Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Integy universal drive shafts
Old 03-11-2008, 11:28 PM   #1
Default Integy universal drive shafts
Has anyone used integys universal axle shafts #C22764 would like to know the good or the bad on these axles. Thanks for any info
gotmax59 is offline   Reply With Quote
Old 03-12-2008, 01:01 AM   #2
I have a set for back up, havrn't tested them yet...
run2jeepn is online now   Reply With Quote
Old 03-12-2008, 02:22 AM   #3
Total garbage! I have 2 sets and had broken one within the first 10 minutes of running my clod. The tires were'nt even stalled and they snapped apart when I was trying to climb over a curb. They also tend to bind very badly when turning. The only reason I bought the Integy shafts was because I couldn't find a set of the Tunder Techs anywhere.
jdmstuff is offline   Reply With Quote
Old 03-13-2008, 11:54 AM   #4
Red
That sucks!!! i just picked up a set. I hope i have better luck.
Red is offline   Reply With Quote
Old 03-15-2008, 09:45 PM   #5
Broke my other set today driving on flat ground. They are very brittle.
Old 03-19-2008, 12:41 PM   #6
xzk7nr's Avatar
I dont know about the durablity of them but I need to cut mine down to fit. They stuck out far enough that they would bind up the steering. Ill keep you posted on the them after i run them
xzk7nr is offline   Reply With Quote
Old 03-19-2008, 10:24 PM   #7
well thats sucks! I just bought a set also.:-( oh well I'll run them till they break
Sneff is offline   Reply With Quote
Old 03-19-2008, 10:38 PM   #8
Which should be about 5-10 minutes.
Old 03-20-2008, 07:41 AM   #9
Bummer!!!:-( Integy makes some really cool stuff but I'm starting to lose faith in it. oh well, live and learn
Old 03-20-2008, 02:25 PM   #10
Integy does make alot of stuff, and It is usually cheap, problem is that they are usually made cheep and don't last. just my experience.
mysharona is offline   Reply With Quote
Old 04-09-2008, 08:14 PM   #11
xzk7nr's Avatar
Well they suck!!!!!!! First hit of the throtle and Bam-mo snaped both of the rear ones.
Old 04-30-2008, 09:53 PM   #12
I broke both sides in less than five minutes!!
djeepman is offline   Reply With Quote
Old 05-01-2008, 12:21 PM   #13
I broke all four in 10 min. I even bought spare set. Arrrggg. These are junk....
Neil E is offline   Reply With Quote
Old 05-02-2008, 12:55 AM   #14
Talking
go with the RC4WD axel shafts,they are deffinetly harder and they really stand behind their product
budcrawler is offline   Reply With Quote
