Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: Crazy axles idea design
Old 06-04-2018, 05:49 AM   #121
Yashua
CREEPERBOB's Avatar
Default Re: Crazy axles idea design
Originally Posted by gonper View Post
Motors arrived some days ago.
They have been run in, condensers and leads soldered and cans decorated
Now I can start the final assembly, Yehaaaa
Is it alive yet?
CREEPERBOB is offline   Reply With Quote
Old 06-07-2018, 03:43 PM   #122
Family and work issues have kept me away from the workbench, so I was not able to progress too much.
Anyway I was able to make the electric harness to connect the 2 batteries, 4 ESC, Receiver, and a Voltage Indicator.
Testing is closer now
gonper is offline   Reply With Quote
Old 06-08-2018, 03:37 PM   #123
Well here it is finally fully assembled.
Tomorrow will drive it
I did some test runs inside of the workshop and for what I can see now it is not going to work any well (as expected ) This is what it is, trial and error.
But no problem, will redesign and test again
Old 06-08-2018, 03:50 PM   #124
Yashua
CREEPERBOB's Avatar
I really like .
Old 06-12-2018, 01:18 PM   #125
sick nasty creation!!!! cant wait to see some vids of this thing running
intheworks is offline   Reply With Quote
Old 06-13-2018, 09:18 AM   #126
Really cool project lots of innovative ideas . But any of the electronics sitting outside the wheels are going to take a beating. And will let the truck hang up on the rocks or other stuff mother nature but's in Ur way. Not trying to be overly critical just being realistic.
Name:  Screen Shot 2018-06-13 at 8.09.19 AM.jpg
Tom G is offline   Reply With Quote
Old 06-14-2018, 04:26 PM   #127
Video of Gosainthan :p running. I crashed just before filming against a wall already broke a part fixed it and made the video.
That parts brake is part of the plan as it is printed very weak in order to redesign and improve strength.
Maneuverability is great, even that I am not getting full turning radius with this servos.
But it does not work any well due not using the correct gears and not appropriate gear ratio. It almost has no power due that.
New gears are on the way
Old 06-14-2018, 05:23 PM   #128
Yashua
CREEPERBOB's Avatar
Very cool to see run. Steering isn't bad
Old 06-14-2018, 05:43 PM   #129
Thank you for the input I have the same feelings.
This wheels are around 30mm wide the motor and battery are almost fully covered with the wheel but the servo is quite exposed.
And I have plans for next iteration, move the motor, battery and servo more inside the wheel and use wider wheels (around 40mm) and a slider/cover for all parts.
This is a CAD of how it looks like with 40mm wheels:
Old 06-15-2018, 12:01 PM   #130
Yashua
CREEPERBOB's Avatar
The video looks good, for first test run it appears to be a success.
Granted redesigning some stuff will improve it, but for a first test I would be happy with what you have already accomplished .
The extra 10mm of width for the wheels will help a bunch to protect electronic devices.
Old 06-15-2018, 05:55 PM   #131
After several test I have discovered manny flaws of the design.
Main issue is lack of power, something that it was on the table even before testing.
The ideas that come up to solve that is to change the gear ratio from 30:1 to 60:1 and reduce the pinions size from M1 to M0.5
If that does not fix it then try to install four 540 motors on each wheel and make a power beast
Some other issues are structural issues, one of the axles broke on a small crash, and latter i discovered another crack, on same axel. But that is not bad:
I printed the parts strong but not ultra strong so they can break easily in order to improve the design latter, and with that I have already discovered a couple of issues, one is a weak point on the axels design and that PETG is not a good material for RC car parts due its viscoelasticity characteristics.
So time to go back to the drawing table
Old 06-15-2018, 06:05 PM   #132
Thank you very much for your words.
After the first test i wasn't any happy at all, I expected a lot of different flaws but not such a big problem with low power It makes that I can not test it on rocks so more issues will arrays when I enter in rocks.
Well now I have accepted it. It is going to be a long journey...
Old 06-15-2018, 06:47 PM   #133
Yashua
CREEPERBOB's Avatar
I Do wish I had CAD skills.
I'm playing with a couple software programs but never seems to be enough time.
I will anxiously watch for next updates.
Old 06-15-2018, 08:53 PM   #134
Getting into CAD can be very daunting, even more so without any way to visualize your designs (laser cutter, cnc router, 3d printer). Designing things you enjoy helps a lot at the beginning.
As do we all!!
Gandalf The White is offline   Reply With Quote
Old 06-16-2018, 02:58 PM   #135
Try Onshape, the learning curve is fast and easy and it is a fully capable CAM software and it is free for hobbyist.
Old 07-02-2018, 04:38 AM   #136
Yashua
CREEPERBOB's Avatar
How is the redesign going here?
Old 07-24-2018, 01:13 PM   #137
I have been very busy with work issues, and no spare time for hobby
I received the new gears some days ago and I hope to have some spare time by the end of mont or in August. Will redesign he gearboxes for the new gears, and will see.
Old 12-12-2018, 06:15 AM   #138
Yashua
CREEPERBOB's Avatar
Have been hoping to see your improvements
Old 01-03-2019, 03:10 PM   #139
Finally I have took some days off this Christmas and done some improvements on the gearboxes design design.
Will post pictures and so in a a few days.
You can check the design changes here: https://cad.onshape.com/documents/27...1cbb92cec77030
BTW, what happened with the pictures???
Old 01-21-2019, 05:50 AM   #140
If they were hosted on photobucket, they w w re pro ably removed because photobucket changed their service to make it so you have to pay to embed photos. All that would show is a non working link but no photo.
makya is offline   Reply With Quote
Crazy axles idea design - Similar Threads
Crazy idea? nahuebsch82 Axial Wraith 18 03-23-2015 12:15 PM
My Crazy Idea.... Nootch Tires and Wheels 9 11-07-2009 12:00 AM
Another crazy idea of mine BJoe Paint and Body 7 01-11-2008 01:50 AM
crazy idea clodman666 Chit Chat 13 09-27-2006 12:26 AM
crazy idea reedpowell33 General Crawlers 3 12-15-2004 09:59 PM
