08-02-2010, 07:21 AM | #61 | |
Pebble Pounder Join Date: Mar 2009 Location: Germany / Stuttgart
do you already have a construction drawings for the gearbox? or do you need also the konstrution complete. Maybe I can help you. Greetings - Sascha | |
08-02-2010, 04:24 PM | #62 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
PM sent Kieren |
08-03-2010, 03:20 AM | #63 |
Front and Rear axles a little further on. Also working on some idea's for new gearboxes. Kieren |
08-17-2010, 03:15 AM | #64 |
Got to work on this a bit today. So far I have got the uppers and the main steering links done. They are 4mm SS threaded rod sleeved in 8mm SS tube. I don't think I will have any trouble with them breaking I'm edging ever closer now and I can't wait to drive it seeing the amount of steering! I have got it sitting around a 16"-16 1/4" wheelbase depending on how much I end up clocking the gearboxes. Kieren |
08-17-2010, 06:59 AM | #65 |
That is coming along quite nicely! What shocks will you be running? Are you planning to mount them to the lower links or the axles??
08-17-2010, 06:41 PM | #66 |
Thank you I plan on running HPI firestorm front shocks in alloy. They will have to be link mount for 2 reasons. 1. They are only about 3.5" and 2. To clear the tires. I've come up with an idea to mount the servo and make link mounts all in one. Hopefully too it will make the lower links slightly less 'L' shaped. Kieren |
08-18-2010, 12:23 AM | #67 |
Hi Kieren, looks good. I like your servo mounts position Greetings - Sascha P.S. The gearbox projekt don't sleep |
08-18-2010, 01:41 AM | #68 |
Thank you. I am working on the other side of them right now. Kieren Ok |
08-18-2010, 04:28 AM | #69 |
Got started on one of the servo/link mounts today. 3mm steel. Welded in place where necessary. Kieren |
08-21-2010, 04:44 AM | #70 |
Got the front linked up. Kieren |
08-21-2010, 05:34 PM | #71 |
Hi Kieren, your links are from full metal or pipe with thread rod. Your lower links look very juicy. Greetings - Sascha |
08-21-2010, 07:45 PM | #72 |
Pebble Pounder Join Date: Oct 2006 Location: australia
This is gunna be badass Just wondering, Are those servos the Coreless Titanium, High tourqe ones off ebay For a very low price? i was thinking of buying them?, i keep burning out My rear steer. epa is set shit im thinking. |
08-21-2010, 08:43 PM | #73 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
are you going to leave the tie rod under the knuckles as shown in the photoz?
08-21-2010, 09:12 PM | #74 | |||
I choose to go with 4mm threaded rod and 8mm stainless tube on these ones, much neater than my welded solid ones I have previously been making for other projects. Thank you! Quote:
One I got from MKS a while back and the other I got from hobbyking, both for $65. Most likely someone is reselling them on ebay though. Quote:
Kieren | |||
08-22-2010, 04:51 AM | #75 |
Front linked and sprung. Slowly but surely getting there. Kieren |
08-23-2010, 05:17 AM | #76 |
Got the rear link mounts finished today. Hoping to have links done tomorrow. Then It's onto the motor plates. Kieren Last edited by Aussie Nerd; 08-23-2010 at 05:34 AM. |
08-23-2010, 06:02 AM | #77 |
Ah k, well i ordered one anyway. 12 bux free postage. and its rated the same as my hitec front digital servo so eh? Im keeping a close eye on this build. Where abouts are you located? ive seen a few of your posts on the crawlpit. |
08-23-2010, 03:16 PM | #78 |
Hi Kieren, nice work Which servo arms you use at your mks servo? looks beefy. Greetings - Sascha |
08-23-2010, 04:17 PM | #79 | ||
The home of bundy rum Quote:
Thank you I am using integy futaba servo horns. They are remakes of the robitronic ones. Kieren | ||
08-24-2010, 12:36 AM | #80 |
Ohwell, 12 bux im not complaining, if its shit itll just go in my drift car. yeah i know where that is |
