07-26-2012, 03:49 PM | #21 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
| Re: Ted's Lightweight Super Juice
Impressive clean build, Ted |
07-26-2012, 04:52 PM | #22 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
| Re: Ted's Lightweight Super Juice |
07-26-2012, 06:24 PM | #23 |
Sweet! Glad to see someone build a proper super berg with a centered gearbox/motor combo!
07-26-2012, 06:29 PM | #24 |
| Re: Ted's Lightweight Super Juice No way it will fit there, unfortunately.
07-26-2012, 06:32 PM | #25 |
Awsome! Great build man! |
07-26-2012, 07:28 PM | #26 | ||
Rock Crawler Join Date: Oct 2010 Location: NW Washington
| Re: Ted's Lightweight Super Juice Thank you. Quote:
That was my first impression as well when I measured it. After I mod the case and move the motor I will know for sure. I may even be willing to get aluminum tubes for the long sides and notch the hell out of them to get that 7980 to fit. For now I am not worried about it, I think I will manage just fine with the servo horn sticking up. Thank you. I just finished another one. A sporty. I will try and post that up in the AX10 section. | ||
07-26-2012, 07:46 PM | #27 |
07-26-2012, 09:11 PM | #28 | |
| Re: Ted's Lightweight Super Juice Quote:
07-26-2012, 10:57 PM | #29 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
You running it on saturday Ted?
07-26-2012, 11:22 PM | #30 | |
Rock Crawler Join Date: Sep 2008 Location: Marysville, WA
07-27-2012, 03:36 AM | #31 |
| Re: Ted's Lightweight Super Juice Hell yes. I also got a sporty built. And I rebuilt and changed my 1.9 setup. Still working on the XR, should be done with it by 3:30am. I got all 21 batteries charged already. First comp of the new season! going to be fun! It will be a challange trying to be competative in 4 classes, I think I will focus on the 2.2 and super mostly this year and just have fun with the shafty's. Its all fun, but you know what I mean. Sounds good. I will tear it down after the comp and bring you my cases. |
07-27-2012, 03:48 AM | #32 |
07-27-2012, 03:49 AM | #33 | |
07-27-2012, 08:06 AM | #34 |
07-27-2012, 12:05 PM | #35 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
And I'll get the pics! Super looks like a winner Ted. |
07-29-2012, 10:21 PM | #36 |
I ran the super at its first comp yesterday. It worked well. I am liking the light weight, climbed right up some stuff other guys could'nt. 6oz of knuck weight per side seems perfect. I need to order a pair of BRXL's for it becuase the FXR's wont hold it.
11-21-2012, 01:37 PM | #37 |
Figured it was time for an update. Nothing has realy changed, but it is all working well and holding up just fine. I did finaly get the aluminum rod balls and got those installed and have a new RTR weight of 6.37 lbs. I stilll have some steel hardware that needs to be replaced with titanium. And I still would like to change out the FXR's for some BRSL's to help with the rollback. And I am realy wanting a set of Infectious RC carbon wheels and some new super boss claws. My thinking is that with the carbon wheels I can possibly get down from 6 lbs, 6 oz to and even 6 pounds. Last edited by TedBull; 11-21-2012 at 01:45 PM. |
11-21-2012, 02:08 PM | #38 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
You won't regret the BR-SL's Ted, I just put a pair in my super and man , what a differance from the FXR's I had on my last super. I run 8 1/4" tall Moab Rovers with it weighing close to the 8lb. mark and it hold's it in place easily , I have the Holmes Hold set to on and the drag brake set to 50% and it's perfect. The FXR's I think are better suited to a 2.2 rig. |
11-21-2012, 05:59 PM | #39 | |
BTW Bob, how many super builds you got going right now? Any of them done yet? Good looking stuff you got going. | |
01-15-2013, 08:52 PM | #40 |
I made a few changes. 1. I followed the brilliant work of D-lux and swapped out my large 2nd Berg gears for large 2nd HR gears. (Thanks again Jeremey for trading your HR 2nds for my Berg 2nds). The HR gears are 52 tooth and 48 pitch compared to the berg gears witch are 42t and mod .6 pitch. The reduction in gearing is huge and just what I needed. Its nice being able to source 48p pinions easily. I am running 12t pinions. I only have a small amount of runtime on it so far around the house but can already tell the huge improvement in torque and drag brake. The gear swap was very easy. It only required cutting the spacer off the large 3rd and using loctite to hold the bearing onto the end of the small 3rd. D-lux has a full write up and how to in his super thread. 2. TCS had a sale on SDS 300 3rd gears so I picked up a pair and tossed them in when I did my gear swap. 3. I finaly threw on my new and improved D-lux CF upper link mounts. I ran his delrin mounts previously. They are spiffy. Lots of adjustability. 4. The 7980's went to Hitech for warranty. Both servos had issues with the spline shaft "wobbleing" a bunch. They replaced the middle cases on both servos and they are 100% again. 5. I got bored and decided to take the dremel to the blast wheels some more. I did it more for fun and looks than actual weight loss. It shaved a couple grams per wheel. They are still plenty strong and I have no concerns. Just hope I dont catch a stick in there. We have a comp this weekend and I cant wait to run her. The RTR weight is at 6lbs 4.8oz. Thanks for looking. . Last edited by TedBull; 01-15-2013 at 08:56 PM. |
