Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: bully or bully 2?
Old 03-02-2014, 07:23 PM   #1
Default bully or bully 2?
I've finally had enough repairing clod axles. I need to upgrade. I dont compete but would like to have a reliable crawler with a decent setup. Tell me why I should spend $80 each ($160) to get bully2's instead of the regular bully?
redneckracerx is offline   Reply With Quote
Old 03-02-2014, 07:31 PM   #2
Default Re: bully or bully 2?
It's like comparing a Lamborghini to a Pinto.
ROWDY RACING is offline   Reply With Quote
Old 03-02-2014, 07:45 PM   #3
Get the first version if you're not comping, the 2's have lots of improved features like width, weight, clocking the hubs etc. If you don't need all that then 1st version will save ya some money and they're really durable. I've comped a set of em for 3 years with no breakage of anything.
sellenk is offline   Reply With Quote
Old 03-03-2014, 05:27 AM   #4
Are you wanting a super or 2.2? There aren't any super bully 2's available yet
Erin is offline   Reply With Quote
Old 03-03-2014, 06:08 AM   #5
Sorry, I should have specified. Yes, its a super. I see that the bullies are 11.xx wide. I know wider is better, but at what point is it too wide?!
Old 03-03-2014, 07:02 AM   #6
Shoot for a 13-14" track width tire to tire
Old 03-03-2014, 08:08 AM   #7
Track width is measured at center of tread right? Also, I'll be redoing my links I'm gonna stretch it out to 17.5" currently at 16".
Old 03-03-2014, 09:38 AM   #8
No, outside of tire to outside of tire
Old 03-03-2014, 10:11 AM   #9
Wanna get? Gotta want.
Erik D_lux's Avatar
Interesting question that I had not thought of.
I think it depends on your end goal.
Stock vs. stock, the V2 is going to be a better axle but more expensive.
Fully built vs fully built, I think the V1 will outshine the V2 but now the V1 will probably be quite a bit more expensive.
Erik D_lux is offline   Reply With Quote
Old 03-03-2014, 10:22 AM   #10
What do you mean by v1 vs v2?
Old 03-03-2014, 10:29 AM   #11
Erik D_lux's Avatar
Bully 1 and Bully 2
Old 03-03-2014, 10:51 AM   #12
Ah, well, that's only going to happen if they give us a long side for the short side or an entire axle. The tubes are side specific
Old 03-03-2014, 11:13 AM   #13
Erik D_lux's Avatar
Yeah, sorry, that was taking the assumption that they were going to provide a longer short side.
Old 03-03-2014, 11:16 AM   #14
We are pushing for them
Old 03-03-2014, 01:38 PM   #15
Hopefully some one is going to make some delrin tube for these things. Hint Hint!
josh6575 is offline   Reply With Quote
bully or bully 2? - Similar Threads
Bully Axle Help For Bully/Wraith Mikey307 RC4WD Bully 3 03-29-2013 07:49 AM
