02-11-2018, 04:38 PM | #41 | |
Pebble Pounder Join Date: Jan 2018 Location: Spain
| Re: Crazy axles idea design Quote:
Anyway this V2 design is still on the drawing table so let see what come out finally. I just ordered today the gears, bearings, hardware staff and a couple of different winding motors, in order to start building and testing. | |
02-11-2018, 09:37 PM | #42 |
Newbie Join Date: Oct 2016 Location: NH
I believe the best way to fix it is have the links not share pivots, and I think the shocks need to be mounted to the chassis in front (and behind, on the back) of the upper link mounts. If you want to avoid stupid long shocks, then the bottom mount can be on the link, instead on the top as you had in that model. The non-shared pivots with shocks mounted to the chassis should prevent "active load adjusting castor." The chassis can still be pretty small and simple, but not quite that simple |
02-13-2018, 08:07 AM | #43 |
Good suggestion Gandalf. One way to reduce the forces that go throw the shock absorbers is to make a chassis as you say, but that is what V1 Gosainthan is about, and I want to test a chassis-less one so I changed how the links are mounted so more forces can be derived throw the chassis instead of the shocks absorbers. Here is a picture of the idea, let me know your thoughts. The crossed links are on the front but I think they will be better if they are crossed on the rear. |
02-13-2018, 07:10 PM | #44 |
I think you can make a simpler model of 7 "links", the 4 links and the 3 vertical sections. Then anchor one or both ends on a fixed cylinder, so the end vertical links can rotate around a point. If you have all the joints constrained properly, you should be able to move pieces around and see how the castor will change.
02-14-2018, 04:25 AM | #45 | |
The front castor angle changes around 2º during full suspension travel Rear castor changes much more, around 20º but actually I want it to perform like that. With this design traction twisting forces are transmitted throw the links from axle to axle and to the ground throw the wheels with out much intervention of the shocks. So in other words we are linking the front and rear axle and what happens on one will affect the other: - If the rear axle has more traction than the front then it will push downwards and a little backwards the front axle. - If the front axle has more traction then it will push backwards and upwards the rear axle. I hope it will perform like an automated dig/scrub function, but not fully sure if it will be positive, only testing will tell. Thank you for remind me that I can use a 3 link instead of a 4 link geometry, I was having an issue of interference of the rear shocks with the links, using only 3 links will avoid that. | |
02-14-2018, 09:43 AM | #46 |
Cool, I wasn't sure if you had made this model with that in mind. I would try and avoid 3 link if possible, but if you can do 4 link in the front that should be pretty good, at least to test IRL travel and clearance. Side note, you using F360? I have found the collision detection to be a little exaggerated during some complex joints, that clear fine after 3D printing the parts. Don't know how bad the shocks interfere, but figured I would mention it. |
02-14-2018, 11:35 AM | #47 | ||
What is IRL? Quote:
The shocks do interfiere on the CAD so will do in real world. Thank you Gandalf for your tips you are a great help. | ||
02-14-2018, 11:53 AM | #48 | |||
02-16-2018, 05:46 PM | #49 |
Well here is a picture of the final version of the V2 Gasherbrum. With a crossed 3 links at the rear. Here is a picture of version V1 Gosainthan at full articulation. Now I am just waiting for all the parts, bits and bobs to arrive... |
02-17-2018, 03:51 AM | #50 |
V2 is going to fold itself up. There is absolutely nothing there to support the "chassis", or to prevent either axle from driving under or over it. You would need an almost rock hard spring to prevent that from happening, in which case an incredible amount of stress would be placed on the axle tubes, upper links, and upper shock mounts.
02-18-2018, 04:08 AM | #51 | |
https://youtu.be/CbmduktO9wg?t=4 And yes in V2 chassis needs higher spring rates I have already calculated it, around 150% more on front axle and 190% more on rear axle if a behavior like V1 version is wanted, I think it may work better with a bit more up/down and side/side flex so provably will install lower spring stiffness that those percentages. In order to handle stress the rods will be 8mm CF tubes. If not enough I can go to 10mm and aluminium rod ends. Anyway this is V2 version is just an experiment that may not work at all, So will drive the V1 then. | |
03-07-2018, 11:35 AM | #52 |
| Re: Crazy axles idea design |
03-07-2018, 04:19 PM | #53 | |
I ordered everything a few weeks ago but Chinese new year have delayed the shipments. Just today confirmed the shipment of the last parts ordered so everything is on its way here. I still have not ordered screws and little hardware staff that I will do locally usually takes 24-48h so no big deal with that. And have to order tires, as I never have cut and shut tires I am thinking in order this cheap ones or this others so I can learn how to do it with out ruining out expensive ones. Witch ones of those two you all think may be the best ones to cut and shut for a Super? The plan is: - Check sizes of parts when arrival and compare with design, modify design if necessary. - Print pieces on ABS and PLA and build it up, provably some redesign and reprint may be necessary in this step. - Test it to the limits to see where it breaks and how to improve it. - Iterate again aiming final design and finally prints on Nylon and/or PETG. | |
03-07-2018, 04:38 PM | #54 | |||
Now, I don't have any experience with larger scale performance tires (I own a Summit ), but my "was a 1:24, now isn't" micro Super loves pin tires. And they were not very hard to make, hardest part was a consistent width. I have heard of using a dremel mounted some distance above the table, but I just went at it with some scissors and they turned out alright. Quote:
Good luck Last edited by Gandalf The White; 03-07-2018 at 04:43 PM. Reason: Added a little | |||
03-07-2018, 04:46 PM | #55 |
Actually, those tires you are looking at might not need to be narrower, just taller. I found that was pretty simple, hardest part was making mine the right diameter to fit some micro rims. And if you are printing rims, that won't be an issue.
03-07-2018, 06:03 PM | #56 | ||||
I have not added thrust bearings to the worm but they can be added to the design if need. | ||||
03-07-2018, 06:20 PM | #57 |
Pebble Pounder Join Date: Feb 2014 Location: Canada
Any farther along production...is there a mock up we can see I'd definitely like to see a working prototype it has definitely peaked my interest
03-10-2018, 05:23 AM | #58 |
03-25-2018, 06:17 PM | #59 |
FINALLY I received enough material to start the construction. I made a mistake and ordered only 2 motors (one of each kind) and I wanted to order 8 motors will reorder... Still some parts to be received and ordered but at least I can make some progress with this. Now I am checking sizes and tolerances on the design with the final components. I am upgrading the 3D printer so will be able to print the first parts in a few days. |
03-26-2018, 08:56 AM | #60 |
Can't wait for some build pics!!!
Crazy axles idea design - Similar Threads | ||||
Crazy idea? | nahuebsch82 | Axial Wraith | 18 | 03-23-2015 12:15 PM |
My Crazy Idea.... | Nootch | Tires and Wheels | 9 | 11-07-2009 12:00 AM |
Another crazy idea of mine | BJoe | Paint and Body | 7 | 01-11-2008 01:50 AM |
crazy idea | clodman666 | Chit Chat | 13 | 09-27-2006 12:26 AM |
crazy idea | reedpowell33 | General Crawlers | 3 | 12-15-2004 09:59 PM |
