05-31-2018, 03:47 AM | #41 |
Pebble Pounder Join Date: Jan 2018 Location: Spain
| Re: super time
Interesting, why are you printing the gear boxes that way? You are suppose to rotate them so the flat part is touching the build plate. Maybe is my mistake and i should upload the STL files parts on the correct printing orientation. As well the tolerances are important so I am going to create a calibration/tolerances test piece, so people can check their machines before printing. Last edited by gonper; 05-31-2018 at 03:49 AM. |
06-01-2018, 10:04 AM | #42 | |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: super time Quote:
I printed them upright to get clean surfaces where the bearings sit. | |
06-01-2018, 10:15 AM | #43 |
| Re: super time |
06-01-2018, 11:21 AM | #44 | |
I haven't tried bearings in it yet so I don't know but with that section pointing up it gives a great finish. I'm guessing it's all for knot anyhow if you are going to redesign for different gearing. I sure like your design and think it will do good work once it is all dialed in . | |
06-02-2018, 04:21 PM | #45 |
| Re: super time
I know that the printing of that gearbox part failed due a power cut. But looking close to your printing pictures I can see that is has a big layer shift on the Y axis at the begging of the print. I got an Anet A6 (almost the same as your Anet A8 ) and had the same problem. I fixed it reducing the travel speed to 110mm/s or less and travel acceleration to 4500mm/s2 or less. I think this issue is provably caused due to low current to the stepper motors but did not had time to check that out yet... Last edited by gonper; 06-03-2018 at 04:51 AM. |
06-03-2018, 05:57 AM | #46 | |
Yea I was trying to figure that out. Actually it is happening to the support layer, it shifts about 2.5 'mm but the main gearbox doesn't have the shift. | |
06-03-2018, 06:12 AM | #47 |
| Re: super time Actually I can see that the gearbox does have the shift as well, but it is difficult to see on the picture as there is little part printed at that high.
super time - Similar Threads | ||||
Super Supercapsitor: our next RC battery? 60 second charge time | STANG KILLA SS | Chit Chat | 11 | 03-29-2017 08:33 AM |
An Evil Super Bully build... time for a different chassis... | EvilTwin v2 | Superclass Crawlers | 4 | 10-05-2011 12:43 PM |
