Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: super time
Old 01-28-2017, 05:20 AM   #21
Yashua
CREEPERBOB's Avatar
Default Re: super time
Originally Posted by CM9000 View Post
soo, whats next??? are you going to trace the flange for the short side and just make it longer? or could you use some old long tubes and just machine them? curious to what your plans are.
I've got a couple super Bully axles and a couple extra tubes as well.
I've did some milling to these flanges trying to get the shape figured out (what cuts to do first) . I've got a few feet of 1" o.d. 7075 aluminum rod to do the final tube work.
Then the 3 feet of grade 5- 1/2" Ti rod but need to finish the tubes before I can get final dimensions for the axle shafts.
As soon as I get something cut that isn't embarrassing I'll post up .
CREEPERBOB is offline   Reply With Quote
Old 02-28-2017, 09:49 AM   #22
Yashua
CREEPERBOB's Avatar
More stuff. Waiting on a couple FXR's and 45 turn motors.
If I don't get any better results this may turn into a 2.2 pro rig.
Old 03-04-2017, 06:26 AM   #23
Yashua
CREEPERBOB's Avatar
A little more electronics ,
Ordered 2 @12" x 24" x 2mm and 1 @ 12" x 24" x 2.5mm carbon fiber sheets twill layered 3K.
I have no idea how to cut it yet but hey, gotta try some.
Old 03-07-2017, 06:32 AM   #24
dremel should work. just wear proper ppe.
CM9000 is offline   Reply With Quote
Old 03-14-2017, 02:30 PM   #25
Throw in in the milling machine Hi speed E-mill''s work ok but carbide last a lot longer
Tom G is offline   Reply With Quote
Old 03-15-2017, 05:13 PM   #26
Yashua
CREEPERBOB's Avatar
I ordered a couple Amana 1/8" solid carbide spiral router bit #46260.
I can't get the speed required for these but I'm gonna give them a try.
Old 03-15-2017, 05:56 PM   #27
These are what u want. Is what i was told form a guy makes tooling bits
richardgarrett56 is offline   Reply With Quote
Old 03-16-2017, 03:15 AM   #28
Yashua
CREEPERBOB's Avatar
https://www.amanatool.com/pub/media/.../4/6/46260.jpg
This is what I ordered.
Old 03-16-2017, 10:45 AM   #29
Just slow the IPM feed rate down they work just fine
Old 03-24-2017, 11:55 AM   #30
Yashua
CREEPERBOB's Avatar
This is in addition to the 3 sheets I already received above.
Coming, 2 @14mm x 12mm x 500mm,
2 @ 12mm x 8mm x 500mm, and
2 @ 12mm x 10mm x 500mm carbon fiber roll wrapped tube and a sheet of 1.5mm x 200mm x 500mm twill weave carbon fiber.
Have no idea what will surface from this.
Old 03-24-2017, 02:14 PM   #31
a graphene battery wielding super????
Old 04-07-2017, 11:53 AM   #32
Yashua
CREEPERBOB's Avatar
Man that boat from China is slow.
Old 07-03-2017, 06:53 AM   #33
Yashua
CREEPERBOB's Avatar
This thread is a bust , just not enough time.
I do have most of a MOA comp rig though, may be in the classifieds shortly .
Old 07-03-2017, 08:07 AM   #34
That's to bad you'd probably enjoy the super... wish I had one.
tapped-out is offline   Reply With Quote
Old 07-03-2017, 12:47 PM   #35
Yashua
CREEPERBOB's Avatar
Yeah, I've had a couple Super Bully rigs and they ARE the shizit .
Old 07-17-2017, 06:10 AM   #36
Yashua
CREEPERBOB's Avatar
Well, my brand new 2 front Bully 2 axles and 1 used rear bare axle housing lockout to lockout is in the for sale classifieds.
Bob
Old 07-21-2017, 09:17 AM   #37
I was looking forward to the completion of this.. but other things happen. did you just give up or?
Old 07-26-2017, 03:24 PM   #38
Yashua
CREEPERBOB's Avatar
I really did too, to much all the time it seems.
I'll see, maybe no one will buy them huh .
Old 07-27-2017, 05:13 AM   #39
hopefully you get to keep em. there needs to be more supers and less scalers.
Old 05-29-2018, 07:16 AM   #40
Yashua
CREEPERBOB's Avatar
:twisted: hmmmm
super time - Similar Threads
Super Supercapsitor: our next RC battery? 60 second charge time STANG KILLA SS Chit Chat 11 03-29-2017 08:33 AM
An Evil Super Bully build... time for a different chassis... EvilTwin v2 Superclass Crawlers 4 10-05-2011 12:43 PM
