07-08-2013, 08:38 AM | #61 |
Rock Crawler Join Date: Mar 2009 Location: AZ
| Re: Rowdys Super Meat Sword
I run 11t or 12t one of the two. I'll check later. I would only run berg pinions.
07-08-2013, 08:38 AM | #62 | |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
| Re: Rowdys Super Meat Sword Quote:
I am running 10t in mine with my 45t stubbys. I am going to 4s to try to get some more power out of them. They are some I got from SDS along time ago, mod .6 pitch. Look forward to seeing this come together. Ty | |
07-08-2013, 08:40 AM | #63 |
You'll want Robinson Metric Pinions. I believe you'd be good with an 11-12t gear which would be either RRP1111 or RRP1112. x2 on 4S. Sky Lipo makes an 800mah 40C 4S that I've really enjoyed on my Super. Side note...GEEZ who said the Super section was dead...with 3 replies within 7 minutes |
07-08-2013, 08:51 AM | #64 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
https://www.tcscrawlers.com/robinson...erg-axles.html | |
07-08-2013, 09:04 AM | #65 | |
Robinson Racing Metric Pinion Gear 12T (Berg) | |
07-08-2013, 09:10 AM | #66 | |
| Re: Rowdys Super Meat Sword Quote: Is there a steel pinion option, I always split RR's when I tighten them. | |
07-08-2013, 04:27 PM | #67 |
Also I plan on running 1.25" wide YTC flat faced cf wheels, what hubs do you guys use for the flat faced wheels, .850's? Also what's a good shock oil starting point for scx shocks on a super, can't find info on that. Sorry for all the questions, I don't know anything about bergs or supers, all help is much appreciated. Last edited by ROWDY RACING; 07-08-2013 at 04:43 PM. |
07-08-2013, 05:14 PM | #68 |
| Re: Rowdys Super Meat Sword |
07-08-2013, 06:38 PM | #69 |
Rock Crawler Join Date: Mar 2009 Location: houston
07-08-2013, 06:42 PM | #70 |
07-09-2013, 04:50 AM | #71 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
X2 on sallys post. I've found the 1113 to be perfect for fit and drive.
07-09-2013, 06:50 AM | #72 | |
Dlux has the spacers you need. DLUX FAB | products | |
07-09-2013, 07:12 AM | #73 | |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Nats is the best place. You would be at worst 5th or 6th. If they have that many show up. | |
07-09-2013, 07:13 AM | #74 |
07-09-2013, 07:35 AM | #75 | |
They aren't aluminum, and they aren't steel...they're "Steel Alloy" | |
07-09-2013, 07:40 AM | #76 | |
Thanks for the help guys keep it coming, anything you guys think would be helpfull is welcome. | |
07-09-2013, 08:31 AM | #77 |
07-09-2013, 08:42 AM | #78 |
Don't forget the rear wheels turn too...
07-09-2013, 08:47 AM | #79 |
07-09-2013, 08:51 AM | #80 |
These are the wideners I run up front. Not sure which setup is better. You have to drill these out a little. And you also have to get a 6mm barrel nut from gmade I believe. https://www.ckrccrawlers.com/gmade-2...0442d945e86ab6 I also run the rear with the face on the inside and if I remember right I think I run a 335 hub and I'm sitting at 13.5" width front and back. |
Rowdys Super Meat Sword - Similar Threads | ||||
Rowdys Trail Comp Wraith | ROWDY RACING | Axial Wraith | 185 | 03-30-2015 10:28 AM |
Rowdys XR, BJV4, SA, Now Team Y-Town "Double Agent" | ROWDY RACING | Axial XR10 | 888 | 06-14-2014 07:50 PM |
Forging He-Man's Sword | BUBBA069 | Chit Chat | 2 | 03-19-2013 09:32 AM |
New meat! | jadama | Tamiya CR-01 | 3 | 06-14-2011 09:14 PM |
