Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: Super Experiment... :&
Old 04-01-2011, 03:17 PM   #61
im getting a mad torque soon love yours!!!! im a noob so this thread will help me ALOT!!!! thanks for all the info and please keep posting!!!
JugRKnoT is offline   Reply With Quote
Old 04-01-2011, 03:49 PM   #62
Originally Posted by N.Master View Post
Hi,
A good regular pot is made to handle 1W of power maximum before burning ! (1/4W for cheap pots) the idea is not bad, but you will need a high power resistance, not a pot.
For reversing the current, you need a dual inverter switch
for example : http://search.digikey.com/scripts/Dk...ame=CKN1409-ND
Thanks for the input... now I know what additional research I need... resistors... BTW i tired the POT to see if it worked and it did for about 3 seconds till it gave up the white smoke... I got a larger more durable POT... 6 seconds... i think I need to take a basic electronics class so I can better understand current and resistors and such.
Abavuso is offline   Reply With Quote
Old 04-01-2011, 09:33 PM   #63
You need the book "electronics for dummies"
Big E is offline   Reply With Quote
Old 04-01-2011, 10:28 PM   #64
So this is what I've done so far... I'm shooting for the same suspension angles I designed into my Rock Hawk chassis because that seams to give me awesome break over and great stability... so after looking at the chassis for about an hour, this is what I decided on for now.
I also swaped some of the rod ends forom the stearing to the lowers to puch the WB out a touch... fully compressed it sits at 18in resting sprung it sits at 17.5in. Tomarrow I'll test it out if the wether holds.
I moved the skid to a few different location to eyeball how I wanted this to be cut, then decided on this.
Cut a bit off
I'm still playing with the rear link placment... I'll probly move them back to the bottom hole once I get my 30 degree high clearance links made.
Lastly I got my BEC wired to the rear servo, now I'm crankin 446oz with the rear... it's perfect now. All I need it a HH BR-XL for this beast and a 3S and we'll be rockin!!!
Old 04-01-2011, 11:12 PM   #65
Looking good man.. Cut that frame up..
Old 04-02-2011, 09:26 PM   #66
aw man i had the same idea but i dont have the money
what u running for a radio if you want i have a 7ch radio futaba for 150 if your interested
if you dont want it after the first comp ill take it
but in the vid it looks like its worken for you and someone went to green lane
asw27x is offline   Reply With Quote
Old 04-02-2011, 10:39 PM   #67
Default Test Run Today
Well I took it out for a test today and it wasn't very stable. I narrowed it down to the fact that I still had the 3 link in the back. I didn't have any more 1/2 in delrin to make a servo mount for the rear so I cut 4 pieces of 1/8th inch and bolted it together so that it would work out for till I get more material... anyhow, will head out to Palmerton tomarrow for a little more testing.
Next, I've got to figure out how to add some caster to the c's... I was looking at to tonight and it souldn't be too hard. I just need to get me some AX-10 C's to try my idea.
Here's the pictures of the rear 4 Link...
Old 04-03-2011, 03:34 PM   #68
Default Tested Comp Setup...
Alright fells I think this bugger is as comp worthy of a roller on a budget you can get. I made some changes and took her out On t he rocks in Palmerton today for some practice/tuning.
Last mods that I need to come up with are:
- Clocking the C's
- CVD's
- High Clearance Steer link
- Better Motor/ESC
- Custom Bodiless Comp Chassis
Part's on order:
4 - Axial Aluminum Knuckles
4 - Better Quility Bearings for the Axles(stock ones are starting to fall apart)
10T - Pinions
Here's the spec's...
