12-21-2011, 04:02 PM | #1 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
| Exceed Mad Torque Super Build
Started this project about a month ago, started seeing where people are building these up so i thought i would start a thread of my build. First started by narrowing chassis down to 2" wide and making my own homemade upper and lower custom bent links. Then i really wanted behind the axle steering, so i started looking it over and after about 4 hours of cutting, bending, grinding and making a new dual servo mount for 2 Hitec HS645MG's finally got it to work really nice and smooth.
12-21-2011, 05:11 PM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: Exceed Mad Torque Super Build
Nice looking work! I'll be following your thread. I would like to see how its going to work out. You might get a better plane of ster if you use the stock bent ball ends on the knuckles. Looks to me your going to get tire scrub on the shocks mounted like that. Check out my build thread below.
12-21-2011, 05:21 PM | #3 |
No tire scrub because i got the same maximizer rims you got, getting ready to post up a lot of stuff, actually getting close to done just new to posting and don't know how to add to this thread.
12-21-2011, 05:26 PM | #4 |
OK figured it out, here's my chassis i made out of $2.19 cutting board from walmart, just used what was left of original chassis plates as template and hand drawn a bodiless topper to it and cut it out, very simple, and if it breaks (which so far seems pretty stout) just make a new one.
12-21-2011, 05:26 PM | #5 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looks good man like the servo mounts.
12-21-2011, 05:32 PM | #6 |
Got new maximizer 3.2 wheels (dyed black) and cut n shut a set of 2.2 white dot rovers. i cut n shut a stock set of tire foams that came with the rovers but that's not going to cut it, they are not thick enough, going to have to order up some special dual stage tall foams for this setup from crawler innovations.
12-22-2011, 07:07 AM | #7 |
Oh I see why you wont have scrub. Your using the stock hubs.. I changed mine to narrow the width. Did you get the green wheels and dyed them black? What kind of dye did you use? I bought a set of Maximizer rock rings for mine. They cool! I posted a few pics of the wheels. |
12-22-2011, 07:35 AM | #8 |
Yep, the green ones, dyed them with rit dye powder from walmart for $1.66, use a pan you don't care about and mix whole box of dye in just under boiling water for about 15 minutes, works awesome. rock rings cool, may have to get some too. been watching your post for about a month now, yours coming along great also man along with a few others on here too. I also have an XR10 also to play with all my friends with, but they all have 2.2 shaftys but i like my MOA's thats why i decided to build up my mad torque and because it wasn't very capable on my course when it got changes for the 2.2's. here's some pics for ya.
12-22-2011, 08:05 AM | #9 |
Nice! Yea I don't have any locals with Supers all have 2.2's. Really the only one that I crawl with is my son who has a modded AX-10. We try to go to a different spot every month. I haven't been out crawling in a while. Just got a new set of servos for the rear. I'll be working on that this weekend. Been doing a little short course running indoors the last 2 weeks. Kinda fun to get out the Slash and do some bashing.
12-22-2011, 08:13 AM | #10 |
I've been doing a little of the same stuff to my sons blue mad torque except fot the BTA mod because there's just to much work involved in it, then my neighbors on both sides of me also have mad torques, so they've been waiting for me to finish mine then help them with theirs. Some of us have big garages so we also built some indoor stuff to play on no that it's cold out.
12-22-2011, 11:38 AM | #11 |
Quarry Creeper Join Date: Aug 2009 Location: Jackets are everywhere.
Nice work. Welcome to the Asylum. I'd like to see what your friends come up with, too. |
12-22-2011, 02:22 PM | #12 |
| Re: Exceed Mad Torque Super Build |
12-26-2011, 08:40 PM | #13 |
Finally got my body panels made today along with some pretty neat stickers i had laying around
12-28-2011, 09:07 PM | #14 |
It's bad when your 1:1 rig becomes a fixture of your RC crawler course |
12-29-2011, 05:57 AM | #15 |
I know what ya mean, winter project, putting set of dana 60's from 1979 F350 in my cherokee.
12-29-2011, 06:53 PM | #16 |
Newbie Join Date: Dec 2011 Location: New Philadelphia
I am very new to the rc world and I just bought a mad torque and have a question about the cut and shut. how do you now where to cut and how much to add? I may be over thinking it but how does it actually stay round without having a lump with the chunk you add in?
12-30-2011, 06:59 AM | #17 | |
| Re: Exceed Mad Torque Super Build Quote:
01-05-2012, 07:34 AM | #18 |
just got my 45t motors from RC4WD today W/13 tooth pinion gear for the front, really like these motors and i run them in my XR10 and run really smooth and strong. just need a good 3s lipo esc for er and i'm ready to letreat. more pics up soon.
01-10-2012, 06:09 PM | #19 |
Could not wait any longer to get 3s lipo and good esc in this thing so i put the stock esc and an old 3000mah nimh battery in and took it for its first test run, man this this climbs 100 times better than it ever did, everythings working really good, put 1 inch limiters in each shock (this thing would articulate past 90 degrees), now it's about 75 degrees. 45t's are perfect bias between torque and speed and i'm running 13t in front and 12t stock in rear for a little proportional dig, will be adding my rc4wd rocker dig II and fxr from my XR10 when i get dual tekin B1R's for my wantamix and DX3R for the XR.
01-11-2012, 06:02 AM | #20 |
Newbie Join Date: Dec 2011 Location: Salem
Can anyone tell me what the pitch is for the gearing? I want to replace the stock pinions and haven't found out what pitch to buy. Any info would be helpful. Thanks |
Exceed Mad Torque Super Build - Similar Threads | ||||
Exceed Mad Torque - Extensive Review and build thread | monkeyracer | Superclass Crawlers | 96 | 06-25-2016 07:55 AM |
Exceed mad torque Build | dannymac | Superclass Crawlers | 17 | 01-30-2013 07:17 PM |
exceed max torque or mad crawler?? | dylanjnt | Newbie General | 6 | 12-29-2011 06:37 PM |
Exceed Mad Torque?? | zero5rubicon | Newbie General | 2 | 12-29-2011 06:34 PM |
