Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: First Super - 5th Dimension Super Dominator
Old 07-28-2021, 01:18 PM   #1
Default First Super - 5th Dimension Super Dominator
I couldn't help myself, I wanted a super and finally decided to bite the bullet and get started.
I'll rattle off the parts list here (somewhat subject to change):
5th Dimension Super Dominator Chassis.
Progressive RC 3d printed gear cases, knuckles, chubs, hubs, link mounts.
Carbon fiber tube, 12mm OD x 8mm ID for axle tubes.
Dluxfab SAF low ratio berg gears.
Dluxfab 7mm FBA super length shafts, with 8mm stub shafts.
Dluxfab Dravtech short shocks, internally limited ~6mm.
Soft springs all around, for now.
BR Mini Dual from Dluxfab.
Team Brood Conflux tk-2 45t motors.
NSDRC rs800 v2 servos.
Sanwa M12
My initial plan was to use brushless outrunners, I've changed my mind and decided to go brushed for the super. My C2(TGH V3/Capra), 2.2pro, and 2.2s all use brushless outrunners. For the super though, I decided to go with a more proven platform... for now
I'm waiting on motors to be delivered in a few days, then I should be able to button it up. I am super stoked to get it on the rocks and start tuning, and LEARNING.
I'll drop a bunch of pics of the progress thus far.
Cheers,
Gable
pcgab is offline   Reply With Quote
Old 07-28-2021, 01:20 PM   #2
Default Re: First Super - 5th Dimension Super Dominator
Chassis and wheels.
Old 07-28-2021, 01:21 PM   #3
Axles:
Old 07-28-2021, 01:22 PM   #4
Chassis, link, shock, etc. setup:
Old 07-28-2021, 01:25 PM   #5
Wheels, tires, etc.
Old 07-28-2021, 01:26 PM   #6
The purple truck sitting on top of the super is my 2.2 sporty, 5th Dimension Sucker Punch, ar60's, etc. for size comparison.
Cheers,
Gable
Old 07-28-2021, 05:25 PM   #7
Rig looks good.. I've always wanted to build a super.. just never pulled the trigger.
Sent from my SM-G781U using Tapatalk
tapped-out is offline   Reply With Quote
Old 07-29-2021, 04:56 AM   #8
That is one sexy rig!!!
You have been great to work with on the axles.
They look very nice!!
Hope they perform as well as they look...
xkill is offline   Reply With Quote
Old 07-29-2021, 09:05 AM   #9
Thank you!
It's been a fun build so far. You should totally do it
Cheers,
Gable
Old 07-29-2021, 09:06 AM   #10
Thank you!
I'm enjoying building your axles, I think they're going to perform very well!
Cheers,
Gable
Old 12-30-2021, 09:51 AM   #11
It was great to see this out on the rocks yesterday!! pulled some lines I thought were impossible!
Turtlejon is offline   Reply With Quote
First Super - 5th Dimension Super Dominator - Similar Threads
5th dimension dominator chassis Foxracer11 RC4WD Bully 20 02-09-2017 02:43 PM
The 5th Dimension "Super Dominator" cboggs Chassis and Suspension 15 11-08-2016 03:11 PM
Mammoth's 5th Dimension Dominator Build mammoth EnRoute Berg 20 04-17-2016 07:06 PM