Parts
Stock ESC - (needs to go but will work for now)
2 - 55T Venom Fireball modified - (8.4v OK but really need a 3S ESC)
2 - 12T Pinion (I've got a 10T for the rear on order)
1 - 8.4V NIMH pack for weight/EXTRA power
2 - Stock servos on the front Axle - about 400oz combined(Y-Harness)
1 - Patriot RC Servo - PHU3542 on the rear W/BEC 7.2V - 426oz
1 - Castle Creations BEC
1 - Traxxas 4TQ 4CH radio
1 - Mini Venom Servo/switch for DIG
1 - Vanquish Blue Gear Grease
4 - Axial 40 Series Wheels Narrowed to 1 3/4 inches wide
4 - Pro-line Moabs Narrowed (1 1/4 inch strip cut from the middle)
6 - Sedona Foams (1 1/2 Per Tire)
4 - Serpent Cobra S811 811 17mm Wheel Nuts and Hex
Setup
4 Wheel Steer(Crab Walk & same direction)
Rear DIG
Narrowed Chassis to - 2 1/4 inches wide
Wheel Base - 17 1/2 inches
Track Width narrowed to - 14 1/4 inches
Belly clearance Front 5 inches - Rear - 5 1/4 inches
No additional weight added to the wheels
7S 8.4V NIMH Pack
Balance Point 1 1/2 inches forward of center
Wheel Diameter - 7 inches
4 Link on the front and rear
Clearance at the Dif - 2 3/4 inches
MAX Articulation Limited to - 8 Inches
Pictures and a video from today to come shortly...
Old 04-03-2011, 03:53 PM   #69
Default Testing Photos
I ran a test course then came back through a second time pausing to snap pictures for your viewing pleasure.
Old 04-03-2011, 05:00 PM   #70
looks good cant wait to see it this sunday
Old 04-03-2011, 06:06 PM   #71
Got mine ordered should b here n a couple days, im very excited to see ppl building these things, and not talkin about axials n what not i like to b different hope i can get mine close to the state of comp worthy lol, love this thread and will continue to follow it thanks again for the info!!!!
Old 04-03-2011, 06:44 PM   #72
welcome to the world of the torques Jugs...
Old 04-03-2011, 06:59 PM   #73
Default Super Panthers
Well, I got two of the super Panthers done... Only problem is that they are rippling a little on the surface... Any idea why? I'm thinking more foam to stretch them out?
Not sure why it's rippling so bad in this one but not the first one.
Old 04-03-2011, 07:07 PM   #74
The rippling is because you are taking something curved, and straightening it out. If you look at some of the other super tires, they sometimes do this. One thing that helps is using super-sized sidewalls.
Using bigger foams might help though.
What do they end up at height wise?
monkeyracer is offline   Reply With Quote
Old 04-03-2011, 07:17 PM   #75
They are 7 inches tall as they sit now. I was going to use the moab sidewalls but I really like the narrowed moabs for high traction surface's... that and I don't know if I really want an 8 or 9in tire, seams to me like that might get a little unstable or have too much tire role I would think... I could be wrong but that's just my thought on it...
I wish my scale wasn't packed in a box because I'm curious of the weight difference. They feel almost half as heavy which will do wonders for my wheel speed and stress on the drive train.
I did stuff them with the stock moab foams and they feel just about perfect for the weight of the supper. As soon as I get the other two finished I'll try them out and see just what they feel like.
Old 04-03-2011, 07:53 PM   #76
I will probably shoot for about 8" tall for my tires, but may end at 7.5". The moabs are about 7.25 or so mounted on full width axial beadlocks. I got my moabs specifically to use the sidewalls (since they are really worn on the treads)
Old 04-03-2011, 09:22 PM   #77
Default All finished
Well, I got all 4 of the tires finished. The last two are better than the first two... The Foams after closer inspection could have been a little taller to fill out the wrinkles. If I work the tires the wrinkles go away. The main problem I see is that the foams aren't siting properly so the tires are a little lopsided. Well, I guess it's off to the store to find some foam to make it better. Once properly stuffed, they should puff out to at least 7.5 niches would me my guess judging by the amount of wrinkles.
These tires drastically improve the handling of the rig. The throttle doesn't feel sluggish, I have my wheel speed back and the DIG actually holds better now. Now I just need to get her back on the rocks to compair performance. Best of all, the sidewalls don't fold over and I get just enough ripple that it should totally grip the rocks really nice.
Old 04-03-2011, 10:10 PM   #78
Default Todays Video
Check out the video
from Adam Bavuso on Vimeo.
Old 04-03-2011, 10:25 PM   #79
hit your video link and this showed up.
"This video contains content from WMG, who has blocked it in your country on copyright grounds"
Tires turned out nice man..
Old 04-04-2011, 12:13 PM   #80
Its fixed, try it now.
