06-16-2011, 12:42 AM | #41 | |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
Thanks for the help with the bearing mod crash. Your rig is looking great. | |
06-16-2011, 10:18 AM | #42 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Very cool Mods! |
06-16-2011, 11:09 PM | #43 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
06-16-2011, 11:36 PM | #44 |
I have finally decided also to go with a 4PK radio. And JB also picked up my tires tonight to build me a nice set... |
06-20-2011, 12:09 AM | #45 |
So I am putting along. I am going to hold off on getting the rear steering stuff finished. So I decided to design my body next. In my typical manner--many many many versions to get what I want. And I finally got what I wanted. |
06-20-2011, 12:21 AM | #46 |
So next I chose to get my wheels done/narrowed to 1 1/4" since my tires will be done soon... I remember the days when it was common to narrow our wheels for the 2.2's and also watched a video by supershafty to re freshen my brain on it. Started by cutting the inner bead off and then the desired amount for the correct width. The big difference (I have not searched to see if anybody else had tried this but it made sense to me) I did was I made 2 cuts per wheel. The cut for the width was only made deep enough to get thru the wheel but not into the spokes and the other thru the wheel and spokes. This lets me butt the spokes against the soon to be glued wheel. I have seen a few wheel failures and wanted to do what I could to keep that from happening. As you can see the inner bead portion fits nicely. Then it was time to glue. So the wheels are done and hardening (with rotation to keep it from dripping). |
06-20-2011, 05:12 AM | #47 |
Rock Crawler Join Date: Jan 2011 Location: bridgeport
Looks good man...is the glue J&B welding?..if so thats what i used on mine and they've held up pretty good.good luck.
06-20-2011, 06:31 AM | #48 |
Rock Crawler Join Date: Mar 2009 Location: AZ
The wheels turned out real nice Crash. I like that you left the spokes to use for gussets. |
06-22-2011, 12:24 AM | #49 |
06-22-2011, 12:25 AM | #50 |
06-22-2011, 12:28 AM | #51 |
Putting along at a steady pace. I got the bodyless side plates cut. And the cross supports done. |
06-22-2011, 12:32 AM | #52 |
Got the roof and hood panels cut and threw some paint on them. And threw it onto the chassis to see how it looked. I still need to make some lower side panels. |
06-22-2011, 12:40 AM | #53 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Man, that thing looks amazingly like a duck! You should name it "Ducking Bills" Nice progress Crash. Casey |
06-22-2011, 12:43 AM | #54 |
06-24-2011, 12:19 AM | #55 |
Well I got my shocks today and got them mounted up. I still have to get springs but I just had to see how it looked... |
06-26-2011, 11:18 PM | #56 |
So on saturday JB had my tires done and ready--thanks JB!!!! So I finally made it home today and decided to head out to the shop. With the tires on it sat a tad high. So I redid the link lengths and shock mounts and dropped it down to 4" at its lowest point. |
06-28-2011, 06:43 AM | #57 |
Rock Crawler Join Date: Sep 2008 Location: Marysville, WA
06-30-2011, 10:17 AM | #58 |
06-30-2011, 10:18 AM | #59 |
So my other 2 Bec's came in. So I figured it was time to start getting the electrons flowing. I programed the voltage for all 4 bec's (6.5v/7.4v). I finished modding the skid plate and got the fxr's in place and some wires. Then thru the skid plate on and tried to get more done. |
07-04-2011, 10:48 AM | #60 |
Well it took some time but I finally got all the wiring done and secured. Before I got it all secured I went and programmed the FXR's. I also watched harleys videos and got the radio setup along with the FXR's set to the radio then fully secured everything. I still have to rework the battery setup plus I need to get different packs for it. The rear. |
