06-29-2011, 07:24 PM | #181 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
any Robinson Racing Pinion for a 1/10 scale moter will work.
07-08-2011, 07:36 PM | #182 |
Newbie Join Date: Apr 2011 Location: columbus
you should come with a 3 link eliminator kit that replaces the 3 link mount on the motor with a 4 link mount. Like the ZNO wing eliminator. Simple design yet effective.
07-08-2011, 09:45 PM | #183 |
| The duel servo mount will double as the 4 link replacing the 3 link once I get the $$$ to finish the testing... mainly I'm waiting for some toasted eletronics to be replaced from castle that was DOA.
07-09-2011, 04:35 PM | #184 |
| I was thinking more for the rear than the front. Cause unless you build a bracket like yours there is no way to do 4link in the rear.
07-12-2011, 08:12 PM | #185 |
| The dual servo bracket for the 4 link conversion can be used with one servo then just mount your ESC on the other side on each axle... |
07-13-2011, 07:13 PM | #186 |
did you ever do the dual esc setup? i wonder if you used 2 stock esc's what would happen? been thinking bout going to this setup instead of a dig switch. What would be needed another esc and probably a bec but what amp and size? This electronics stuff confuses the crap out of me.
07-16-2011, 10:00 PM | #187 |
| Experiment Continued...
Well, I Finlay got some extra $$$ and time to work on my super a little more. I found that if you use tome 1/8 revo 17mm hubs and drill a new pin hole just out side the hex, you get a perfect snug fit!!! and helps bring in your track width. The Chassis.... Well, I finished tweaking the original design that was sent to me for my liking, got her cut and put together. Now I have to finish up the custom links, body panels and we will have a roller.. Here's a photo with my girl modeling it. She approves with her... ouwwww, eee, ggaaaaaaa And some other shots... |
07-17-2011, 02:44 PM | #188 |
Looks good looking forward to see this thing all put together.
07-17-2011, 11:15 PM | #189 |
| Roller
Well, i got more time today so do the body panels and work on the roller... I still have to adjust the upper links a touch and shorten the lowers by about 1/8th of an inch to get her to 18 inches on the nose!!! So far, I think it's looking promising. |
07-18-2011, 07:37 AM | #190 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
That looks great Adam, good luck with it!
07-18-2011, 08:15 AM | #191 |
man that thing looks badass. Do you have a measurement to the bottom of the frame. A+ on the chassis.
07-19-2011, 07:17 PM | #192 |
| it gives you 5 inches of clearance at the center of the chassis whe way it's set up. You can run the ride hight lower then what I have it set at. This is just my starting point. I would like to use some slightly smaller shocks but the stocker's will have to do for now. The chassis dimensions meet the minimum rules on all dimensions.
07-19-2011, 10:15 PM | #193 |
That looks great, super work Adam. |
07-20-2011, 07:40 PM | #194 | |
07-20-2011, 08:56 PM | #195 |
They've had those for a little while now. This issues is that they are too long. probly need somthing about 100mm long to using the mounting locations on the links.
07-22-2011, 10:53 PM | #196 |
MFDesigns Join Date: Feb 2009 Location: ValleHOE
nice work. my budy just bought one and its got potential. we put 105mm integy shocks with stock springs and they worked out well. also put an AKRCC ares 2.2 chassis on and that fit well also. we still have alot to do to it but am following you build for more insperation. this is his first crawler and ive been comping 2.2 rigs for a couple years so im helping him out. i did notice that the AX 10 and berg knuckles would work and that gave me hope for it. thanks for your detailed build and info for parts it will save us alot of time and money. P.S. do you have anymore chassis? |
08-02-2011, 07:19 PM | #197 | |
09-01-2011, 09:27 PM | #198 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Ok Abavuso I read up a bit on this build, and I like the idea of picking this up to get into the super world, but thought I would shoot you a quick question. If you had it all to do over again would you pick this rig up again? I am seeing that the bully axles are 99 bucks but obviously you are starting from scratch all around there. What say you amigo? |
09-01-2011, 09:52 PM | #199 |
Really liking this build. Alot of work gone into it. The new chassis looks great. Just one comment. In this picture, it looks like you need to shorten your front upper links or clock your steering knuckles back. Not sure if you can do that on these axles. Looks like you have too much negative caster which greatly reduces steering effectiveness. |
09-02-2011, 04:54 AM | #200 | |
The whole perpous of this thread was to see if you can make the MT COMP WORTHY. I'm saying yes but with my experience the MT lacks durability at the knuckles while running a serious comp setup. Knuckls will need replaces and nodded heavily to be durable enough and all the strain on the transmission caused the plastic transmission housing to flex. Bottom line you get what you pay for. Sent from my PC36100 using Tapatalk | |
