05-24-2013, 06:37 PM | #1 |
Newbie Join Date: May 2013 Location: broomfield
| new to mad torque and rc crawling
Finally. Broke down and bought a mad torque as a cheap way to get into the rccrawl game. I can not afford to fix my 1:1 scale jeep anymore so my question is... has anyone compiled a list of compatible parts for the torque? I have ax10 knuckles. On order a better servo and arm are next but what about cvd axles And other parts??
05-24-2013, 09:41 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| Re: new to mad torque and rc crawling
You could shorten bully shafts and run those, there's nothing that goes right in. You can run all berg gears with dlux's adapters. Everything else is universal parts.
05-25-2013, 12:17 PM | #3 |
Cool thanks. Those berg axels looked so similar I was hoping the torques. Were a carbon copy in plastic molding .. oh well
05-25-2013, 12:36 PM | #4 |
New age enroute 2.2v1 berg axles to be specific...
06-01-2013, 12:54 PM | #5 |
I'm probably going to start posting pics of my rig so I can get some ideas, but my question now is if I can Cut-n-shut my wheels only then cut new foams to get slightly skinnier and taller wheel? Then if I want to cut wheels I can do that later... |
06-21-2013, 07:23 PM | #6 |
Ahhh crap I can't figure out how to add pics from my phone!!! I'm right in the middle of my first bodyless chassis build and my first wheel cut-n-shut. Not sure I want to waste my time transferring pics to computer?
06-27-2013, 01:02 AM | #7 |
Download the photobucket app and use that to post pics.
07-14-2013, 07:08 PM | #8 |
thanx, I'll do that. I just broke down and hooked up the lapper for this round...
07-14-2013, 07:53 PM | #9 |
[IMG][/IMG]. Were my super tourqe started life
07-14-2013, 08:00 PM | #10 |
[IMG][/IMG] strc aluminum knuckles... Only wish I got some High steer ones instead. |
07-14-2013, 08:03 PM | #11 |
[IMG] removed some tread blocks and spied the others for some more grip and flex
07-14-2013, 08:08 PM | #12 |
[IMG] my bodyless chassis design on some super cheap lexan. This stuff was just for a test run, but I found a way to stiffen it up and ended up keeping it.
07-14-2013, 08:12 PM | #13 |
[IMG]. Cut and shut the wheels to loose 10mm of width
07-14-2013, 08:15 PM | #14 |
[IMG]. Found this foam at hobby lobby super soft and good choices of width... I went with two inch thick.
07-15-2013, 05:40 AM | #15 |
[IMG]now here is the pic of the finished wheel
07-15-2013, 05:43 AM | #16 |
[IMG]and the lexan body being cut
07-16-2013, 08:18 PM | #17 |
[IMG] cut out and holes drilled
07-16-2013, 08:23 PM | #18 |
[IMG] the Lowe's guy gave me a chunk of this 1/4 inch plexi stuff out of the scrap pile for free, so I made my skids and body panels out of it to stiffen up the body, and it worked like a charm.
07-16-2013, 08:29 PM | #19 |
[IMG] picked up a plastic folder from wallyworld for $0.50 for side panels..
07-16-2013, 08:35 PM | #20 |
[IMG] my new favorite thing is painting the inside of the panels so the paint doesn't scratch and you can see the threads from tapping.
new to mad torque and rc crawling - Similar Threads | ||||
not another mad torque | MMjeep | Superclass Crawlers | 20 | 05-06-2012 08:40 PM |
My Mad Torque | XtrmTJ | Superclass Crawlers | 22 | 12-29-2011 07:32 PM |
