Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: 1/8 scale Custom Crawler
Old 09-14-2013, 12:39 AM   #1
Default 1/8 scale Custom Crawler
Ok guy's i have been thinking about doing this for a long time ........
This was my old Nitro Truggy that was turned into Brushless and now it's going to be transformed into a Big Crawler, im not sure on the wheel base yet and im not sure where im going to go with this so it will just evolve along the way.....
I will need a transmission and some drive shafts that will fit the 8mm outputs on the diff...... I'll make the skid and links out of Delrin.....
This is what i have to start with
icrawl2 is offline   Reply With Quote
Old 09-14-2013, 12:43 AM   #2
Default Re: 1/8 scale Custom Crawler
This is what's left to work with, i need to lock up both diffs....
Locked up the front arms on a slight angle to give the center diff some ground clearance, also swapped over the steering blocks so the steering links will be out in front, i might try BTA later.....
Old 09-14-2013, 12:47 AM   #3
Just trying to work out the best wheel base
This is at 15 inches
And this is at 17 inches
Might go with 16 inches
Old 09-14-2013, 09:20 AM   #4
very interested to see where this going!
Jake Ewing is offline   Reply With Quote
Old 09-14-2013, 07:38 PM   #5
Just need to pick up a tranny, not sure what to get yet either..... might just use a Axial scx10
Old 11-29-2013, 07:47 AM   #6
Gold Star Baby!
vwmopar's Avatar
a summit 2 speed would be sweet.
vwmopar is offline   Reply With Quote
