52 AM | #741 |
| Re: Ivory |
09-11-2013, 07:04 AM | #742 |
| Re: Ivory
but did you trim down the sleeve?
09-11-2013, 07:12 AM | #743 |
| Re: Ivory
So, now to get this to work properly I need a machine shop?
09-11-2013, 07:42 AM | #744 |
| Re: Ivory
Nope...just a belt sander/dremel/file etc. The sleeve on mine is too tall even with the shim so the next step was to take a little off the sleeve so that when you tighten things down you are putting pressure on the bearings instead of on the sleeve. Without pressure on the bearings you'll get excessive play in the gears and they will skip under heavy loads. It doesn't have to be precise... |
09-11-2013, 09:19 AM | #745 |
| Re: Ivory Even the sidewalk might work Not even close. Just as long as its below the top bearing surface. You could be 1/8, maybe even a 1/4" below the bearing but try to go just under. Lastly, if you dont want to use the Dremel, sidewalk or even mess with it in general, just hit me up in PM and I will get the correct parts out in the mail today. |
09-11-2013, 01:31 PM | #746 |
| Re: Ivory
I understand things happen. I am not mad. I was kinda mad when I was ripping it off after my first course at nats....but the pouring rain might have had something to do with that. |
09-11-2013, 01:34 PM | #747 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Ivory
0.125" CF plate...
09-11-2013, 02:01 PM | #748 |
| Re: Ivory |
09-11-2013, 02:07 PM | #749 |
| Re: Ivory
Shows you what I know. I can't even cut the stuff! J |
09-11-2013, 09:15 PM | #750 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Ivory |
10-01-2013, 07:45 AM | #751 |
| Re: Ivory
Manu graciously gave me a set of these cool hub spacers (made by Dlux) at nats and I finally paired them with some Lattice Innovations hubs: Nice and strong yet, reducing the slop by getting rid of the extra piece. |
10-01-2013, 11:48 AM | #752 |
| Re: Ivory
OOOOOH, very nice!!
10-08-2013, 09:35 AM | #753 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
| Re: Ivory
Looking good Jeremy, Let me know how the shifts hold up on your Super. |
10-08-2013, 10:00 PM | #754 |
| Re: Ivory |
10-09-2013, 12:14 AM | #755 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Ivory
When are you getting the scratch paint body panels? Ivory needs some lovin' to. |
10-09-2013, 08:52 AM | #756 |
| Re: Ivory |
03-14-2015, 05:50 PM | #757 |
| Re: Ivory |
03-14-2015, 05:54 PM | #758 |
Rock Crawler Join Date: Mar 2009 Location: AZ
| Re: Ivory |
03-15-2015, 08:02 AM | #759 |
| Re: Ivory
End of an era...
03-15-2015, 01:17 PM | #760 |
| Re: Ivory
I see it as the beginning of a new chapter! |
