04-08-2011, 04:59 PM | #121 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
if you looked at his signature u would get an idea
04-08-2011, 05:11 PM | #122 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
04-08-2011, 06:56 PM | #123 |
| Custom Chassis
I think I'm finally happy with the chassis layout. I've fixed the Shock and link mounting location so this should work just fine. I'm planning on using 4 small buggy shocks so that that I don't have to limit them all that much so we shall see how well this works once I get it made... again, it's going to be a while before this design roles.
04-08-2011, 10:37 PM | #124 | |
Rock Stacker Join Date: Mar 2011 Location: Parker
Man wish I would have known you were going to sell this thing my wife probably wouldn't be so mad at me for taking all my time making mine.. | |
04-08-2011, 11:59 PM | #125 |
Pebble Pounder Join Date: Mar 2011 Location: Kings Mtn.
got mine in, ran it for a few minute,put it up, and took it back out to show a friend and notice that i have a split in the back left tire about an inch and a half long down the seam of the tire. any ideas of how to fix this until i get some new tires? glue? thread? fishin line if glue what kind should be used?
04-09-2011, 01:06 AM | #126 | |
I wanna be Dave Join Date: Oct 2008 Location: Golden
04-09-2011, 01:15 AM | #127 |
Ok, thanks. Should the local hardware carry the ic2000 glue? Its not a huge deal at the moment but i do need to get it fixed. Other than that i love this thing in its stock form as it is the first crawler that i have owned besides a cheap maisto haha
04-09-2011, 01:45 AM | #128 | |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
X2 what Monkeyracer said. FYI a little goes a long way | |
04-09-2011, 01:46 AM | #129 |
Rock Crawler Join Date: Jan 2011 Location: bridgeport
| Very cool bracket for the servos but the only thing im noticing is they might be to vonerouble to getting damaged when crawling,they're to out in the open.i've broken so many servo horns and bent so much steering linkages when mine were up front in that position.but very cool design and good luck with it. |
04-09-2011, 01:48 AM | #130 |
| Dude! You are beast with all the ideas and fab work you got going on! All while moving! Super mad dope props to you man |
04-09-2011, 04:46 AM | #131 |
| Call nitrix tech suport ant tell them. You should get a replacment for free. My dog bones and difs were bent out of the box and they sent me those for free.
04-09-2011, 07:48 AM | #132 | |
04-09-2011, 08:19 AM | #133 |
04-09-2011, 08:59 AM | #134 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver Wa, USA
04-09-2011, 02:39 PM | #135 |
Well i got to test mine out on a huge pile of broken concrete we had from a demo job, and it did very well... Tires do need attetion though and skid plates seem like a must for me. Im gonna look back and see if you guys wrote a how to on skid plates if not where to start?
04-09-2011, 05:14 PM | #136 |
Adam and I are driving to the GSRCRC comp on Sunday, I can't wait to see all the work that he has done to this. Great Job. |
04-09-2011, 05:21 PM | #137 | |
Unless you talking about narrowing the skip plate on the chassis. Then that's a must. | |
04-09-2011, 07:22 PM | #138 |
the only thing i think about the RTX-27 shafts is because they are like the bull have a big joint but then some homemade knuckles and the cool think is ti atach the hex its a pin and setscrew and the are so smooth full steer and you can turn them and there is no rough spots |
04-09-2011, 08:09 PM | #139 |
[QUOTE=Abavuso;3035150]I won't bother doing skids on the bottom of the axle but get a 5 Hr energy bottle and cut the top and bottom off put a slit in it and wrap your motors to protect them. The rocks slide onthe plastice easier then the motor can. Unless you talking about narrowing the skip plate on the chassis. Then that's a must.[/QUOTE Ok sounds like that would be much easier, also is anyone having problems with the pins holding the bottom of the shock to the bottom links, trying to slide out? |
04-09-2011, 11:16 PM | #140 |
[/QUOTE]Ok sounds like that would be much easier, also is anyone having problems with the pins holding the bottom of the shock to the bottom links, trying to slide out?[/QUOTE] Quick fix/cheap fix: put a "crimp" in the pins with a pair of side cutters or a little bend in the pin and it will stay in place. Upgrade fix: Drill out the lower link and shock bracket and thread a 2.5mm screw thru each one |
