03-10-2012, 10:02 AM | #21 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Stubs Super Bully!!!
Ooo! You get a vacation and you get to sleep in your own bed, nice! I think there might be enough supers in Fl to have a comp! Once there all up and running we will have to all get together and run them through some gates. |
03-22-2012, 07:36 PM | #22 |
Ordered 2 of these and they are AWESOME!! Receiver bypass adapter Super easy to plug in and they work great! The servo's seam faster than when they were plugged into the rx with only one bec? Maybe i'm just crazy though? I have been messing with my 6ex and i mixed steering ch1 and ch4 on pmx2 with the ch5 toggle. It is a lot easier to operate like this put does anyone know if there is a way to move it to the trainer/idle up toggle? If not i think i will just switch the toggles in the radio. I would also like to make the trainer switch make the rear steer 50% when flipped one way and 100% when the other? Does anyone know how to do that? |
03-22-2012, 10:16 PM | #23 |
I have never really understood that adapter. Why not just use a male - male adapter, pull the signal wire, install signal wire into a holder and call it good? What am I missing? |
03-22-2012, 10:17 PM | #24 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Why have a 50% rear steer on a mix? Just put one axle on the left stick and one axle on the right stick and steer them individual from one another.
03-23-2012, 04:15 AM | #25 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: Stubs Super Bully!!! The only advantage of the adapters is they run a ground to the Rx, instead of just the signal wire.
03-23-2012, 05:56 AM | #26 | ||
| Re: Stubs Super Bully!!! Quote:
You can mix so much in the 6ex. And it makes driving with a stick radio so much easier. I drove it yesterday and with the mix on the steering it makes 4 weel steer so much easier but it's only for steering them to make a tight turn. To crap walk i have to turn the mix off and steer with the left stick. I feel it just makes it easier to control in a situation where there is a lot going on. Doing 4 functions at one is to confusing for me at this point | ||
03-23-2012, 08:02 AM | #27 | |
Like I said though...I understand. There have been many time when alot needs to happen fast that My brain wants to explode! | |
03-23-2012, 10:04 AM | #28 | |
Maybe I should mod my dx6i for auto center on the left stick and put it on there, but that would mess with my helis. hmmm I can't wait to see this rig on Sunday Stubs | |
03-23-2012, 12:04 PM | #29 | ||
Servo Connector Female to Male Adapter I actually got the whole kit Servo Connector Kits I consider a connector kit like this a necessary tool for RC. Once you have one you will wonder how you made it without. There is also a lot of weight and mess you can pull out of wiring when you cut them to the correct length. | ||
03-23-2012, 01:10 PM | #30 | |
The ground doesnt do anything if you dont have glitching. Many have a problem with it and adding the ground solves it. I agree, a good connector kit it like having a good soldering iron. I have the hansen hobbies kit and their stuff rocks. | |
03-23-2012, 04:02 PM | #31 | |
Thats a cool kit but it looks like way to much work I just plugged in the connectors and jammed it under the panels. Which brings me to another point! How can you guys stand this bodiless business? I am tempded to cut the cab off this stupid thing and put a body over it! Every time i want to get to the electronics i have to take a ton of screws out. It is driving me f**king crazy | |
03-23-2012, 04:10 PM | #32 | |
Edit: never mind, I just looked at yours again. You are screwed into the cross members including the middle. I use zipties. Remove the middle one completely. Then it is only 2 screws to remove the cross members to flip the panel! Last edited by DickyT; 03-23-2012 at 04:12 PM. | |
03-30-2012, 04:32 AM | #33 |
Newbie Join Date: Jan 2012 Location: Ingram
Where did you get those wheels? Sweet lookin setup.
03-30-2012, 11:54 AM | #34 |
Thanks! Not sure who made the wheels? They were on there when i got it. |
04-07-2012, 09:31 AM | #35 |
Quarry Creeper Join Date: Feb 2012 Location: Adams, MA and Florida, MA
Wow! I want a superbully so bad now. They just look amazing when they're on the rocks.
04-08-2012, 10:33 AM | #36 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
| Re: Stubs Super Bully!!! |
05-03-2012, 09:36 AM | #37 |
Just wanna say gratz on 9th at ecc. Was reading the little writing on the home page
05-05-2012, 09:30 PM | #38 |
Nice driving this past weekend! It was good to meet you...
05-06-2012, 12:18 PM | #39 |
Newbie Join Date: Apr 2012 Location: Phoenix, AZ
Nice looking car!! |
05-13-2012, 09:54 AM | #40 | |
Thanks! It was great to meet you also and I appriciate all the help you have given. Thanks. It is in for some major changes! Dlux style. | |
Stubs Super Bully!!! - Similar Threads | ||||
Stub's Dlux HALLSTYLE | stubs179 | RC4WD Bully | 360 | 12-19-2018 04:25 PM |
