Ted's Lightweight Super Juice Hey guys. So after running my super bully 65:1 with BWD wedge chassis all last season I decided to change it up for the new season. My old setup was in the 9 pound range. New for the 2012/2013 season. Specs: *Chassis: Y-town CF Super Juice. *Links: Titanium custom links from my buddy Marc AKA "moes670". *Gearbox: Berg V1 with drilled stock gears, (Thanks JB), RC Bros lockers, Mann 2nd gears, and CKRC 3rd gears for now untill John's stock of SDS 3rds are availible. Dlux case cover. Dlux adjustable upper link mount. And case milled by Dlux. (thanks Erik). *Tubes: Dlux delrin custom offeset tubes with D-lux lower link mounts and Dlux servo mounts. Axial AX10 C-hubs with Bully machined knuckles. *Axle shafts: Bully XVD axle shafts modified in length and at the locker to fit this setup with berg cases. (These will be replaced with either VP shafts or SDS shafts soon I hope). *Shocks: 4" Big Bores lathed down by Dlux, Mini-T red springs all around, JeepinDoug spring cups, 27.5 oil all around. *Wheels/tires/foams: Blast wheels 1" shaved down, open cell nova 7.5" dual stage foams, 8" rovers with moab sidewalls. *Knuckle weights holders: Made by Sven to hold VP slugs. *Electronics: 1. Motors: Team Brood Vapor (lightweigth motors). 45t HHK arms, epoxy balanced, ground, polished, and dyed. lathed cans, lightweight endbell mods, ceramic bearings, team brushes and springs. (I also have new 45t GT arms with "the works" that I can try in these cans). 2. Servos: One Hitec 7980 on each axle. 3. ESC's: Dual Tekin FXR's decased and wired/shrunk down with a pair of CC bec's in there as well. Mounted on Rowdy tray. (I had fun with this). 4. RX: Nomadio 4ch reciever that is way too large. 5. Battery: Sky lipo 3S 800mah. Mounted on homemade mount. That is the basically all of it I think. It was a fun and stressfull build. I am pretty happy with it. It is done for the moment and ready for the comp in two days. I ran two packs thru it and it works well. Future plans are to get new axle shafts/knuckles, CF wheels, aluminum hollow rod balls when they come in stock, and some more titanium hardware to replace the little bit of steel that is left. Thank you to all the great vendors and to all the great people that made this build possible. "thumbsup" RTR weight with 12oz total of knuckle weight is: 6.36 pounds. |
Re: Ted's Lightweight Super Juice Dual FXR's, Two BEC's, One larger capacitor. Decased and consolidated by myself. They seem to be working fine. And I can still field program them if needed. http://i189.photobucket.com/albums/z...n/DSCF0425.jpg http://i189.photobucket.com/albums/z...n/DSCF0421.jpg Here is a pic of the AX10/Bully/Berg hybrid setup. http://i189.photobucket.com/albums/z...n/DSCF0417.jpg Here is the gearbox full loaded with upper link mount. (thanks again to JB for drilling the gears). http://i189.photobucket.com/albums/z...n/DSCF0404.jpg http://i189.photobucket.com/albums/z...n/DSCF0402.jpg And a pic next to his 4 pound baby brother. http://i189.photobucket.com/albums/z...n/DSCF0419.jpg |
Re: Ted's Lightweight Super Juice Wow, impressive list of parts. I hope to get mine done soon. |
Re: Ted's Lightweight Super Juice Quote:
Re: Ted's Lightweight Super Juice WOW!!! That looks good Ted! "thumbsup" Can't wait to see it this weekend! |
Re: Ted's Lightweight Super Juice Looking good! However, you are going to HATE that servo horn sticking up there like that. It will get hung up on any undercut you push the truck up against. Why not rotate the servo 90* and let it sit between the motor and tube? |
Re: Ted's Lightweight Super Juice Looks great! Does the upper link mount contact the ground before the servo horn? That is the only thing I could see being a problem. Why the desire to get rid of the knuckles and shafts? |
Re: Ted's Lightweight Super Juice I would also throw another screw in those shock mounts. You really need 2 screws as close to the link/shock mounting points as possible. The way you have it now, it will allow the mount to flex up just a touch and could possibly break next to the screw you have on top. If there are screws as close to the mounting points as possible, it does not allow the mount to flex at all. Hopefully that makes sense. |
Re: Ted's Lightweight Super Juice Great build or rebuild. Can you post picts of your battery mount? |
Re: Ted's Lightweight Super Juice Great Build TED"thumbsup" Looks like you used the same wide like the Superbullys??? should be around 14" track wide right?? |
Re: Ted's Lightweight Super Juice Looks very nice Ted! Can't wait to check it out Saturday. "thumbsup" |
http://i189.photobucket.com/albums/z...n/DSCF0426.jpg Quote:
Re: Ted's Lightweight Super Juice lol, how much does that battery mount way? -.2 oz? lol....nice build! |
Re: Ted's Lightweight Super Juice Very nice rig Ted "thumbsup", I just picked up a super juice myself, will run super Bully's though. Will be watching as you go. |
Re: Ted's Lightweight Super Juice Oh, and keep an eye on those upper link mount screws. They take a serious amount of abuse on roll overs which is awesome for the rest of your components, but after a couple rollovers they can become a touch loose. I throw a bit of super glue on my threads and that seems to help. |
I was unlucky and broke alot of stuff. But, most of that should not be an issue with the new truck with the AX10 C hubs, and l like you said the low weight. It is a great conversion and option, actualy The only option at this time right now. Nobody else has shafts availabe that will fit a super right now. :roll: I dont remember where I was at with the bully for track width? But with this setup I am 14 1/8" sidewall to sidewall. Quote:
