Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Like Tree82Likes
Thread: Tom G's 1st Super Bully Build
Old 06-06-2016, 05:52 PM   #41
5th D Owner/Driver
cboggs's Avatar
Default Re: Tom G's 1st Super Bully Build
Originally Posted by Tom G View Post
Did U build/buy a new set of S/xr's or acquire them from PaPa boggs
Kinda both, I built another XR set for pops.
cboggs is offline   Reply With Quote
Old 06-13-2016, 10:45 AM   #42
Tom G's Avatar
on the Super XR-10's Chris Hope they held up for Ya at Best of the West last weekend
If these new Dlux case's don''t fix the gear issues. I'll go back to stock Berg gear cases. I never had any issue's with those old heavy junkers. All the gear problems started when I to the latest & greatest TRICK LIGHT WEIGHT STUFF.
GOOD THING I HAVE A LARGE HOARD OF BERG & SD small 2nd/3rds GEARS
I've run 6 Packs testing and flogged the crap out of them no issues so far
CREEPERBOB likes this.
Tom G is offline   Reply With Quote
Old 07-13-2016, 03:53 PM   #43
Couple pics of Tom's whip from last nights practice session:
And the carnage:
Diamond D and mammoth like this.
VMGontheRocks is offline   Reply With Quote
Old 07-13-2016, 04:24 PM   #44
Tom G's Avatar
Originally Posted by VMGontheRocks View Post
Couple pics off Tom's whip from last nights practice session:
And the carnage:
OUCH my Trusty OLE RELIABLE Brood Vapor with a little BOOBOO
Who da thunk it couldn't stand a 15ft fall playing basket ball of pointy rocks bending the can 1/16 out of round
Just the excuses to switch back to the brood SISU's
CREEPERBOB and gonper like this.
Old 08-11-2016, 12:00 PM   #45
Tom G's Avatar
DLUX SAF Berg Gears
Got a chance to run these new gears in my Super last night NICE and quite. Dlux 26 grams RC4WD's 37g 11 Grams lighter . Both using RCB Alum. lockers Not to mention being able to use 48 pitch pinions!!!!!
Long Live BERG'S now that gears will be available agn Nice work Erik Dlux & Robinson Racing
Old 12-21-2016, 04:36 PM   #46
Tom G's Avatar
Winter boredom set-in so decided to do some preseason maintenance on all the crawlers..
1st up was the Super tore it completely apart for the first time (other then routine maint.), replaced all the bearing in the drive train and servos
No real major changes except for a new match pair or Brood 35t Confux's with the works Really liken these guys. tnx Eddie
Also after running Dlux / Robinson-Racing SAF gear's and love-en them , thought I'd try his new lower ratio gears. Wow what a difference in torque and and way smoother throttle response. Dam I've never run gears then run so quite TNX Eric & RR
Rebuilt the shocks. I really like the KYOSHO Red Velvet's Diamond D talked me into a couple yrs ago they never ever LEAK and are as smooth as Butter
Have not decided yet but thinking of changing the 4 link Bias from 45/55 to 40/60 But then again why tempt fate
On to the Sporty and PRO
Old 10-06-2017, 05:18 PM   #47
Tom G's Avatar
Default Re: Tom G's 1st Super SuDu Build
So after my 3rd back surgery in 2 yrs the feeling in my is right foot back to about 80% ( caused by being rear ended on my motorcycle)
While recuperating and out of pure boredom decided to try a new chassis on the Super I picked up a DravTech Super SuDu and a set of Tobias's shocks to replace the always leaking big Bores.
Made a new set of Ti link's 3/16 front & uppers 1/4 rear lowers for a 40/60 bias wheel base .
I've had a chance to get it out on the practice pile a couple a few time's and after some link an shock tuning I Darn happy with the performance.
I guess this can be considered a new truck so here are the basic Spec.
DravTech Super SuDu Chassis and shocks TNX Tobias
Ti 4 links by me
Modified Delrin Skid by me
Axles
Dlux Replacement Cases with Dlux/Robertson SAF Low ratio Gears TNX Erick
Super 300 CVD's
Axial style Splined 7075 T-6 with clamping link shock,servo & battery mounts by me
Axial 8 deg. Scale Clamping C hubs
Dlux Aul. knuckles with my front & rear Knuckle weights
Dlux 6" G-10 Wheels with 8" Cut- n Shut VooDoo's by me
Electronics
Matched pair of
Brood Conflux's with the works Tnx Eddie
HH Dual BR Dual Mini ESC
Hi-tech 7980 servos
Futaba TX/RX
Nova's Ark and gonper like this.
Old 10-06-2017, 08:23 PM   #48
Nice!!! That’s a good looking super.
stubs179 is offline   Reply With Quote
Old 10-09-2017, 02:05 PM   #49
why did u change Brood Sisus to Brood conflux?
Juuti is offline   Reply With Quote
Old 10-09-2017, 03:20 PM   #50
Tom G's Avatar
Actually sold the SiSu's quit some time ago wanting smoother throttle response and Switched to 30T Vapors which were OK but not as much power an prone to stalling when the 8" tires were wedged-in a notch .
Last yr the truck had a fall of a 20ft cliff and the rear motor landed on a pointy rock bending the motor can and broke a magnet.
At that time Eddie was out of stock on SiSu's . cboogs really liked his Conflux's so picked up a pair of loaded 35T Conflux's and more then happy with them. Just as much power and wheel speed as the SiSu's ,but way way smother throttle response.
Juuti likes this.
Tom G's 1st Super Bully Build - Similar Threads
1st crawler build RC4WD BULLY bdth9447 General Crawlers 11 10-01-2013 03:44 AM
My 1st bully build! sococrawler RC4WD Bully 12 04-23-2010 01:04 AM
4th and G's "Pinch Yo Sack Pimp" Bully Build Kraqa RC4WD Bully 30 04-01-2010 09:50 AM
Mr G's Super Bully with RIB! Mr Glassman Superclass Crawlers 25 01-21-2010 03:10 PM
1st super build hiperbeast Tamiya Clod Buster 11 07-09-2009 09:26 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
