01-18-2013, 06:31 PM | #61 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Mad torque build, cheap and easy
Do the small berg gears not work with the exceed large gears?
01-18-2013, 06:46 PM | #62 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
They work, they're the same pitch. The exceed gears use a larger pin though. Got my new wheels in the mail today, kyosho monster truck wheels with a 17mm hex. They're not 40 series though unfortunately, they're 3.2. They didn't specify which size they were so I knew it was a gamble, I'm alright with them bein 3.2 though. The tire stretches on them fairly easy but it balloons them a little, as soon as I narrow the wheels the ballooning should go away and I'll be happy. They're lighter than the stock wheels so that's a plus too, stock wheel is 2.5oz and these are 1.5oz. Pics Pic of my steering, about 45 degrees. It's as much as you can have with the stock axle shafts Last edited by Nimyad; 01-19-2013 at 12:38 PM. |
01-19-2013, 08:05 PM | #63 |
Narrowed my wheels today, I discovered the glue was insufficient so I used 6 m3 screws per wheel to hold them together. Narrowed them from 2.25" to 1.75" and now I don't have any steering clearance issues. Then screwed around on our course today and broke an axle shaft pin, luckily I have spares! Also if you have any interest in running mad torque axles look at this thread and tell him you're interested. Berg small gears are an absolute must to make these axles survive under a super! New gearbox and gear options Last edited by Nimyad; 01-19-2013 at 08:08 PM. |
01-20-2013, 09:20 AM | #64 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
Has anyone tried to use bully knuckles and xvd shafts in one of these? An Axial c-hub will fit a bully knuckle. Probably have to be cut down but that could make these strong enough to hold up to the abuse of super duty. They are also reasonable a far as cvds go. And that would also allow you to run about any hex you wanted. Are the lockers the same as the berg as well? Another question, Could somebody post a weight of the MT gearbox with gears in it? Just case and gears. Thanks. |
01-20-2013, 10:49 AM | #65 |
Bully axle and berg axle shafts are to long to fit in a mt without using different tubes. The berg lockers have a different bolt pattern than the mt so you have to drill out the 4th gear to use a berg locker. If you read the link I posted in the post above yours you'll find the weight information you're after. |
01-20-2013, 01:10 PM | #66 |
Sweet. Thanks. Super light! You could cut and grind the tang on the bully xvd to fit into the MT locker. And cut them to length just like dlux has em for bergs. |
01-20-2013, 01:12 PM | #67 |
Yes you could, I'd rather do dlux tubes and sds 300m shafts though.
01-20-2013, 01:45 PM | #68 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: Mad torque build, cheap and easy |
01-20-2013, 02:37 PM | #69 | |
| Re: Mad torque build, cheap and easy Quote:
Im gonna have to get me one of these to build. Fun on the cheap. As for the HH brxl esc, Its flat out awesome. I love mine. And the Holmes hold is second to none in the drag brake department. | |
01-20-2013, 03:04 PM | #70 |
No doubt about it being super expensive. I was just giving the basic idea, I'll probably just make my own tubes out of delrin and run stock berg shafts with ax10 inner c's and knuckles. Then for gears run an sds berg 3rd and the rest stock mt gears, with a berg locker of course. As for the brxl, it's on my list of things to get. I'm not getting it until my stock esc dies though. |
01-20-2013, 07:48 PM | #71 | |
Good thinkin! | |
01-20-2013, 07:53 PM | #72 |
So are you saying keep the stock tubes and run bully shafts and knuckles, or different tubes? Why couldn't you just run bully shafts and cut them down?
01-20-2013, 08:15 PM | #73 | |
What I was getting at is it would be possible to keep your stock tubes, cut some Bully super shafts down, run a Bully knuckle and youre good to go. You could do front and rear for $100 and you would have a pretty bulletproof axle setup, just address the stock 3rd gear and I bet you could party on those axles pretty hard. My only other concern would be the tubes and breaking the plastic C off. You could just replace them since they are so cheap or you could upgrade to better tubes down the road if its a problem. The Bully knuckle is really easy to put knuckle weights on too. | |
01-20-2013, 08:27 PM | #74 |
Interesting, I'll definitely look into it. Is there no way of using bully axles with ax10 knuckles? I already have a couple sets of aluminum ax10 knuckles, that's why I ask. If it'll seat correctly I could see drilling/machining out the mt hub so I can keep the same width and run the stronger axles. |
01-20-2013, 08:32 PM | #75 |
Bully knuckles are drastically different from AX10 stuff. Running a Bully knuckle would also probably be great because they have a bunch of width built into them, then you could also ditch those huge hex spacers and run something more proper and stronger. |
01-21-2013, 08:24 PM | #76 |
Screwed around a little tonight. I need to limit my flex and my steering, or run bully knuckles and shafts. My steering likes to bind at full lock and it screws me up. I also want to make a 4 link in the rear at least. |
01-26-2013, 12:34 PM | #77 |
Got material for a new chassis today, I'm hoping when it's done I'll be rtr at sub 6lb 1/8 delrin (chassis), 1/4 delrin rod (brace the hell out of my chassis), 3/8 delrin rod (links and steering) |
01-28-2013, 12:51 AM | #78 |
Quarry Creeper Join Date: Mar 2011 Location: norcal
Can't wait to see what you've got planned for this beast.
01-28-2013, 12:18 PM | #79 |
Next is a chassis and 4 links front and rear, but I'm kinda at a stand still right now. I can't decide exactly which way to go with my chassis. Also my servo took a crap so I'm waiting for a new one.
01-28-2013, 04:51 PM | #80 | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/superclass-crawlers/418316-mad-torque-build-cheap-easy.html | ||||
R.I.P Bobby Long | This thread | Refback | 02-27-2013 08:47 PM | |
Lets see your rc crawlers | This thread | Refback | 02-23-2013 10:36 AM |
Mad torque build, cheap and easy - Similar Threads | ||||
Exceed Mad Torque - Extensive Review and build thread | monkeyracer | Superclass Crawlers | 96 | 06-25-2016 07:55 AM |
Exceed Mad Torque Super Build | motoj550 | Superclass Crawlers | 38 | 10-22-2013 05:13 PM |
Exceed mad torque Build | dannymac | Superclass Crawlers | 17 | 01-30-2013 07:17 PM |
New To RC, Exceed Mad Torque Build | woodsracer | Superclass Crawlers | 17 | 11-08-2012 11:49 PM |
Brat Build(easy,cheap)(new rear bumper!!) | rebel35747 | Axial SCX-10 | 41 | 03-12-2012 01:01 PM |
