02-23-2015, 01:03 PM | #21 | ||
DravTech Join Date: Aug 2012 Location: Sweden
| Re: Dravpnir tries to build something Super big Quote:
The links should work quite well and those wheels in orange would look, well super! Why can't my projects never go as I plan... I will not lathe any new tubes after all... One conversation that took an unexpected turn and some fast shipping from Switzerland totally screwed everything up... Oh well... I guess it would be bad to complain... .... | ||
02-23-2015, 03:22 PM | #22 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
looking good as always........
02-24-2015, 06:43 AM | #23 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Skins designed up! |
02-24-2015, 08:10 AM | #24 |
looks just like youre 2.2pro skinz,,,, same theme,,, 3 KRONOR!!!! He he he... So Swedish that it is no doubt where you are from,,,, And only a team brood and dlux logo,,, do you know what kinda motors that would be great for my superlites axels from dlux with youre sudu chassis??? Eddie told me to make my own conflux with a .020 thick can and a HHK-ST armature with quad magnets,, 30T, Maby I want some more wheelspeed,,,like 27T or maby even 25 or buy the nexus,, that is what he said was the replacement for his stubby motor,,, |
02-26-2015, 01:43 AM | #25 |
Yes, when I get some 7075 centers and at some point 7075 knuckles for it they will look very much the same, just difference size. I have the same theme on my sporty body and MT4 transmitter too Why do you ask which motors you should run for your 2.2 moa in a Super thread? Sorry, but I am not a big fan of out of topic discussions in my build threads. For this super I will run my 30T HHK-ST Conflux motors with cobalt magnets. I will use a 11T poinions to try to reduce the speed a bit. |
02-26-2015, 05:12 AM | #26 |
RCC Addict Join Date: May 2012 Location: Folsom
Im considering the same for my super... motor wise any ways.
02-26-2015, 08:31 AM | #27 |
You would be foolish to run anything but Cobalt magnets in a super, IMHO. Pretty sure you own more Dlux knuckles than I do now... |
02-26-2015, 02:00 PM | #28 | |
| Re: Dravpnir tries to build something Super big I am a bit worried that my motors are a bit too fast. I tried the 11T pinion tonight but it couldn't mesh properly so I have to use a 12T pinion instead. In worst case I just have to change the armature. Quote:
The final major part for my super arrived today Then I got time to test assemble the front axle. It still need some more work but I like what I see | |
02-26-2015, 03:40 PM | #29 |
RCC Addict Join Date: May 2011 Location: at home
what gears are you using on the servo? 24-96? hard to count from that picture haha how much of the original axles are you using? as always what you make is a work of art |
02-26-2015, 03:45 PM | #30 |
So jealous right now...... a few more days and one assignment....
02-27-2015, 01:27 AM | #31 | |
I didn't order the axles from Dlux, but bought the axles unused and unassembled from another person. Tbh I really do not know which gears there are, but I guess it is the standard 24T/48T combo? I can try to count the teeth number next time I go down to the hobby room. The only upgrades I will do to the new axles before I use them is to swtich out the delrin centers to 7075 centers and replace the aluminum hubs with some stainless 0-offset hubs. Right now I do not use any of the parts from the old super axles. I have been thinking of, someday in the future, to use the sds small gears with RCBros LW big gears for this rig instead of the rc4wd gears that are in the cases atm. If someone is interested I can sell my old axles minus the knuckles/chubs and with new unused rc4wd gears. That sound intriguing, I will keep my eyes open for a build thread | |
02-27-2015, 08:12 AM | #32 |
what is the point off taking off the casetop`s to on the hitec 7980`s???
02-27-2015, 08:18 AM | #33 |
I havent removed anything from the servos. The brass gear is mounted where you normally mount your servo horn. The extra gears makes the servo twice as strong but also twice as slow.
02-27-2015, 08:21 AM | #34 |
okay,,,that explaines alot,,, |
02-27-2015, 11:41 AM | #35 |
| Re: Dravpnir tries to build something Super big This picture stresses me out. LOL. It makes me cringe every time I see a steering link spaced off the top of the knuckle arm. I used to break my steering bolts that were spaced up like that on my 2.2. Mix in over 1200oz of steering power... On top of that, your steering links will really want to be even higher to get nice straight lines for that steering strengthener. Here is what I am going to send you, that I also use so I dont have to stress out every time I read this thread. |
02-27-2015, 12:07 PM | #36 |
what kinda foam are you using here?? Looks lika pillow..he he he |
02-27-2015, 02:28 PM | #37 | |
Thanks a lot Erik The foam is the CI outer super foam. | |
02-27-2015, 08:26 PM | #38 |
Rock Stacker Join Date: Dec 2008 Location: Phoenix
Stack one more CF plate and another delrin spacer and both links will be double shear. Love this build!! It has inspired me to build. Thank you.
02-28-2015, 02:04 AM | #39 | |
Erik, have you ever thought of trying out that steering geometry you use on your 2.2 Berg but on the Super? | |
12-05-2015, 09:04 AM | #40 |
I have been really slacking on updating this thread... But now after the first comp with the super I need to write something I guess It was fun to drive it although it ended up with a last place for me at EuroCrawl. David511 double started with me and ended up at third place, so it cannot be all bad Congrats David! Nothing much is new on it, but I made some weight holders that I received just before going to EuroCrawl. At the comp site I noticed that the rear holders were grinding on the wheel hubs so I took them off. I still use the aluminum hubs in the rear which has a bigger outer diameter than the stainless ones... doh! Front holder with maximum weights I forgot to take pictures during the competition but The Lizard managed to take a few photos of the super. david511 going for the podium! |
Dravpnir tries to build something Super big - Similar Threads | ||||
Dravpnir tries to build something Berg-ish from the scrap box | Dravpnir | EnRoute Berg | 20 | 03-04-2015 08:01 AM |
Dravpnir tries to build something all weather fun | Dravpnir | G-Made Crawlers | 27 | 02-04-2015 07:30 PM |
Dravpnir tries to build something small | Dravpnir | Losi Mini-Rock Crawler | 221 | 11-10-2014 02:28 PM |
Dravpnir tries to build something even lighter | Dravpnir | EnRoute Berg | 88 | 08-03-2014 02:58 PM |
Dravpnir tries to build something light | Dravpnir | EnRoute Berg | 125 | 04-23-2014 06:01 AM |
