11-22-2011, 04:20 PM | #1 |
Newbie Join Date: Oct 2011 Location: amherstburg, on
| Exceed mad torque Build
So I got my exceed mad torque a few days a go I got the green version and thought I would give my thoughts on it and show what I have done to it. So stock it crawled good but left room for improvement first off 2ws sucks so I put my 4 wheel steer on which was much better. Also don't like how you have to put the spacers in the shocks every time you want to adjust them so I got the aluminium ones for it that are threaded that way I can adjust them fast and whenever I want without having to carry around those spacers. clod stall wasn't really a problem as what little it had didn't really affect how it crawled to much also I crawls up stairs very good stock. so the tire compound was alright so I fiqured I would stick with it for now till i can afford something better so I planned to make the tires better so I cut a piece out in the tread which made them grip better also got some foam from Walmart for $6 That was 18x18x3 And did all four tires and it worked a bit better Then I cut shut them when my wheels came the next day and cut the wheels down to 1 1/2 wide and bought another foam from walmart and cut them for the new tires I also got the lower links from the maxstone 8 and used a 2.2 chassis I had which worked out pretty good and am using a 1550mah lipo from my e revo in it mounted on the top front links on a piece of lexan from a body with velcro and zipties to hold it on. I also put some lights on it for when I crawl at night Also put a big nut on each of the front axles for front end weight it's not much but maybe it helps maybe not I plan to get some stick on wheel weights for cars to stick in the rims Last edited by dannymac; 11-22-2011 at 04:28 PM. |
11-22-2011, 06:31 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Jackets are everywhere.
Nice work, D! You haven't been messing around. Looks good! |
11-22-2011, 08:20 PM | #3 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
Looks cool, Danny, you will be changing those servos soon. Like duals on the front with those big wheels.
11-22-2011, 08:20 PM | #4 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
Looking good so far, welcome to the madness!!!
11-23-2011, 12:09 AM | #5 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Looks great! Glad to see another person has gone Mad!
11-27-2011, 07:06 PM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: in the 7eventh level of hell
those tires and wheels are crazy
12-01-2011, 02:13 PM | #7 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
12-29-2011, 07:04 PM | #8 |
Newbie Join Date: Dec 2011 Location: New Philadelphia
| Re: Exceed mad torque Build
did you do anything else to the electronics in order to run the lipo?
02-26-2012, 07:18 PM | #9 |
Newbie Join Date: Feb 2012 Location: Bishop
Nice job danny it looks great!
03-04-2012, 05:07 PM | #10 | |
| Re: Exceed mad torque Build Quote:
I now run dual stock escs with 3s lipos and higher torque servos with no problems works great thanks Danny | |
03-16-2012, 12:19 PM | #11 |
Rock Stacker Join Date: Mar 2011 Location: Parker
HUMMM those tires and wheels look oddly familiar |
12-24-2012, 05:21 PM | #12 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
I know it's been while since this threads been up. But when you started running a lipo did you run a bec as well, or just leave the electronics stock and throw a lipo in there?
01-30-2013, 12:35 PM | #13 |
Quarry Creeper Join Date: Mar 2011 Location: norcal
What wheels are those?
01-30-2013, 12:58 PM | #14 |
| Re: Exceed mad torque Build |
01-30-2013, 05:36 PM | #15 |
FYI for you budget minded guys here's a servo that will do the job. check out the output. Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear Last edited by BentMetaL; 01-30-2013 at 05:37 PM. Reason: added |
01-30-2013, 05:54 PM | #16 | |
01-30-2013, 06:40 PM | #17 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
How tall is that wheel and tire combo?
01-30-2013, 07:17 PM | #18 |
