01-13-2012, 07:30 PM | #341 | |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
| Re: Super Experiment... :& Quote:
There's other option if you change wheels size, the cutting and gluing is just what we do for the comp rigs becuase there arn't a lot of really good comp tires on the 40 series realm that give you 7 + inches in hight for the tire. | |
01-14-2012, 09:35 AM | #342 | |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
01-14-2012, 09:29 PM | #343 |
Nothing Fancy, Just crusing around the kitchen to show how much stering you can get with this modification. She'll be going to her first comp tomarow with the modification so we shall see how she does. I think the only thing I really need at this point is some knuckle weights. This rig will stear further than I have it set to, unfortuatly my crapy servos don't push it to it's full potential. Looks like I need to start saving $$$ for new servos now that this thing actualy drives like it's supose to. Video - Super :: VIDEO0039.mp4 video by adambavuso - Photobucket Last edited by Abavuso; 01-14-2012 at 09:34 PM. |
01-14-2012, 09:31 PM | #344 |
Tomorrow will be about driving, it won't be about weight! |
01-14-2012, 09:43 PM | #345 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
That steering is looking good! Can't wait to hear how the new set-up works for you tomorrow. I am planning on ordering (hopefully) the last few parts to get mine together. Still have lots of tire gluing to do, but I'm starting to lean toward enlarging some 2.2s...
01-15-2012, 08:37 PM | #346 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
ok now i really want one of these i need to get my 2 i have straightened out first LOL |
01-16-2012, 12:25 PM | #347 | |
Sent from my PC36100 using Tapatalk | |
01-16-2012, 02:47 PM | #348 | |
01-17-2012, 06:16 AM | #349 |
Quarry Creeper Join Date: Aug 2009 Location: Jackets are everywhere.
Guys, as you know, those sockets were designed so that with a 4mm shaft, they would provide 1/2 sq. inch of contact surface... specifically to test glues. There is no reason not to try that first... a failure would cause no damage, and would be easy to clean up before moving to more difficult or permanent bonds. I precision bored those sockets (2 slow passes, not needed for solder or brazing) intending to provide the best odds to you that K.I.S.S. would rule the day. I need to know real world results to refine the design. Jumping straight to a bond that we all know will work... but, takes much more work, and tools that most don't have... teaches us nothing. I have the torque readout tool now, so I will be testing bonds as soon as things warm up a bit. I will test from standard CA, flexible CA, and 2 part epoxies... through silver bearing solder/acid flux, and brazing. The latter will require much less contact, and will have appropriate (lighter) sockets. Those UJs are wet noodles. You can see the finish left by A's dremel, on the joint, looks "fluffy". I have cut 4 of them, and can tell by resistance. Experience has given me a feel for the relative hardness of metals... and those cheap Integy CVDs (4.5mm) I was going to use feel easily twice the strength of the exceeds. I'll have hard #s on them as soon as conditions permit. The UJ's served well already. They showed us that, at the low shaft speeds we need, they can be angled to extremes... while costing little. I won't be using them, the sockets can easily take 5.5mm shafts, so I'll spend a little for UJs with known quality, and thicker shafts. I have asked Nabil for the info he offered on the UJs he used here: super bully universals They held up for him. A, Braze those up, and twist the heads off. We'll make more. |
01-21-2012, 02:40 PM | #350 | |
01-21-2012, 02:46 PM | #351 |
| Re: Super Experiment... :& I stand corrected I think these are the Uj's the he is using. OFNA Hyper 7 TQ Buggy Front CVD 87354 // CVA Axle Universal Joint Drive Shaft |
01-26-2012, 10:12 PM | #352 |
My take on STICK PROGRAMING.... This this is what i decided on after messing around with my 2.2 a little to fine tune the way it drives. the best part is that it works like a dream on the super and doesn't make me feel like I'm flipping crazy switches. Not to mention when you dig, the rear holds solid because you are applying curent to the motor. I need to get out and drive with it a touch so I can get a feel for it but it feels a lot more natural on the 4WS and the dig, burn. |
01-27-2012, 01:32 PM | #353 |
I like this! I just ordered a Sky Fly CT6B.(I'm Cheap) . I would really get some details on the dig a ma jig. Can you help out a EKD R&D brother?
01-27-2012, 04:38 PM | #354 |
The dig-a-ma-jig I initialy created was back in my XR-10 thred,, check it out here... The Hawk - XR10 Bodiles Chassis Concept |
01-27-2012, 09:23 PM | #355 |
Those UJs look good. The clearances look ample. I like my 6B. I've never even held a "good" radio, but I can't imagine a better deal for a good starter than these things. I have a lot to learn about programming, but a quick look at the menu didn't baffle me too much. Don, why are you thinking switched dig vs. dual ESC? |
01-27-2012, 09:41 PM | #356 | |
01-28-2012, 07:34 AM | #357 | |
01-29-2012, 04:09 PM | #358 |
So I tested a few other options... CA and JB Weld... I ran the JB all the way up around the lower portion of the UJ and sanded down the UJ shaft to ensure I could shove JB down the hole for maximum contact. The CA broke free with little effore as I figured it would. The JB on the other hand... after 24hours of curing you could slightly budge the shaft. On the next, 48hours of curing I coun't tell if it was moving at all or not. After 1 week of curing!!!!!! The end result!!!! A After 5 min of bashing on a high traction surface the UJ's are strong but I snapped a third gear!!!! Further testing will tell but I think I can get EKD's shaft to bond to the UJ's with JB!!! Hummm who would have though!!!! Further testing once the new gears show up will tell for sure. Last edited by Abavuso; 01-29-2012 at 04:11 PM. |
01-29-2012, 06:27 PM | #359 | |
Wow! I didn't think CA would hold up for much torque, but glad to hear JB weld seems to be working great. I was still planning on brazing, but just barely got my tubes together. I still have a lot of work to go, but I might order up a spare gear-set just in case. | |
01-29-2012, 10:45 PM | #360 |
Good job, A!! I couldn't be happier about this. If that bond works, we can try lighter shafts with heat treating, and not worry about ruining the treatments with more heat on assembly. We need to break 3 or 4 of these gears in a row before we hunt stronger stuff. We can't get too excited about upgrades until we know it isn't a single part's (or single production run's) flaw. If these are all weak, we'll solve it. At this end.... it's all good news. Hurry up and break it again! Last edited by ekd; 01-29-2012 at 11:19 PM. |
