07-16-2013, 09:23 PM | #21 |
Newbie Join Date: May 2013 Location: broomfield
| Re: new to mad torque and rc crawling
[IMG] save for a plastic folder on the back to cover wires, stage one is complete of my super torque... Everything is stock driveline wise, except for knuckles. And I have about $50 into the build so far... Next stage is new radio 4-steer and other stuffs. So now I bash!
07-17-2013, 11:33 AM | #22 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
I highly suggest you switch to berg gears front before 4 wheel steer and a new radio. Especially since you're running wheel weights.
07-19-2013, 04:27 PM | #23 |
| Re: new to mad torque and rc crawling |
07-19-2013, 09:20 PM | #24 |
| Re: new to mad torque and rc crawling For me, with weights like that just in the front I toasted a small 3rd the first time I wheeled it moderately hard. With no weights and stock tires they lived, with cut and shut tires they broke easily in the front. They've lived in the rear though.
07-19-2013, 09:55 PM | #25 |
They have survived. Two trips so far, so I'll see how long they last I guess. I am kind of light on the trigger finger, and am hoping they last till stage 3 wich is 40 series wheels and new motors and axels. (Fingers are crossed)
07-20-2013, 12:01 AM | #26 |
I run the jconcept wheels, they're cheap and super light for a 40 series. If you do motors those gears and shafts will die. What axles are you planning?
07-20-2013, 05:32 PM | #27 | ||
| Re: new to mad torque and rc crawling Quote:
07-20-2013, 06:09 PM | #28 |
| Re: new to mad torque and rc crawling https://www.youtube.com/watch?v=4RaV...e_gdata_player. Just a link to video, I'm still learning how to post stuff correctly... |
07-20-2013, 08:34 PM | #29 |
| Re: new to mad torque and rc crawling Well rc4wd is the only place that sells bully. But for what it's worth, mt axles with berg gears and narrowed axles are going to be cheaper and lighter than bully axles. Also since they're lighter your rig will handle better and be more agile than a bully axle rig. |
07-21-2013, 09:35 PM | #30 | |
08-11-2013, 06:52 PM | #31 |
| Re: new to mad torque and rc crawling https://www.youtube.com/watch?v=2Zdw...e_gdata_player a quick line I found flexing the crap out of this thing... Some how I got the suspension to only flex when it is needed, but to lift a wheel when it is necessary too...
08-11-2013, 06:54 PM | #32 |
| Re: new to mad torque and rc crawling https://www.youtube.com/watch?v=8wZG...e_gdata_player. Another quick vid of some bashing, I was trying for wheelies down the drops but oh well.
08-11-2013, 06:59 PM | #33 |
| Re: new to mad torque and rc crawling https://www.youtube.com/watch?v=Z3Jb...e_gdata_player. I'm pretty sure this constitutes reaching for the sky.
08-12-2013, 03:13 AM | #34 |
Rock Crawler Join Date: May 2012 Location: Australia
for what it's worth, with some creative work you can shave 200gr out of the bully axles. My super bully axles weigh about 300gr. Drilled gears,shaved gearbox, delrin tubes. |
12-10-2013, 09:35 AM | #35 |
[IMG][/IMG]. Extra servo maximizer wheels and hpi Terra pin wheels..
12-10-2013, 09:40 AM | #36 |
[IMG][/IMG]. So where do all the torques crawll in Colorado? I'm currently rebuilding links but should be up again soon. |
12-10-2013, 05:05 PM | #37 |
I'm so cheap I found this 1/4 inch copper pipe at Lowes... 5' for $8.. All thread 3' for $1.20 but hwy it works.. With the$0.25 worth of scrap 1/4 plexi... That's a new four link and battery trayfor under ten bucks... Well I had to order more rod ends so that will be $20 for shipping [IMG][/IMG]
12-10-2013, 05:08 PM | #38 |
I got bored waiting for parts and put the led light kit the MT came with in just for kicks. [IMG][/IMG]
12-14-2013, 08:03 PM | #39 |
Thanks man, it's killing me not being able to run it...
03-22-2014, 11:59 AM | #40 |
If anyone is out there I. Am in need of some advice... I recently swapped in a set of 27t motors going for more of a rock bouncer thing instead of crawler... so far It is a ton of fun and has broken just about everything on the rig. Now that I have rebuilt it to handle the extra speed and power my esc has burned out. Can someone recommend a descent upgrade that can handle an eventual switch to Lipo and doesn't. Cost $200. |
new to mad torque and rc crawling - Similar Threads | ||||
not another mad torque | MMjeep | Superclass Crawlers | 20 | 05-06-2012 08:40 PM |
My Mad Torque | XtrmTJ | Superclass Crawlers | 22 | 12-29-2011 07:32 PM |
